Results 1 to 2 of 2
    NorCal - Vacaville to Martinez
    If anyone is familiar with this area, do you think this commute would be possible. In the near future the old <A HREF="http://solanosgotit.blogspot.com/2008/01/work-on-old-benicia-bridge-to-add.html">Benicia</A> bridge is suppose to be retrofitted to allow walking/bicycling across it. Once this is done I was thinking about trying this commute.
    I'm just not sure if it's even possible given some of the roads and routes I would most likely have to go. It is 33 miles roughly depending on the route.
    Just curious if someone from this area has an opinion, or maybe I should just forget about it.
    Maybe
    Getting to Fairfield is no problem. You'd have to check out the FF to Benicia leg along 680. It looks like Lopes road might work. It will be windy as hell.
