Page 1 of 2 12 LastLast
Results 1 to 25 of 35
    Huckin' trails
    Reputation: David C's Avatar
    New DIY studded tire thread ! Post your ideas and experiments :)
    Hi fellow winter warriors (and vets) !
    First snow just hit us this week, but many of you have been going trough the whity mitty powder already for a while now.
    Which makes it the perfect time to start discussing about our DIY studded tires for commute and snow blasting duties. No matter if you ride 24" or 700c, 5km or 30 miles, 1.5 or 2.4 wide, slick or knobbies, we want to hear your thoughts, experiments and experiences/inventions in turning tires into ice spikers and getting the grip back to you !
    No need to buy expensive "winter" tires when an handful of screws and a cheap rubber is all you need to turn something hard into an hardcore riding experience
    So show me your techniques, setups and user-tinkering on how to make the best DIY studded rubber in town. What tire, which screws, what patterns, etc.
    Me, I started making my owns last winter, as doing a short 5km round-trip commute to college and the occasional winter warrior ride out in the wild. I used a bunch of screws I had laying around to do my first tire, a generic 26x1.95 front tire. Since then I got some #6x3/8 zinc plated self drilling screws and made a rear tire, a 26x2.3 Duro Maveric Demolition and that I also ran in rear on my big MTB and loved the extra grip on hard pack snow.
    Now I just put back on my front one on my commuter, and I plan to use the rear one on my big bike as a season setup, along with a new front one, a CST Caballero 2.4 I just bought (will have it for Christmas) and using new screws to complete the rear one and do the new front. Last year I used about 85 self-drilling screws in the rear. They were Richelieu self-drilling zinc plated with pan head, square bit, in #6 by 3/8". They wear out decently, though I may only had put about not more than 200km on them.
    This year, I found some H. Paulin self-drilling framing screws, in #6x7/16", with black phosphate coating and pan head Phillips bit. $20 for 500, decent price. They look quite good, as the additional 1/16" length will be great to have almost 3/16" of the self-drilling tip sticking out instead of the shy 1/8" from the 3/8 screws. All depends on the thickness of your tire/knobs though. I hope the black phosphate coating will do a better job at prevention surface corrosion as the zinc plating did, although it's not much of an issue, more esthetic than anything else.
    See them here :
    The Richelieu zinc plated :
    The two tires I did last winter :
    New DIY studded tire thread ! Post your ideas and experiments :)-imageuploadedbytapatalk1354425044.990287.jpg
    New DIY studded tire thread ! Post your ideas and experiments :)-imageuploadedbytapatalk1354425147.805016.jpg
    Now the few things I learned. First #6 screws are pretty much the best size. #8 are too big and would tend to split the rubber too badly. 3/8 to 1/2 is a good length range depending on your tire thickness. Drill pilot holes from the outside first and when choosing a tire, plan on which studding pattern you're gonna use. You can easily use 100 to 150 screws per tire, so a box of 100 might not be enough. Use a tire liner or some old big truck inner tube wide slice to protect your tube from the screw heads, very important because the screw heads will slowly work their way against your inner tube every time you ride and /brake. If you plan on running tubeless, a drop of silicone on the threads before putting in the screw might help sealing better and prevent the screw from backing in. The larger/flatter head the better, since it will give more support and less prone to tear up the rubber or get loose by wiggling around. Self-drilling tip are quite good, but I don't know if they are that much better than just a nice sharp framing screw tip to be worth the hassle finding them.
    Also be careful not to wreck your nice wooden floor if you live in an apartment or have to carry your bike somewhere where it's not ceramic/concrete floor. Surface rust on the screws don't really matter since as soon as you're gonna ride again, it will get grind off right away. And I still wonder about an ideal tire pressure range for using DIY studded tires. Maybe something like 40psi for the usual 26x2" MTB tire ? You don't want to let the screws to be too loose when hitting the brakes.
    So show us what you got !
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    R.I.P. Pugsley.
    Reputation: Rabies010's Avatar
    Jan 2011
    You might want to check the fatbike forum as well, a lot of DIY studding is being done over there.
    Also you might want to take a look at these: Grip Studs™ Screw-In Tire Studs | Traction in Ice, Snow and Dirt | Bicycle Tire Studs
    i have used Schwalbe Ice Spiker's on my 26er, and om going to get a set for my 29er as well.
    But i really wish i had the dough for a set of 45Nrth's Dillinger's....
    CheesyRider
    Reputation: riderb's Avatar
    "a handful of screws and a cheap rubber is all you need"
    Sounds risky to me! But ya I did this last winter with one tire for the front and will be doing the other to make a full set this winter. Just waiting around for more snow. There is a sticky on another forum with some good info on this subject here:
    Making Your Own Studded Tyres
    My concern is flatting from the screw heads. I used duct tape to line the one I used on the front and I'm considering using a thin foam pipe insulation around the tube for the rear or both...
    Enjoy yourself, it's later than you think.
    Quote Originally Posted by Rabies010 View Post
    Flippin hell...for the price of those studs, you might as well buy a pair of Nokians and their stud replacing tool. And you'll still come out under half of what it would take to do two tires.
    as for the tube to screw head interface,you might want to try these. their wider and flatter than panheads.
    and cheaper
    Metra PWHT812 8 X .5 Phillips Wafer Head Tek Screws
    Huckin' trails
    Quote Originally Posted by riderb View Post
    Well again your mileage may vary
    Like I said I'm doing a short 5km round trip commute and the occasional weekend warrior snow blast maybe once or twice a week when time and weather allows it. I like to run tires at least 2" wide and MTB style.
    Idea of this thread is to post up new ideas and discuss about commuter and MTB dual setup for winter studs as many commuters here also like to MTB in the snow. And many lives in a urban area.
    Regarding your tire liners, I tried duck tape at first, and put down 2 layers, thinking like you it would be enough to prevent the heads from puncturing your tube. Well on the front tire it took about 10-20 commutes max before one evening I was heading home, jump on my bike and it felt very soft in the front. Turns out I had finally punctured the tube on my ride in the morning and now I had to ride home on a flat. Lucky I had a wide rim and good tire casing which allowed me to just ride it home anyways instead of walking the 2.5km. When I took out the tube, I had about 30 or so holes to patch up to prevent possible future leaks and then about 2-3 real punctures. Then I had a big thick truck inner tube laying around, so I cut a wide 2" strip and used it to line the tire. Then it worked out good. I'm still running that tube in the same wheel and riding the bike everyday. And I also did the same thick rubber lining for my rear tire. I think it's mostly the fact that front tire studs have way more wiggling from braking, turning and hits than the rear tire that made the heads work their way trough the tape a lot faster. Ideal would be to simply use a regular tire liner already, but I didn't had any so I went the fastest way around. But otherwise the idea of using an inexpensive tire (in the way that you don't need to bust your $60 Ignitor for this purpose, just buy nice knobbies on sale) and screws with a tire liner is way more cost effective than buying dedicated studded tires already. I don't have the luxury to spend $150 on a set of studded tires just for winter duty and even if I did, I'd probably still find the DIY way more fun to do
    And those Grip Studs are nice, but $100 for 100 studs isn't in my budget at all, considering I'd use a minimum of 150 studs for a set of tires. I think I'll stick to my 100 screws for $6. Thanks for the link though
    Huckin' trails
    Quote Originally Posted by drewvir View Post
    and cheaper
    You are right, Wafer heads are way better than Pan heads for this purpose. My only issue so far was not being able to find them in #6x3/8 with a nice tip or decent price yet locally. I saw some Richelieu #8x3/8 self-drilling with Wafer head, in $5 for 100 pack, but #8 is just too big not to shear the rubber unfortunately
    If someone can get Wafer heads instead, that'd be even better. But I'd still use a good tire liner anyway.
    Reputation: newfangled's Avatar
    David, you saw my thread on this last year, but I'll post it here for reference:
    DIY Studs and Tubeless
    My experience - stud the outermost knobs, and tubeless worked great.
    But I gave up on mine by Christmas because the screws were too worn down.
    A new #6 3/8" screw on the left
    A typical screw from the front tire in the middle
    A typical screw from the rear tire on the right
    Last year was also a freak year though, and I spent two months running those tires on basically bare pavement. If I'd tried it this year instead I think they would have held up a lot better, because the roads have been under snow&ice for a few weeks now.
    I buy nokian tires with tungsten carbide tips. $ 45.00 per for my commuter ride and will last at least 5 or 6 years. YRMV, works for me. You do the math.
    Huckin' trails
    I sure know about your thread
    You get a lot more mileage than I do. So far my front tire hasn't been wearing down much at all. Rear one about 25% down the tip, using the same screws as you did, so maybe half the wear your front tire screw is showing on the picture. I'll be working on my rear one in the next days hopefully, and I'll take out a few screws and replace them with the longer black 7/16" ones and see how good they wear. I'll also track the mileage as it will be on my MTB and not my commuter, and will have about a 50-50 of urban and trails.
    Do you plan on going DIY again this winter ?
    I Ride for Donuts
    Oct 2007
    $45 per tire?!?! Where are you shopping?!
    I just got Nokians (finally) this year also, but I'm all about DIY options... from what I've seen though, the labor involved, maintenance, and longevity of DIY studs tipped me towards buying the real deal. $150 for the pair (29er) on a crazy ebay deal, and I'm hopefully set for several winters.
    Curious to see what everyone is coming up with though...I'll go DIY when the technology meets my strict demands like I did with tubeless.
    (no excuse for that either)
    All Items - Bruno Wessel - Tire Studs, Studding Equipment
    Some interesting possiblities here.
    My stud milage is so high that there is just no point in DIY studs.
    Carbide is the way to go, and aluminium/carbide is even better.
    Quote Originally Posted by David C View Post
    Last winter I found a good deal on the 29er ice spiker pros, so I'll be using them for hopfully the next bunch of winters.
    Where'd you find the black screws?
    I'm grabbing this from my old thread, since it's useful info:
    Bolt Depot - Selecting Fastener Materials - Steel Grades, Brass, Bronze, Stainless Steel
    Stainless Steel:
    It is a common misconception that stainless steel is stronger than regular steel. In fact, due to the low carbon content, stainless steel cannot be hardened. Therefore when compared with regular steel it is slightly stronger than an un-hardened (grade 2) steel fastener but significantly weaker than hardened steel fasteners.
    Steel:
    Grade 2 is a standard hardware grade steel. This is the most common grade of steel fastener and is the least expensive.
    Grade 5 bolts are hardened to increase strength
    Alloy steel bolts are made from a high strength steel alloy and are further heat treated. Alloy steel bolts are typically not plated resulting in a dull black finish. Alloy steel bolts are extremely strong but very brittle.
    If I ever do DIY again I'll have to hit up one of the speciality fastener places to try to find hardened screws.
    Quote Originally Posted by newfangled View Post
    Check out my link.
    I Ride for Donuts
    Oct 2007
    I don't buy any bolts/hardware for my Jeep that isn't Grade 8, but I don't know if there is such a thing as grade 8 teeny tiny screws...
    ^ yeah, ideally there'd be a middleground between the spendy screw-in studs, and the fast-wearing hardware grade screws. When I looked last year the local hardware stores weren't any help, and I didn't check the speciality fastener shops because none of them are open past 5.
    But I know a bunch of people who swear by the standard ones and ride in conditions where I'm white-knuckling with my schwalbes or nokians.
    Huckin' trails
    I got the black screws at Home Depot. They are simply black phosphate coating and maybe not harder steel grade then the zinc plated ones. Although while checking out the manufacturer's products specs (they are made by H. Paulin), they said they were using harder and better steel for all of their self-drilling and self-taping screws, but however those exact self-drilling ones I got are not under the same category as all of their self-drill/taping screws, they are under the framing section, which doesn't state any info on the steel used. So they might or might not be of harder steel.
    At least the black coating should help regarding corrosion and esthetic. And the extra 1/16" may make the difference between an early end of season tire life and riding till spring.
    I know about the steel grades, and I browsed that Bolt Depot website quite often. They have very nice information and good selection. Also when I did DIY pin my flat pedals, I made sure to get the highest M4 bolt grade I could find locally, I think I got class 10.9 (could be grade 8 in imperial). Wish I could find some alloy steel hardened whatever self-drilling screws. I might have another big specialized hardware store to go look at next time I'm in that part of town.
    And like another poster said, as long as it meets our requirement and is cost-effective, DIY all the way
    That $ 45 was for 26" x1.95 nokian mount and ground about 3 years ago. A company called Grip Studs makes studs that you just screw into the tire from the outside.
    Huckin' trails
    Quote Originally Posted by leeboh View Post
    Yup, link was already posted in the beginning and consensus they are just too damn expensive for the usual rider and even compared to studded tires. Though it's nice to have them around if someone ever wants to tinker much, well at least there is many options out there for all kind of budget
    conjoinicorned
    Reputation: ferday's Avatar
    the Grip Studs are so expensive that you could've bought commercial studded tires (about $1/stud). i could see them being useful if you wanted to stud a special tire (like a 2.5 DH rubber or something)
    i'm done with DIY studs, they worked great when i simply couldn't afford commercial tires, but they never, ever lasted very long (although you can just put new screws in the tire which is cheap enough) and they aren't very comfortable to ride unless they aren't sticking out very much (i've used a bolt cutter with good success) but then the mileage goes down again
    my hakkas have probably 2500 miles on them over years and years, and the studs are still in good shape. considering the "smiles per miles" quotient they were actually waaaaaaay cheaper than my DIY studs, faster and more comfortable to ride
    that said...i had best luck with the wafer head black screws with the sharp tip, they are dirt cheap. i also learned quickly to cut the heads down to have as little sticking out of the rubber as possible, otherwise dry pavement sucks bad. if i was using the tire offroad i'd probably leave the studs long...
    what would rainbow unicorn do?
    ^ I'd pretty much agree with that, since for typical riding you should be able to get a set of the basic nokians or schwalbes for under $150, easy. That's the cost of two months' transit, but could get you through 5+ years of winters.
    The only reason I went DIY last year was because of the limited 29er options (ie. 1). But by christmas the new schwable 29er tire was available so I switched over. If I had a fatbike or a krampus I'd probably still be looking DIY though, since there's not much commercially available or it's $400+ for a set.
    Huckin' trails
    Quote Originally Posted by ferday View Post
    Few questions.
    Where did you find the wafer head black screws and any link for them ?
    Why didn't you simply used shorter screws instead of cutting them ?
    Did you ride on more skinny tires ? I'm always on 1.95 or bigger, so although I can feel and hear them on pavement, I don't get any comfort issue regarding ride quality.
    Why not simply let them wear as the rubber wear down ?
    And again, you seem to put a lot of mileage during winter, while some others don't get much more than 800 km.
    And isn't winter riding almost off-road conditions 90% of the time ?
    conjoinicorned
    i got mine at home depot, they look like this i think they are called drywall screws or something.
    screws only come in so many lengths...so pretty hard to find the exact length needed, so i went longer....after a few rides of bumping around (especially on the dry parts) i cut them. my first DIY set were on 2.3 worn out old nevegals. i also made the rookie mistake of putting way too many studs in...especially on the centre row where they aren't needed as much and really destroy the ride quality
    i commuted for years, i don't any more as i work out of town now, i still use my hakkas on the fixed gear for bombing around and going to the store, etc and that mileage has been over many years. honestly i prefer the narrower tires with the studs, they grip fine and are way easier to pedal around than the big 2.3's, also they cut through the road slush rather than skidding on top.
    i've spent a lot of time in montreal (i'll be there in a few weeks for christmas) and i know your winters (ice storms LOL). DIY studs work fine, but after i finally sucked up the $150 for proper studded tires i'll never go back, unless i feel like trying DH with studs or something (since i got my fatbike i have no interest in studs offroad anyways)
    to make a long story short...DIY studs can be made to work great, but it takes time and effort...and after years and thousands of km's my nokians are still going strong...I'm a DIY fan but not for studs anymore
    R.I.P. Pugsley.
    Jan 2011
    I remember that in another thread someone used grubscrews to stud a tire.
    He drilled a hole from the inside out screwed in the grubscrews until it completely disappeares in the rubber and i also think he glued in a really thin innertube as a tire liner.
    Huckin' trails
    I saw those screws too. I don't know if they are much difference in performance between those pointy tips or self-drill ones. Funny tho for Christmas I won't be there, but at the beach for 2 weeks
    Currently it's raining outside, about 5°. But the next days will be under freezing point, so some black ice is to be expected hehe
    I also only have 2.5km each way to go on a fairly busy street, which means warmer pavement and less ice, but more slush. But I also enjoy going wild during winter and I want whatever bike I'm riding to be able to handle my randomness and lack of total judgment like a kid trying to run on a ice ring. I'm crazy like that haha
    I think my current riding style would have to change greatly if I was to do a 10-15 km commute everyday instead. But I'm riding for fun and nothing else. So screw whatever will be better but less fun ! Just kidding, not that badly. I like to do stuff my way, that's all
    And I still welcome opinions and suggestions on everything and see what makes my day
Hot Deals
Contests
Latest Mountain Bike Articles
