Results 1 to 13 of 13
    Hikers=SHlT
    Installed trigger shifters on a 31.8 drop-bar today
    I don't have the money to buy expensive road shifters, bar-end shifters, etc.. so I used what I had. I basically used a couple cheap 31.8mm seat post clamps, ground down the metal lip inside of them, bored out the threads, and filed a flat spot for the shifter mount. I admit, it does look a little out of place, but they function flawlessly.
    I searched all over the net and could barely find any info on how to do this. Maybe this will help someone out in the future. They're Sram X7 9-speed shifters by the way,
    Reputation: mattbryant2's Avatar
    Apr 2005
    Whow. Nice work. I'm intrigued.
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    it even looks good.
    Oct 2012
    Looks very nice. I've been thinking about putting drops on my commuter as well but got hung up on the price of shifter/brake combo levers. What are the brake levers you're using?
    MTB, Road, Commuting
    Reputation: bedwards1000's Avatar
    It looks like that fork has ample clearance for that tire too. The shifters look like they belong there. Someday I'd like to build a Frankenbike with all my spare parts.
    Reputation: bikeCOLORADO's Avatar
    Sep 2003
    That is an ingenious and badass solution. Well done.
    I want to ride my bicycle...I want to ride my bike...
    I Ride for Donuts
    Oct 2007
    Very cool. I ran an 8 speed trigger shifter in the same spot on my 31.8 drop bars for a long time... I got away with it by just using a longer bolt and bending the clamp into a more wide open position. but then you have to bend that longer bolt bolt too, and when you go to tighten it, you're constantly bending the bolt with every twist...if that makes any sense. I got away with it for a few years with no issues, but your solution is definitely more permanent and looks sharp too.
    (no excuse for that either)
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    For a while i ran
    $13 6 spd sun race friction shifters held on the bar with zip ties. The set up got some good laughs. The set up lasted longer then i thought it would.
    Hikers=SHlT
    Thanks guys. I wasn't sure what kind of response I was going to get. The frame is a Sette Reken mtn frame and the fork is a aluminum Mosso with a short axle to crown. The levers are Tektro RL520's and they work great with BB7 mtn calipers. I plan on doing a little part swapping in the near future, but overall... it rides great!
    I Ride for Donuts
    Oct 2007
    I had a VERY similar set up for a long time... road bars on a mtb, Tektro's, mtn BB7's, trigger shifter, matte black everything.... I definitely approve
    Sep 2003
    Ten thumbs up.
    She's a beaut.
    Reputation: ThundaCrymz's Avatar
    Oct 2012
    That's one sexy ride you got there!
    Finally rolling on 29" x 2.0" Schwalbe Big Apples
    Reputation: shiggy's Avatar
    Dec 1998
    Nicely done.
    Jenson has the levers for ~$25, half the price of the identical Cane Creek model.
    mtbtires.com
