Results 1 to 36 of 36
    Jan 2011
    How to overcome dangerous routes?
    So I really want to start commuting to work. I've got a good bike to use, slicks to put on my bike and everything else in place (as far as I can plan ahead).
    However, I did a "test ride" on my day off to/from work on a Saturday (I work weekdays), and I realized there's a section of road that's about a mile long I'm simply NOT comfortable with at all. It's dangerous and the drivers are NOT bike conscious around there at all. I know I could take up an entire lane as a biker (it's a large 3-lane road), but I'm pretty sure I would get run down.
    I've looked and looked, and there are simply no other routes to/from work that I can take to avoid this road, unless it's on a more dangerous road.
    Any suggestions?
    My garage is a revolving door of bikes, wheelsets, & frames
    www.mtbdeals.com
    Get the brightest tail light you can find.
    Is there a sidewalk? I know sidewalk riding is frowned upon, but if it makes you feel safer for that portion, by all means use it.
    Jason
    Disclaimer: www.paramountsports.net
    Jan 2011
    Nope, no sidewalk, either. I would take that option (even if it's frowned upon), if it was available.
    Tail light option, yeah true, but I'm not sure that would make me entirely comfortable, either.
    www.mtbdeals.com
    Rolling
    Reputation: lidarman's Avatar
    How do you know this is dangerous? Is it your perception or do you have stats that support this?
    However, if you feel it's dangerous, that is not a good motivator for commuting.
    Maybe you should contact your local city or county folks and express your opinion. Also, can you shift your hours of commute to avoid peaks....in fact sometimes, riding during the peak rush hour can help since it slows down traffic in cases and reduces the risk for bike riders.
    weirdo
    Reputation: rodar y rodar's Avatar
    Tough choice. If you don`t feel safe, I`d say it isn`t worth it. All the suggestions sound worth a try, who knows- maybe something unexpected will work out. The only other one I have to add is to ask with local bike shops, cycling clubs, etc who are familiar with your situation. maybe there is some route option you`re over looking. In the end, it`s entirely your call.
    Single Speed Junkie
    Reputation: crux's Avatar
    Quote Originally Posted by sslikesnake
    I feel your pain there. My commute has a few hazardous sections, however if you can get creative and eliminate traffic by all means do so. Search google maps for possible paths or alternative routes. In doing this I found a route thru an arroyo nearly completely eliminating traffic. In the city it is deemed illegal to be in the arroyos, however after being struck by hostile drivers I'll take the lesser of two evils.
    Finding an alternate route seem like the only real solution.
    My commute used to be about 6.5 miles but the last 2 of that is on a narrow stretch of twisty two lane that heads out of town.
    I was not comfortable on that stretch.
    I actually added 3 miles to the ride by taking an alternate route to avoid the section.
    If that is not an option then maybe a combination of some suggestions above may help.
    Reputation: BrianMc's Avatar
    Your gut instinct is likely correct about flow. You can redrive it in the car to see if you can determine ways to reduce the danger. Being on edge through there is likely a goiod thing. I have a 2 -lane road marked for 30 drive often above 50 and had to keep upping the ante because the drivers were not looking for cyclists there. It is the only route out of where I live, and have to be more on the watch whenever I ride it. Oh and Saturday traffic here is clueless. Much worse than commuters who will begin to expect you if you hold to the same time. So you will only have non-locals or people who don't normally drive at that time finding you a novelty after a while.
    A situation you need to know about: A Louisville rider was killed 2 years ago on a 3 lane road taking the lane when an impatient driver decided to pass the truck that was in the center lane on the right. Then found the cyclist who was eclipsed by the box truck too late to stop. So traffic mix plays into this and stop and go traffic may be one of the safer times to do the stretch. If alongside a truck use your mirror and be ready to take to the verge to escape.
    Leopold Porkstacker posted his humongous ghetto tech tail light in the Another Commuting Thread About Lights which will likely prevent tailgating or singe paint. I find lights as bright as brake lights good enough, but you may want his 'take no prisoners' option to get them to brake first, figure it out later. Then you only need hope they aren't reading or typing text messages.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Check the web sites
    of your city, county or maybe state (if its a conventional state hwy) bike and ped advocacy organization for a bike route map of your city or county. There could be a parallel route of some sorts. Another possibility is too use a bus bridge for this segment of your commute. See if theres not a dirt shoulder that you could ride on. I do this on one street here b/c of the recessed drains and curbs.
    or go to google and punch in city of "your city here" bicycle route map. Something tell me that there
    Reputation: Marcster's Avatar
    Hi-Viz Safety vest?:
    Don't laugh, I wore a armored Hi-Viz motorcycle jacket when I rode my motorcycle... And I have a Hi-Viz vest for the bicycle (I haven't worn it yet though).
    If that't too dorky, how about a Hi-Viz Camelbak?:
    Reputation: OldHouseMan's Avatar
    You may want to give it a go during the week. I've found weekend traffic to be different than midweek traffic. even morning traffic can be different than afternoon traffic.
    I only ride bikes to fill the time when I'm not skiing.
    Bedwards Of The West
    Oct 2007
    If it's only a mile... is there a dirt option? Do you have any trail tools? A friend or two? A mile of rough singletrack could appear over night... stranger things have happened
    (no excuse for that either)
    Firstly of all post a goggle map of the area....not sure I buy no other options.
    Secondly if it is not safe do not ride it.
    Thirdly contact bike shops in that area.
    Even a 5 to 10 km detour is more than acceptable.
    Oct 2007
    True... is there a detour that adds a mile or so? nothing wrong with that.
    Reputation: newfangled's Avatar
    You could check www.bikely.com to see if anyone else has a route suggested for the area.
    But I'd also like to see the spot on googlemaps.
    Reputation: nachomc's Avatar
    What time of day will you be riding, and what is traffic like at that time? In the morning when I leave at 7, traffic is much lighter than at 8-830 when I hit the office and am back on roads again (I ride a MUP for most of my commute).
    :wq
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Another perfect location for the Kolelinia flying bike lane.
    http://gajitz.com/biking-with-the-bi...uspended-lane/
    Jan 2011
    Thanks for all the suggestions. I plan on getting a hi-viz vest, for sure. Here's a map of the "proposed" route mapped out.
    For those of you trying to help, the section of Josey Ln is the one that's bad--speed limit of 50mph, 6 lanes total with cars hitting up to 70mph (with lots of weaving) during morning commute--not stop & go at all, it's big enough that it's always "flowing". Every other route that I can find is either private roads w/o access (see Crider Rd & East Hill Park Rd) OR 2 or 4 lane roads w/o shoulders that are 50+ mph speed limits with very little patrolling (see Plano Pkwy & Parker Rd--both with lots of blind curves, too).
    My only hope is that they're connecting the 2 pieces of Windhaven Way sometime in the next year or so--then I'll be golden.
    Thanks again for all the suggestions--I'm definitely much more informed now!
    www.mtbdeals.com
    Yeah, I see what you mean. Have you tried using Windhaven Way and heading offroad across the tracks? If it's all been graded for new subdivisions then it should be pretty doable, so I'd probably give that a try at least once.
    Jan 2011
    Going offroad across the tracks is impassable because the tracks are fenced off, unfortunately.
    www.mtbdeals.com
    Yeah looks like you're sort of stuck.
    Is your life insurance policy current?
    :wq
    Jan 2011
    Life Insurance policy is current, but I don't think my wife wants to cash it in any time soon, as far as I know. I'll just wait for that road to be completed--now if only the city would get back to me about the timetable of it's completion!
    www.mtbdeals.com
    Are we there yet?
    Reputation: AlmostQuick's Avatar
    I have a 1 mile section on my commute that most would consider a "dangerous road", and I agreed. 4 lanes, 50 mph speed limit, lanes way too narrow to share and no ridable shoulders. Afraid to ride it on the bike, I first drove it several times in my car at 15 mph with my flashers on. No one ran into me, not even almost. Then I bucked up and rode it on the bike. I was nervous the first dozen times or so as most would be, but after nearly 1000 trips I can honestly say there have been no close calls.
    First, realize you need to be seen early, and seen as relevant. I always wear a hi-vis jacket / jersey or vest, and run at least one powerful blinky. Co-workers tell me they can see me a quarter mile away. You must take the lane completely (no half hearted partial attempts) to make it clear to motorists there will be no room to squeeze by. You will get some honks but in my experience the honkers almost always pass me safely.
    I also would not do this without a mirror. Being able to easily and continuously monitor overtaking traffic is very reassuring. You WILL see drivers moving over early, or slowing to your speed. Traffic is such on my road that I often end up with a car (or more) following me at my speed before I clear the section. The vast majority treat me with adequate care. Let us know how it goes.
    If you are comfortable with the windhaven parkway, you might try this alternative/detour which basically connects the two sections of windhaven parkway. For the portion along frontage road, you don't actually ride the road, ride the grass next to it (against traffic, but far enough off the road) You may need some moderate tread tires for this, but it looks like a safer route... presuming that windhaven parkway is better than the one you currently have mapped out.
    Maped out detour
    Looks like there is a decent shoulder on that road.
    And a variation of what Jonesy33 put.... http://maps.google.com/maps?f=d&sour...,0.105228&z=13
    Jan 2011
    Schmucker, I can't take Crider Rd--it's private and gated. Parker is a horribly windy 55mph 2 lane road with no shoulder--not going to do that one.
    Jonesy33, out of all the re-routes, your suggestion is the safest by far. I've even ridden that section of grass to check it out. On days where the soil is dry, this would work out fine (although I don't really prefer having to put moderate tread tires on just for a 1 mile section with 7 miles of road, but beggars can't be choosy, can we?). However, if that section got rained on at all, I would be in for a mud bath and that route would completely not be an option whatsoever.
    So, unless someone else has any great ideas (thanks for the all the help, everyone!), I'll hopefully hit the route Jonesy33 came up with sometime in the next week (if it dries out sufficiently for me to do so). I'll post an update when I do.
    www.mtbdeals.com
    Moderator Moderator
    Dec 2009
    I would try the gated road, if it's just a pipe gate. It looks like there is a gravel pit or something down there, they probably don't want people stealing gravel or dumping stuff but they may ignore a bike. The worst they can do is throw you off the property. Just watch out for the dump trucks!
    Here is my solution:
    Dr. Emmett Brown: "Roads? Where we're going, we don't need roads."
    Glad I could be of some help. In way of further advice, When I say moderate tread I'm talking about a more etched, or car-tire-like tread pattern... nothing knobby. With that kind of moderate tread it should have minimal impact on the road portion of your ride, but will enable basic dirt and grass riding... although mud-bath conditions would be a little much... Maybe you make that an excuse to drive on rainy days!
    Quote Originally Posted by mtbxplorer
    This is texas we're talking about... I'm bettting the "worst they can do" might involve fire arms...
    Jan 2011
    Jonesy33, I took your route suggestion this morning for the 1st time. That one section was pretty soft (we had some rain last night) and it kicked up some mud and left mud on my tires, but I'm glad I experimented with it. So now I know what "worst scenario" is when it comes to wetness. All-in-all, I really enjoyed commuting this morning.
    However, I will probably be trying one of the more "dangerous" routes on the way home, weather permitting.
    www.mtbdeals.com
    Reputation: dmboarder's Avatar
    Jan 2011
    Why not continue Memorial onto Lake Ridge? S on E Hill Park down to 121. You should only have a tiny bit of 121 service road to navigate and then take Old Denton south. How bad is the Frisco to Denton traffic in the morning? I figured that since they finally got 121 going so well, most people take that instead of the service road. It may take you a bit to cross 121, but that would take out most of the other hard part.
    Glad it worked out for you.... hope it does even better in dry weather.
    Jan 2011
    Quote Originally Posted by dmboarder
    Frisco to Denton traffic isn't that big, but crossing the service road, which still gets a fair amount of traffic, would be more dangerous w/o a light to help stop traffic.
    Also, E Hill Park south of Lake Ridge is government property, unfortunately, so that route is a no-go. I've thought about going south on Leora to the business park, but that still involves the service road, which I hate crossing.
    During my commute yesterday, I just found myself wishing & wishing for Windhaven to be finished. Once it's completed, I'll be in bike commuter heaven with an awesomely safe route! But until then, I just gotta be extra vigilant.
    www.mtbdeals.com
    Jan 2011
    Seems like that service road has a lot of traffic, but it seems to go in spurts. A bunch of cars and then a big gap. You might just have to wait a minute or two.
    Stay safe and have a good time commuting. You can look forward to the 110 degree days with 99% humidity this summer! hehe
