Results 1 to 21 of 21
    high volume, faster rolling tire, mostly for commuting?
    I'm looking for new rubber for my HT. It's primarily a pavement commuter, but I will be doing some rides on hardpack trails, and some playing around on stairs and small drops in the city.
    It should be high volume (2.3 or thereabouts), and roll somewhat easier than the Tioga Factory DH's that I have used in the past. Some degree of pinch flat resistance would be nice, which is why I used to use the Tiogas.
    I've been looking at some of the Schwalbes (Rocket Rob, Racing Ralph), but have no idea as to how good they are. Any other recommendations? They're going on Rhyno Lite wheels on a Specialized HT with a 100 mm travel fork. Rider weight is about 210 lbs + gear.
    the tires you mentioned wear out fast on trails and I'm pretty sure they would get shredded insanely fast on pavement.maybe run a high volume slick unless you're planning on hitting dirt and in that case swap out;it's what I do as I only have one bike for transport and for fun.it is a pain but it's better than wrecking my 80$ a pop ralphs.
    I turn wrenches at a not for profit bike shop in Denver called The Bike Depot
    Holy rollers?
    ACCESS Stealth 3.0 carbon 29'er
    GT-R Pro
    Surly 1x1
    Surly Disc Trucker
    I'm SUCH a square....
    Reputation: bigpedaler's Avatar
    Intense Micro Knobby. For commuting, I ran 'em @ 60psi (I'm a Clyde, 235#), and they rolled for two seasons (for me at the time, a 'season' was April-almost Xmas). On dirt, they're not great.
    Michelin Country Dry tires roll like semi-slicks, but have some bite in sketchy areas.
    A bike is the only drug with no bad side effects....
    Ex-Clydesdale
    Reputation: Dwayne's Avatar
    Jun 2005
    What percentage of your mileage will be on pavement vs trail? Do you have another dedicated trail bike?
    If your mileage is 95%+ on pavement, I would go with something like the Schwalbe Big Apples in 2.35". They'll handle city steps and drops without complaint, give you terrific puncture resistance, and lots of mileage, with the trade off that you won't shred trails like you would with a knobby (I'm assuming trails on the way to and from work?). That's my perspective. Anything with decent grip for the trails will have some sort of knobs, which won't last long on the street in comparison.
    '94 RSBikes Stampede (commuter), '05 Prophet, '09 Scattante XRL Team, '10 Slice 4
    Retired: 97 C-DaleSuper-V, 05 C-Dale R5000
    Reputation: OmaHaq's Avatar
    Jun 2010
    WTB Vulpine is what I run the most. Good on the street, and for hard pack / gravel conditions, perfectly fine.
    I've run Big Apples. They are heavy, but no doubt they are really solid! And not bad on hard pack XC to boot (not kidding). I put them on my father's bike when I went Vulpine.
    Specialized Control LK's are solid as well. They wear better than Big Apples or Vulpines on pavement and work better on the trail.
    - The only thing that keeps me on a bike is happiness.
    Bedwards Of The West
    Oct 2007
    I have dirt roads and trail options on my commute (20% Dirt mandatory), and I loved my Big Apples. They are very predictable on dirt.
    (no excuse for that either)
    PRETENDURO
    26"x2.5" Maxxis Hookworms. Much more predictable on dirt than Schwalbe Big Apples.
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
    Oct 2007
    ^^ I forgot about those. Always wanted to try them.
    Reputation: junior1210's Avatar
    I use these for my commutes. I believe these are made by Vee Rubber for Origin8. Weren't very much money (somewhere around $25-$30 each). Ride smooth and very tough, when used with thorn resistant tubes, no flats in almost 8 months.
    Attached Thumbnails Attached Thumbnails high volume, faster rolling tire, mostly for commuting?-sunp0031.jpg
    The ridiculousness of cycling clothes increase exponentially in relation to the distance from your bicycle.
    I run a small block 8 on the front of my multi purpose commuter.
    Intergalactic
    Reputation: firerescuefin's Avatar
    May 2013
    Drop the HT and get a CX bike. Much better suited for commuting
    Everyone's got a plan..until they get hit - MTyson
    Reputation: Spatialized's Avatar
    I'm on the fence between a narrow "performance" road type tire and bigger high volume tire: do the big apples roll fast? After running studs all winter going back to slicks was a nice, albeit rough ride as my speed jumped. If I put BAs on, will that speed drop again? Just curious.
    29er and 26er
    Mar 2012
    I put Big Apples on my XC Bike and it rolls nice on pavement and works great on dry dirt. When I get into the mud its a different story.
    To tell the truth, I really can't tell that much difference between my knobby tires and the big apples. I would assume the big apples roll better, but I sure can't tell any difference, but that's just me.
    CB of the East
    Reputation: bedwards1000's Avatar
    I'll throw my vote in for the Big Apples. They roll smooth on pavement, go great on gravel and do fine for light trail riding. They're fairly heavy and expensive but wear like iron.
    Oct 2007
    Quote Originally Posted by Spatialized View Post
    I noticed the heft of the BA's when accelerating, but once you get 'em up to speed, they carry momentum like nothing else. Fast rolling, and smoother than anything. I don't think you'll notice a drop in speed. Just acceleration.
    Reputation: AlexCuse's Avatar
    Re: high volume, faster rolling tire, mostly for commuting?
    Kenda K-rads have been great. Im using 1.9s but they make 2.3's too. Inverted tread pattern rolls great on road, good on dry singletrack, ok when wet but terrible in deeper mud (2.3 should float better over that stuff)
    Yeah I only carry cans cause I'm a weight weenie.
    Oct 2012
    Quote Originally Posted by CommuterBoy View Post
    My normal commuter is a Cross-Check, with 35mm Marathon Mondials on them. I usually average about 14mph on my commute. Last Thursday I had to pick up some stuff on my way home, so I took my 2.35" Big-Apple equipped Big Dummy.
    According to Strava, I averaged 13.8mph there and back. Considering that the Big Dummy weighs about a million times more than the cross-check, I think it's fair to say that the Big Apples won't slow you down much at all. Interestingly, I found that while the average speed was basically dead-on the cross-check was much more variable in speed, while the big dummy basically got up to speed and just kept going no matter what.
    Reputation: crossracer's Avatar
    I'm going to try a set of panaracer driver pros. I'm just going to commute once a week, long route, with maybe 15-20 miles of mtn biking in the middle of the commute.
    You got to find riding wherever you can.
    Bill
    Schwalbe Supermoto, preferably tubeless (for puncture protection and extra speed).
    Most likely the fastest rolling 26" tyre off-the-shelf.
    www.bartthebikeman.wordpress.com
    fast 26" road bike, shaven Racing Ralphs as road tyres, homemade "Paul thumbies"...
    Jun 2010
    WTB Nanos are pretty fast on pavement.
  1. high volume, fast rolling, primarily commuting tire?
    By bikedreamer in forum Wheels and Tires
    Last Post: 05-08-2013, 11:17 AM
  2. High Volume, fast rolling rear tire...
    By patrick2cents in forum Wheels and Tires
    Last Post: 04-30-2013, 03:45 PM
  3. Tire help. WTB High Volume low resistance
    By mjbrox in forum Wheels and Tires
    Last Post: 02-19-2013, 09:20 AM
  4. Replies: 6
    Last Post: 09-11-2012, 10:52 AM
  5. Pro`s and con of a front high volume tire
    By treesmasher in forum 29er Bikes
    Last Post: 12-21-2011, 01:23 AM
