Results 1 to 10 of 10
    Reputation: junior1210's Avatar
    Has Anybody Seen/Tried This?
    Brake Therapy Conversion Kit
    Just ran across this, rather interesting.
    The ridiculousness of cycling clothes increase exponentially in relation to the distance from your bicycle.
    That looks like a great solution!
    It does work, a might bit expensive, though. Good alternative to drum brakes (assuming your hub can fit one!) or changing your frame.
    Jan 2011
    It seems like the forces acting on the frame would be very different than a rim brake.
    As cool as that seems, I think I'd be fine with disc on the front and V-brake on the rear at least for commuting on the street. I guess the downside to that would be that the brakes would feel different.
    I've been riding with hydraulic in the front and cable pull on the rear. Seems to work fairly well. Only reason i did this was because I got tired of adjusting the pads all the time on the mechanical front brake.
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Quote Originally Posted by jseko View Post
    ...As cool as that seems, I think I'd be fine with disc on the front and V-brake on the rear at least for commuting on the street.
    That works for me for the commute and the trails.
    The more I research the more cool stuff I find. That isn't the only adapter I've found, although it seem to be the only one sold in the U.S. currently .
    since 4/10/2009
    Reputation: Harold's Avatar
    Specialized used to sell a "sharkfin" adapter that did the same thing.
    Born With A Tail
    Reputation: M-Train's Avatar
    I paid a frame builder $75 to weld a disc mount on a steel mountain bike frame. he also welded a tube between the seatstay and chainstay. I'm satisfied with the work and don't have to think about it anymore. I'm not saying it's better, but contraptions like that always seem pretty janky and add new weak points to the system. $240? new frame?
    Tequila tonight, tomorrow we ride!
    Quote Originally Posted by NateHawk View Post
    Yeah, A2Z used to have one as well, and much cheaper, but wouldn't work unless you had large flat dropouts.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Yes, I had one of those (sold by Hope with one of their calipers) in 1999-2000.
    It worked great. It bolted up in minutes.
