Results 1 to 31 of 31
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Guess what % of red light runners were cyclists?
    Reputation: BrianMc's Avatar
    ^ I don't run reds. One light I learned won't trigger for a bike. If going right I have an alternate route to avoid it. If left I wait the normal 1.5 minutes then is no vehicle arrives to trip it I turn left when traffic allows as drivers in Indiana can ignore a malfunctioning light. I have seen no cyclists run lights here, but many motorists who have. So I bet this varies a lot by city.
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    Auckland NZ though. I wonder what it is in the US?
    The pedals turn, not just the left one, but the right one too.
    since 4/10/2009
    Reputation: Harold's Avatar
    It definitely varies by city. Saw a lot of bikes running reds in san francisco. It seems uncommon in indianapolis. I do as brianmc does, but locally haven't had trouble with lights not triggering for my bike.
    Feb 2012
    The light coming out of my apartment complex won't trigger if you are turning left in a car if you don't position yourself correctly. A bike definitely won't do it.
    29er and 26er
    Mar 2012
    Quote Originally Posted by TenSpeed View Post
    This!
    There are a few lights that will not trigger when my bike is at the stop light in my area. At these I treat them like a stop sign during low traffic volume times. At high traffic volume times I avoid these intersections or walk my bike across at the cross walk.
    Reputation: ghettocruiser's Avatar
    So did they count motorists who accelerate through stale yellows?
    No? Because that's just the way people drive when their time is valuable...and it's not all dangerous, right, cause the light's only been red for like, a second or two... and those cars who have already started to turn left, they will never plow into those guys, of course.
    The above statements have not been evaluated by the Food and Drug Administration
    Reputation: newfangled's Avatar
    This is a tough one.
    I am a huge advocate of jay-walking. It is a stupid law, and it should broken whenever it is safe to do so. And when you're on a bike a lot of laws are also stupid and should be bent if not broken...but redlights aren't really one of them.
    This study was apparently at "major" intersections, so the excuse that the light wouldn't change probably doesn't fly. But like ghettocruiser says, the numbers could also definitely use some explaining.
    Does "running a red" include starting into the intersection early? Does it include making a right turn (on a red) without coming to a full stop first? I wouldn't be surprised that cyclists do both of those a lot more than drivers. I don't think many cyclists are blowing through stale yellows at 80kph though.
    ^^ I also wonder how many cyclists "ran" the light by still being in the intersection when the light went red. In Ohio and Indiana if you get into the intersection on the yellow, you are legal. (A bit dicey if a busy multilane intersection unless you are right in front of the last lane or two as the light changes. Busy intersections are often wide intersections. I have one like that where if I am 4th to 6th in line to cross, it will be close). Cross traffic in Indians must yield to traffic in the intersection or imminent on entering it. I think NY used to require that you were out of the intersection by the turning of the light to red. So some jurisdictions may vary. Since the lights are set for cars, the yellow light can be too short to get out of the intersection even if you entered at the same time as cars that did make it through. On another issue. I wonder if even half the drivers in this city actually stop for a right turn on red. This is a report on the survey and the author may have overlooked some of what the report included.
    since 4/10/2009
    A couple of intersections in Indy change from green to red so quickly that even if I am hammering, I have a hard time making it across before the yellow cycles completely through. One of them is right by my house. Busy but not huge street my house is on crosses a very major street that is about 7 lanes wide. If I enter the intersection when it is towards the end of the green, most of the time, it will be red before I'm completely through it.
    Thinking about it, the numbers are SO high that it almost has to be a methodology error.
    Aukland's bike modeshare is apparently 3%. Even if it's higher than that in the downtown, how likely is it that 60% of redlight violations come from such a small number of cyclists? To get that proportion either no drivers runs reds, or every single cyclist runs reds all the time. It's only a little bit more likely than if a study found that 60% of all redlight violations were by people named John.
    Moderator Moderator
    Dec 2009
    Reputation: pharmaboy's Avatar
    Auckland has red light cameras that photograph your rear number plate and send you a $200 fine. Bikes don't have rear number plates.
    What's the bet that this "study" is in fact pictures taken by the red light camera and a proportion of bikes to cars.
    Now if you are guaranteed a $200 ticket if you run the red in the car, do you think you will run it? If you are on a bike and have no chance of a photograph ticket, will it change your behaviour?
    As an aside these cameras are often put on city intersections that get blocked in heavy traffic to stop people from blocking and trying to get across, so perhaps what you have is cyclists essentially riding through a traffic jam intersection. The other thing that would be caught up is cyclists who start off a second before the green when it's safe in order to get into view of all traffic on the gutter side lane.
    Moderator Moderator
    Dec 2009
    They seem pretty concerned about red light running in general...
    Intersections
    I personally don't run reds, but many of the people that I've ridden with, as well as almost all of the "seasonal" cyclists in the area do.
    Yeah, it's illegal, bit if it's not enforced, why would they stop?
    Wait.
    They're counting right-on-reds (left down there) who don't come to a full stop as "running a red"?
    If that counts, every major intersection in this city would have thousands of infractions per hour. If I started coming to a full and complete stop to make a right-on-red, someone would plow into the back of me on day one.
    I don't think this "study" warrants further discussion.
    Quote Originally Posted by newfangled View Post
    So I am apparently psychic, because:
    [Cycle Action chairwoman Barbara Cuthbert] referred to a presentation by a senior Auckland Transport official which won an accolade at an engineering conference, noting many instances of red-light running by cyclists were left-hand turns or motivated by riders wanting to get a head-start on other vehicles for safety reasons.
    Reputation: pablobell's Avatar
    Oct 2013
    You are not allowed to turn on a red at all in NZ, so that is why it is counted.
    Worth pointing out is that a cyclist running a red runs the risk of getting themselves hurt while a driver running a red could very easily kill someone else.
    That's without the lower speed a cyclist travels at and the greater situational awareness a cyclist has.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Yeah i run some red lights, but what keeps me from running more is the fear of getting whacked by a car and getting seriously ****ed up as a result.
    Quote Originally Posted by pablobell View Post
    Gotcha.
    As a point of reference, Toronto motorists who (think they) can see nothing is coming slow down just enough for a right-on-red that they don't flip their car.
    I'd seriously need to be on my road bike in a dead sprint to right-on-red at the same speed as the average motorist in the outer suburbs.
    As for going through red lights, 0% of the car detectors see my bike on the way to work.
    If no cars are there to trigger it, I wait for a gap and do a right-on-red--> U-turn--> right turn.
    I even arm-signal this still-probably-illegal-alternative-maneuver, if I'm not using bar-mitts.
    Jan 2009
    this does vary a lot by city. I visited Philly this summer and stop signs everywhere seemed to be a mere suggestions to everyone on the road. cyclists NEVER stopped for anything- even little old ladies on cruisers would just amble their way through the busiest intersections while totally ignoring stop signs. here in Austin, I don't see it nearly as much.
    plus, no one has bothered to break down the kind of cyclists who are running the red lights. are they recreational, casual types? roadies? commuters? tri-dorks? from the photo they used, I am thinking tri-dork Stav*******s are to blame.
    Spherical Earther
    Reputation: Forster's Avatar
    Sep 2013
    I don't always run red lights, but when I do I prefer Dos Equis. My community has a rule that allows cyclist (and motorcyclist) to cross a red that won't change due to their low magnetic signature. On the flip side, if you're crossing a roadway while riding a hiking/cycling trail and a car runs the light or stop sign, it's the cyclists fault because they are operating a "vehicle" at a "pedestrian" crossing. My standard is to pull a wheel-stand until traffic clears then press on. I figure the best time to cross an intersection is when there is no traffic, not when you hope the traffic stops for the light. Seen the later scenario fail too many times.
    Reputation: s0ckeyeus's Avatar
    Here in KY, running reds is part of the culture with car drivers. Just this weekend I braked for a yellow light I wouldn't have made it through anyway, and the SUV behind me swerved around me to the right so he could make a left on red. A few weeks ago, something similar happened, but it was someone passing me on the left (going the wrong way) to make a right on red. Other drivers, who had a green light, had to stop for the dude. Crazy people!
    I'll fudge a stop sign now and then on my bike, but I stop for red lights.
    Bicyclochondriac.
    I am very surprised it was only 60%. I would have guessed 80-90%.
    I guess cars are more to just miss the yellow, whereas from what I see, bikers just treat the red light as a stop sign (or ignore it altogether).
    Feb 2013
    I mainly only run reds when it's one of those intersections that has an "all stop" mode for pedestrian crossing. if everyone is stopped for pedestrians, I will casually cross the intersection as well, being careful not to hit anyone or even get near anyone crossing in the crosswalk. I live in a small town though, in high traffic I try to behave as much like a motor vehicle as is practical and safe, including stopping at lights.
    "...when I stand to climb I'm like the Hulk rowing the USS Badass up the Kickass River."
    -michaelscott
    Feb 2014
    fits here
    Randomhead
    we had a similar conversation on our local bike advocacy email list. Interestingly, the people that lived near campus had an entirely different view of this than the people that lived a few miles further out. One of my pet peeves when I'm driving is the number of people that think they can just go right on red without worrying about oncoming traffic with the green. I don't see too many motorists actually go straight on red, but right turn on red has turned into a joke. It's not even an Idaho stop for these people, they just go if they think the oncoming traffic can stop in time. Since there is virtually no bicycle traffic, there is no way that the number of cyclists running lights even registers.
    Stop signs are an entirely differnt matter. Nobody stops for stop signs, and I've seen a couple of frat boys run stop signs at speed. It's surprising there aren't more fatal crashes given some of the speeders around here. On campus, cyclists are a plague. I get annoyed, most of it's just pointless. Of course, I see no reason to allow the campus to be overrun by cars either. Park at the periphery and ride a bus or something
    Quote Originally Posted by unterhausen View Post
    ... One of my pet peeves when I'm driving is the number of people that think they can just go right on red without worrying about oncoming traffic with the green. ... Nobody stops for stop signs, and I've seen a couple of frat boys run stop signs at speed.
    I have all but collected too many to count on my bumper for daring to stop at stop signs. Getting in the habit of not stopping is hazardous in other locales where they obey and enforce them. Crossing the street with a person looking left and rolling into the crosswalk is a contact sport here apparently. Who knew? Fortunately I am big enough they don't seem to want to anger me, so let me pass. The right turners with the light will run you down in the crosswalk and this is one of the main downtown intersections with some decent pedestrian traffic at times. So take care 'cause the other guy likely won't.
    Quote Originally Posted by BrianMc View Post
    When I'm walking in this scenario I'll almost always go behind the first car, even if it means hoping the snowbank and not using the crosswalk. The slightly added risk of getting squashed between 2 cars is way more than offset by the fact that the second car needs to look ahead to keep from running into the first car, whereas at the front of the line their heads are locked left.
  1. Hikers/runners complaining
    By bigbadwulff in forum General Discussion
    Last Post: 10-31-2012, 01:32 PM
  2. Any pavement runners on here?
    By SuperSlow35th in forum General Discussion
    Last Post: 03-12-2012, 05:18 PM
  3. Volunteer cyclists needed to lead marathon runners
    By Chopper in forum California - Socal
    Last Post: 01-10-2012, 03:38 PM
  4. Runners?
    By wanderingdave in forum General Discussion
    Last Post: 08-23-2011, 08:15 PM
  5. Runners?
    By Cajun Rich in forum General Discussion
    Last Post: 01-07-2011, 11:58 AM
