Results 1 to 33 of 33
    Drop bar comuter
    I was given a very old Lugged steel 12spd Trek road bike with down tube shifters and drop bars. I am looking to either get some different shifters as I can't get used to friction or even down tube for that matter or would it be better to just forgo trying to retain drop bars and go with a straight bar and a different style shifter for it.
    It has a Suntour XL RD and Suntour FD.
    I have searched but never really come up with anything very use fall.
    I'm not sure what you're looking for. When you say friction do you mean bar end? Have you considered STI/brifter style shifters? I'd guess you'd have to change most of your drivetrain to make them work.
    Yes, I am referring to down tube shifters style that are friction. I was looking to not replace everything as to that point I might as well buy a new bike.
    There's a style of shifter you can mount on the ends of your drop bars, like this:
    I would guess they'd be more versatile for use with what I'm guessing is 2x6 gearing.
    edit: after more research, there are also adapters that will let you mount your current downtube shifters either along the bar or at the bar end.
    Reputation: Joules's Avatar
    Quote Originally Posted by Sanath View Post
    That's going to be your only economical choice, but of course that isn't going to do anything about the friction shifting. Be glad you didn't start riding before the mid 80s, when down tube friction was all there was. Suntour isn't around any more, and indexed shifters that are compatible with your freewheel/derailleur never existed. There's a good chance you'd have to replace the rear hub as well.
    To convert to STI you'd be looking at $500 minimum, I'd guess. To go to shimano bar ends, probably $300-350. I don't think your frame is anything special that would be worth pouring money into to upgrade, you could get a complete bike with the shifters you want for what it would cost to convert.
    Reputation: newfangled's Avatar
    Sheldon Brown was a little less pessimistic than Joules:
    Freewheels (Thread on Type) for Bicycles from Harris Cyclery
    That includes:
    If your bike currently has a regular-spaced 6-speed freewheel, you can generally upgrade to 7-speed with little trouble. Since the sprockets are closer together on a 7-speed freewheel, the overall width is only very slightly wider than a regular-spaced 6-speed.
    Sun Tour indexed shifters pull less cable per shift than Shimano systems use. Thus, generally, you need to match Sun Tour indexed shifters with Sun Tour rear derailers.
    There's also Traditional Thread-on Freewheels which talks about upgrading older bikes to indexed.
    I don't know where you'd find any of that stuff new, but if there's a bike coop around they might have parts to try out.
    Reputation: BrianMc's Avatar
    Another option if it is the reach down to the down tube that bugs you, is to see if the local bike shop has an old set of Suntour friction stem mount shifters. That will bring them at least as close as bar end ones. Or something like this: IRD Silver SOS power ratchet Thumb shifters. Pauls let you mount shimano bar end shifters.
    That said I converted a 2 x 5 120 mm rear through 3 x 5, 3 x7, (cold set rear to 130 mm) finally 3 x 10. The last thing I did was go indexed with brifters. Others said I would take to them like a duck to water. I like them a lot but the friction Suntour stem mount on the 1 x 9 errand bike is fine (wider shifts so the delay is unimportant and you do get a feel fast for the shift points).
    OK so after I wrote this I went to a local shop that seems to deal with old items. They had old Shimano 105 downtube shifters that were indexed that seemd to fit on some retroshift shifters. I am going to give them a trey and see what happens. I am probably just being stubborn in trying to make this comfortable like a new style road bike.
    ^^ We need a picture. Some old road bikes are well worth the effort. If it fits you well and rides and handles well and makes you happy, to heck with what anyone else thinks. Nice classic workmanship is worth preserving. (Says this owner of 2 oldie but goodies.) Ask Rodar.
    weirdo
    Reputation: rodar y rodar's Avatar
    Quote Originally Posted by BrianMc View Post
    Haha! Rodar doesn`t have a big stash of classic bikes, but he is sort of stuck in the 90s
    Scribble, you do have some options for upgrading and keeping the dropbars. But before you jump into it, how is the fit with the bars it has now? If you feel good on the bike as it stands, remember that it`s probably going to be too cramped for you with a flat bar. On the other hand, if you`re a bit stretched, the flat bar might actually be helpful in that respect. I`ve gone the other way (drop bars on an mtb) a few times and it`s possible, but it does kind of open up a can of worms with no guarantees as to how the bike is going to handle for you afterwards.
    If keeping the drop bar, the cheapest way to indexed rear shifting with currently available new parts would be a set of 8-speed bar ends with a 7-speed freewheel and any Shimano RD (even an old mtb model) from the 90s on. You can redish the current wheel for 7-speed and Shimano 8-speed shifters index just fine with 7-speed rear (you`ll just have a ghost position below your gtranny gear). That still leaves you with friction shifting up front (all bar ends and downtube shifters have friction only in front), but you might find that you actually prefer it in front- I`m one of a large "club" who like rear indexing and still want friction in front. Or you can hound eBay for 6-speed indexed DT levers- they probably won`t be expensive. New 8-speeds are fairly cheap, too:
    Amazon.com: Shimano SL-BS64 Ultegra Bar End Shifter Set (8-Speed): Sports & Outdoors
    If you want to throw a little bit more cash into the pit (we won`t try to stop you!) you can go with a modern wheel and 8 to 11 speed cassette along with the new shifters and derailler.
    If you want both front and rear indexed, the only options are flat bar or brifters. You already know your options for flat bar shifter/derailler combos and I don`t know anything about the brifter options, so can`t help you there.
    I call for pics too! Even if your bike isn`t anywhere near top of the line, it`s going to be a beautiful, nice riding steel frame, hand built in Wisconsin. There really weren`t any crappy models.
    EDIT: Suntour "Symmetry" warning. For several years, ST made some DT shifters that mounted behind the tube rather than on the sides. They were called Symmetry and also had some kind of cam activated FD trim feature. If you have those, I don`t think you can use "regular" DT shifters, but bar ends are still possbile with clamp-on housing stops.
    Recalculating....
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Another option is moving the shifters to the stem
    <img src= http://farm3.static.flickr.com/2198/2215383403_50f3a03e13.jpg>
    Here is a pick how it looked when I got it minus the flat tires.
    When I get it back from the wheels being trued and I have the retroshift levers on I will take another pic of it.
    Looks like a new saddle is in the offing. Also brake pads go very hard pretty fast and work like greased lightning in the rain. Meaning they don't. On advice I bought a set of Cool Stops. I like the aluminum fixture ones that have replaceable pads. They were an incredible upgrade! Very linear and precise feeling.
    Re: Drop bar comuter
    Robbed a seat from the mountain bike I don't ride for the time being. I will keep that in mind about the pads.
    Sent from my Samsung galaxy S2
    weirdo
    Nice! Those brass-colored headbadges went away in the mid 80s. I can`t see yours clearly, but it looks like the third generation:
    Believe - Trek Bicycle
    What model is it? Hope you get a lot of enjoyable miles out of the critter when you get it set up to your liking.
    Recalculating....
    I am not sure on what model it is. Where you would have the frame size in a new bike it says 22 in large numbers.
    I just got finished installing Retro shift units with shimano 105 downtube index shifters and it is very nice to ride now. It looks like I will need to pick up a 7spd freewheel to finish this project off.
    weirdo
    The retroshift thing looks like good plan- would like to try one myself.
    Quote Originally Posted by scribble79 View Post
    Something else just occurred to me. I hadn`t thought about it, but there were 6 speed cassettes for a short time. Are you sure you have a freewheel? That`s the most probable scenario, but do check before you buy another to make sure you don`t get stuck with a part you can`t use.
    Sent from a nearby part of the Milky Way Galaxy
    Recalculating....
    I honestly don't have the tools to do either. The shop that is helping me mentioned freewheel when I was there yesterday. I am going back tomorrow and we will see what we have. I'm mainly going off Sheldon brown's page about the compatability using a suntour rd with shimano index shifters.
    I think I read Sheldon brown's page backwards. It says I can use a shimano rd with suntour 6apd shifters.
    I went the opposite. I went to shimano shifter with my suntour rd. It does shift gears but not smooth or correct at times.
    weirdo
    It was worth a shot. How many "speeds" are the 105 shifters you`re using? You may as well try them with the ST derailler and 7 speed cluster and see how it goes. Cross brand compatibility is complicated, sometimes with different spacings within the same brand/speed, and what some folks consider acceptable might be unacceptable for others. It`s easier to just try the combos you`re looking at and see how it does in practice rather than make your head spin reading all the theoretical possibilities. If all else fails, keep switching it all towards 7/8 speed Shimano and by the time you have it all Shimanized it`ll go. In the mean time, you can use the 105s in friction mode. It won`t take long to get te hang of it.
    Recalculating....
    The Shimano shifters are 6 spd S.I.S. I may give the cluster a try and may just go with the new RD as well so I can swap that out at home. I don't have the tools for Cassettes or freewheel swapping. I can get it to go through the gears just not smoothly.
    When I shift from the smallest gear up the shifter clicks and I watch the RD move but it just doesn't move enough till you go to the next gear up from there.
    weirdo
    Ah, for some reason I though you had picked up 7 or 8 speed shifters. In that case, the 7-speed freewheel is unlikely to work out, but you might end up needing a Shimano 6 in place of the ST. Do you have the derailller adjusted so the chain lines up nicely on one of the middle sprockets when the shifter is in its corresponding click? It sounds like you have a good suply of old stuff at the shop you`ve been going to- that should keep things from adding up too fast. Did you look for an old Shimano derailler?
    Recalculating....
    I may have not adjusted the rear derailleur properly. I really just grabbed the new cable threaded it through the housings and clamped it down. I am thinking from everything I have read I will need a Shimano RD either way. The vintage shop I have been visiting should have a used one that they can sell me. The shifters were from them as well and were used but are working fine at this time. I really don't care for friction shifting but with them on the retro shift units it might not be so bad.
    Well struck out at the shop I usually go to but am going to try a new one on the way home that thinks they may have something. I would just order a new unit if I new something that would work in its place.
    Any know a replacement in a shimano for a SUntour XL 6spd RD?
    weirdo
    Bummer. I`d try adjusting again to see if the ST one will work- start from the middle and work out. If that won`t cut it, stop barking up the Suntour tree unless your aim is to go entirely ST. Indexed stuff needs needs to be the same brand (or 3rd party made to match that brand), so what you need to match are the shifters. Something like this
    Amazon.com: Shimano Acera M360 7 and 8-Speed Rear Derailleur with SmartCage, Black: Sports & Outdoors
    would work, but it`ll look much nicer if you can dig up an older one from when they were still shiny and purdy... old Deore, RSX, Exage, 600, etc. The derailler is the next-to-last step. If it flies that way, you`re done. If it still doesn`t index, you need a Shimano compatible 6 speed freewheel (used Shimano or any currently manufactured brand) and it`ll all be singing the same tune. But first, make sure it isn`t just out of adjustment.
    Recalculating....
    Rodar I've been looking for good instructions for setting up the rd but not having much luck. I did find a old shimano acera derailer and installed it. I think either I am extremely out of adjustment or this unit is bad.
    weirdo
    There ya go! A nice shiny aluminum derailler that will index with your 105 shifters
    Now to see if it`ll work with the SunTour freewheel...
    Odd. I Googled up "rear derailler adjustment" and got hits for Park Tools, Sheldon Brown, plus some YouTube videos. Here`s my version:
    Flip the bike upside down (use 2 x 4 blocks or something under the bars so you don`t kink your brake cables) or hang it some way that lets you pedal with the rear wheel off the ground) and undo the cable so the derailler pulls all the way to the small sprocket.
    Adjust the "H" limit screw so that the chain rides well centered on the sprocket when you turn the pedals.
    Turn the pedals while you push the derailler with your hand all the way over to the big sprocket. If you can`t push it that far, back out the "L" limit screw until you can. Keep turning the pedals and drop the derailler so it goes all the way back to it`s natural position on the little sprocket.
    Screw the cable adjuster barrel all the way in, then back it out about 1.5 to 2 turns so that you know you`ll have adjustment in either direction.
    Check to see that your shifter is in "high gear" (6th), pull the cable tight with one hand and clamp it back in the derailler. If there`s a little bit of slack in the cable, take it out with the barrel adjuster- just take out the slack, don`t put it under tension.
    While turning the pedals, downshift 3 clicks. Squat directly behind the wheel and watch the chain- hopefully it will track nicely on the "3rd gear" sprocket without trying to hang up on the next bigger one or trying to drop back onto the next smaller.
    If it`s NOT riding centered on that sprocket, line it up by adjusting the barrel. Unscrew to move the chain towards the next bigger or screw in to let the chain move towards the next smaller sprocket. You`ll definitely be able to make it stay on that one sprocket even if the freewheel is incompatible with the rest of your drivetrain.
    While pedalling, shift up or down two clicks and see how it tracks. This is where compatibility comes into play. If you`re tracking correctly on that sprocket (two away from the one that you adjusted to), you`re golden. If it`s not riding exactly on that sprocket, you have a compatibility issue that MIGHT be able to live with. Readjust the cable tension (adjuster barrel) again in the new gear, then shift back to the "3rd gear" sprocket and see how it looks.
    Messed up? Adjust for that sprocket again, shift two click and try readjusting only part way to the "1st gear" or "5th gear" sprocket. Since you just found out that your freewheel spacing isn`t an exact match for your shifter and RD, your goal will be to find a happy medium that will hopefully work well enough. If you can get it to work in that sprocket AND a middle (3rd gear) sprocket, shift all the way to the opposite side of the cassette and see how it looks. Hopefully you`ll be able to make something go because even if you don`t have an EXACT match for your freewheel spacing, it`ll be pretty close- just a matter of finding out if it`s close enough. That`s all you can do with what you currently have. If it still doesn`t work, you`ll have to deal with friction mode until you get a Shimano (or similar) freewheel on there.
    Recalculating....
    Rodar, I appreceiate your quick run down. The lamens wording really helps me allot with understanding things. I know cars so much better. I will give it a try with what I have and if all else fails I will pick up that Shimano Freewheel from my main shop.
    I got the rear derailer adjusted correctly with the Suntour freewheel. It shifts decent and smooth enough to allow me to comfortable ride it.
    Hooray!
    What kind of shop has all of these old parts kicking around? Our local co-op has a ton of old stuff, but I'm sure if I went to any of the LBS they'd look at me like I was crazy.
    The 2 shops that had these items have been around for many years and don't throw anything away. Just in case. The one that had the shifters had 4, 8' tall shelves full of old parts all boxed in a certain catagory.
    That's good stuff. One of our oldest shops (I think they've been around for 80 years or so) basically laughed at me when I wanted to get a cup&cone bottombracket adjusted.
    This is the shop that sold me the shifters and helped me get this project going. They are an eclectic group.
    http://revolutioncycles.net/
  1. Drop out help!
    By scribble79 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-03-2012, 02:56 PM
  2. Fully Fixed Comuter
    By Crispy01 in forum Frame Building
    Last Post: 09-24-2012, 08:50 PM
  3. Chain drop drop off and misalignment a norm?
    By boardrider02 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-03-2012, 01:20 PM
  4. my new comuter
    By JUNGLEKID5 in forum Commuting
    Last Post: 02-24-2012, 06:46 PM
  5. XM-L P60 drop-ins
    By CathastrophiX in forum Lights and Night Riding
    Last Post: 02-18-2011, 07:18 PM
