    Sep 2013
    Caution;  Merge;  Workers Ahead! Do I hae the right tires??
    Hello, For my front tire I have the Hutchinson scorpion tire and it seems to be wearing pretty fast for a fornt tire, I have seen this on many other threads but was wondering if I have a hard rubber tire at back and soft rubber tire up front will it get better grip or should I go with both scorpion tires since the grip is phenomenal
    Unhinged Aussie on a 29er
    Reputation: hunter006's Avatar
    Your rear tire will wear faster than your front tire under most circumstances, because it is the load bearing tire. If your front tire is wearing really fast, I wouldn't buy the same one for the rear unless you want to replace it frequently.
    FWIW, I used to run a grippy front tire and a longer lasting rear tire, e.g. Vittoria Zaffiro or Rubino front tire, and a Continental Gatorskin touring tire for the rear. The Zaffiro would typically still have a lot of life left when the Gatorskin was worn out after 6000 mi.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    tires with higher tpi and better casings/ sidewalls will on average wear better. What size wheels are you rolling on? Touring/commuting and some messenger tires are a good bet.
    Sep 2013
    I am running 26 inch tires. I am running the tires at 70 psi, (sais on the sidewall that I can) and was hoping to see if this would make it wear slower than 50 psi. its still wearintg fast, probably because I am going 30-40 miles an hour down hill, does this affect it?? should I go slower?????
  1. Switching from off road tires to street tires...suggestions?
    By bpreachers in forum 29er Components
    Last Post: 04-13-2013, 10:35 PM
  2. turning your tires into snow/ice studded tires.
    By Clozedeyez20 in forum Wheels and Tires
    Last Post: 02-23-2013, 11:38 AM
  3. Question about Schwalbe tires to replace stock tires
    By bosco0633 in forum 29er Components
    Last Post: 03-06-2012, 08:40 AM
  4. Replies: 4
    Last Post: 10-07-2011, 05:04 PM
  5. Wider tires, less rolling resistance, what about taller tires
    By HighLife420 in forum Wheels and Tires
    Last Post: 06-01-2011, 06:23 PM
