Hello,
Was curious as to who might have some experience with these lights. I basically need a commuter light for roads in half lit streets. Reason why I chose these 2 is because they are both 1 watt outputs.
The cateye uses 4 AA batteries and gives about 60 hours of run time. The blaze uses 2 AA batteries and gives 7 hrs of runtime in high mode, 14 hrs in low, and 20 hrs in flashing.
I think the mounting bracket on the blaze is slightly better with the quickcam bracket mounts. Not sure about what type of mount the cateye uses.
Does anyone know out of these 2 which would be the brighter one? Both uses a single LED bulb. Any input will be greatly appreciated. Thank you!
