Results 1 to 7 of 7
    Bedwards Of The West
    Oct 2007
    Anyone else using disc brake tabs for fender mounts AND running disc brakes?
    I can obviously see the potential for a problem, but I haven't had any issues...
    I was forced to do this in the rear when I started using my BOB trailer... the fender supports, which already had to be bent to clear the disc brake, got in the way of the fork of the trailer...there's a lot going on right there with discs, fenders, and a trailer. So I shortened the fender supports and used the actual brake caliper mounting bolt to secure both the brake and the fender. You can sort of see what I did in this picture:
    now my homemade tab on the front of the bike has broken (rickety hose-clamp situation) and I'm thinking I'll do the same thing with the disc caliper mount up front. I haven't had any issues with the back.
    Thoughts?
    (no excuse for that either)
    Air Pirate
    Reputation: Bokchoicowboy's Avatar
    I don't have a trailer, but I do run discs and fenders together. To avoid problems that might arise by using the same hole to mount the fender stay and brake caliper I went with the Planet Bike Speedez ATB fenders. These things use a rubber mount with rubber straps to attach to the stays. You can slide the fender stays in their mounts and even bend them to adjust the fit. I even attached them to a front suspension fork, placing the attachment point above the brake caliper.
    I have had no problem with the rubber mounting system moving around or failing. I am pretty sure you can use zip-ties instead of the rubber straps if you wanted, but I have had no need yet.
    "You're messing with my zen thing, man!"
    Oct 2007
    ^^ Do they make those in a 29er version? I'm running 29x2.35 Big Apples... The Planet Bike Cascadia fender is the best full covererage option I've found for these monsters.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Bokchoicowboy View Post
    I've got a friend who used these fenders on an old Cannondale roadie that had odd rear dropouts that didn't fit regular fenders. They worked well until he was hit by a car and the C'dale frame broke.
    Did I catch a niner+?
    I have to on my rear (Vassago Fisticuff). I think the tab will be fine I would maybe just get a stronger bolt (steel).
    I have done it on several bikes. Works just fine. I even mounted a rack with one.
    Oct 2007
    Good deal...thanks guys. I have had it that way in the rear most of the summer...no issues yet but I'm nervous messing with the caliper mounting situation. I guess the fender strut just acts like a big fat washer...shouldn't take any strength away from the caliper/tab relationship. I might go for longer bolts at least.
  1. Replies: 5
    Last Post: 10-04-2008, 09:01 AM
  2. Disc brake mount tabs
    By ysrchris in forum Brake Time
    Last Post: 07-18-2008, 06:14 AM
  3. Disc Brake Tabs for Traveling
    By SuperKat in forum Brake Time
    Last Post: 02-19-2008, 10:46 PM
  4. disc brake tabs
    By bnelson in forum General Discussion
    Last Post: 08-24-2007, 02:48 PM
  5. Adding Disc brake tabs
    By Dirteye in forum Brake Time
    Last Post: 05-12-2004, 01:06 PM
