    Bicyclochondriac.
    Actual widths of Schwalbe Marathon Supreme 32c and 35c
    As the title suggests, I am looking for some real world width measurements for the Schwalbe Marathon Supreme in the 32c and 35c (also labeled as 37?) sizes. If you could tell me what rim the measurement was taken on, that would be great.
    Dec 2008
    35c=
    Widest point 34.3mm, Dtswiss X 470 XC 29" Disc.
    Bicyclochondriac.
    Quote Originally Posted by irrah
    35c=
    Thanks for the info, it helps a lot. I looks like the 35c is the one I want
    Bicyclochondriac.
    I got the 35 x 700 size.
    After a few weeks mounted, on a CXP21 rim (20mm outer width), @ 70psi, they measure ~ 34.8mm.
