Results 1 to 36 of 36
    Reputation: SSSasky's Avatar
    1x9 commuter gearing
    Howdy folks.
    I just built up my new commuter, and I'm curious about what folks here use for gearing. Mine is currently set up 1x9, with a 46t chainring, and a wide range MTB rear (SLX 11-28, I think). The gearing works well enough for me, but I find I rarely use the lower ranges available and sometimes feel like I am missing an 'in-between' ratio in the higher cogs where there is a more than one-tooth difference cog to cog.
    So I'm thinking of switching to a 42 (which I already have) or 44 tooth chainring, and a road cassette with 1-tooth difference cogs.
    What are you guys running?
    Pic:
    Natural Born Killer
    Reputation: nemhed's Avatar
    May 2010
    My current commuter has multiple roles including bikepacking and backup/loaner mtb so I'm still running fat(2.2") tires and don't really feel much of a need for speed. I've got a fairly standard 1x9 setup with 32 tooth chainring and 11-32 cassette. My next build will be a little more cyclo-cross inspired which will also see commuter duties. I'll be running a 42 tooth chainring with a 11-34 cassette on it. That should cover all my needs(I really like a single chainring). Nice bike btw!
    Quote Originally Posted by Skrufryder View Post
    Silly rabbit Jack Daniel drinking donkey kissing caterpiller
    Reputation: BrianMc's Avatar
    Commuter-errand-bike path bike is 42 x 11-34. With carriers full of a load of groceries or farmer's market produce, it is about 100 pounds. In commute mode, about 28 plus briefcase or PC bag. The upright position and these loads make for work into the wind.
    Even with careful load placement, a full load can make it tricky to handle, so I like the simplicity of the single shifter with more useful ratios than a 2 x 7.
    Bedwards Of The West
    Oct 2007
    I'm running 11-34 out back and a 50 up front. I have a road double with a 34 tooth small ring, but no front derailleur. I leave it in the 50 tooth front for the commute. It's made me a better climber, that's for sure.
    (no excuse for that either)
    Have experienced chain fall off? I took my front derailleur off to make 1x8 but chain has fell off many times. I tried shorten the chain by removing a couple of links but that didn't help. I am wondering if there is any solution for it. Thank you.
    Quote Originally Posted by ttper
    I have used a Jump Stop (by N-Gear, but there are other brands and designs like the 'dog fang' from third-eye) and a bash guard before. That gives you protection from chain jump to the inside and the outside. A nice "channel", if you will, with your chainring in the center. Not as clean looking as just the single ring, but there is basically no way for the chain to derail up front.
    For me, riding bikes is not a hobby, it is a way of life.
    http://natureofmtness.blogspot.com
    Assuming your chainwheel is not bent and runs true.
    Assuming there are NO even slightly damaged (bent) links in the chain. Bent chain = nightmare.
    Assuming you are using the inner of a double, or center front of a triple. (Not a single crankwheel set).
    You don't need as long a chain if you aren't changing chainrings anymore. The RD takeup should keep good tension. If you are using the largest chianwheel, and it is the same BCD (Bolt Center Diameter) as the next, you could move it inboard for a better average chainline. A second one (preferably with more teeth = bigger diameter) can be detoothed (used ones with bent teeth from your LBS can be cheap) and put outboard where the other one was as a chain guard (so you can keep the same bolts, otherwise, you may need some hardware to drop to a single chainwheel). The RD take up should keep enough tension. You can also fit the old FD as a chain guide without cable just stopped in place with the set screws though you may need longer ones to lock it.
    Fat-tired Roadie
    Nov 2007
    My current is a 2x6 setup, with a range from 32.5-91.7 gear inches. I actually do use that entire range, but I'm out at the boundaries only on the steepest pitches on my commute - I don't feel like I'd be too crippled by losing the most extreme ratios. Why am I posting this in a 1x9 thread? Well, with an 11-34 cassette instead of a 14-28 freewheel, I'd actually get a bigger range doing 1x9. With a 41t (yeah, I know they're rare - it's in between 34 and 48, my current rings) chainwheel, I'd get a range of 32.3 - 99.7. I could get a pretty near match to my current with a 38t ring and 11-32 cassette, 31.8 - 92.4 gear inches.
    OP, I highly encourage you to either visit the gear ratios calculator on Sheldon Brown, or make a spreadsheet. With a little tinkering, you can figure out a combination that will give you the boundary ratios you want. Since you want smaller jumps, narrowing your range like that should take care of you.
    http://www.sheldonbrown.com/gears/
    Bicyclochondriac.
    I run a 1x8 on my commuter. 40 ring, 12-32 cassette, 26" wheels. It seems just about right, though if I need to replace the drivetrain at any point I will go with an 11-34 cassette (I guess 9-speed). I find the gear ratio spacing plenty tight, never caught between gears.
    It is hilly around here and with a bit of a load (I have racks front and rear) I would not want to loose my low gear. I sometimes spin out in the highest gear on downhills, but I don't really care.
    Quote Originally Posted by AndrwSwitch
    My current is a 2x6 setup,...32.5-91.7 gear inches. ...an 11-34 cassette ...doing 1x9. With a 41t ...a range of 32.3 - 99.7. I could get a pretty near match to my current with a 38t ring and 11-32 cassette, 31.8 - 92.4 gear inches.
    My bike was a 27" 13-28 and 52/42, 2 x 7, 40.5-110.1, ratio range: 2.72. Now a 700C with fatter tires (same height) 11-34 x 42 1 x 9 = 33.4-103.1, ratio range: 3.09. (outside chainwheel is a chain guard.) If I don't go NuVinci 360 IGH (ratio range 3.6), when the cassette is worn I will go 12-36 and a 41 (the smallest chainwheel for a 144 BCD crankset) for 30.8-92.3, ratio range: 3.00. A 10% lower gear for when it is loaded with groceries and I am uphill into the wind would be nice and a 10% lower top will get a bit more play when empty or downhill with the wind as the erect position is non aero but I make a good sail. The single shifter when loaded with groceries is very nice.
    Frys With That, Please
    Reputation: cda 455's Avatar
    Aug 2010
    Quote Originally Posted by BrianMc
    Very interesting !
    2012 Cannondale Trail SL 29ER 4
    1994 Cannondale Super V 1000
    1996 Cannondale F500 rigid-fork 69'er
    Motiv 26'er
    Since someone might search this thread converting from 2 x something to 1 x 9, and I brought it up in another post, here are two links to converting double cranksets to single (inboard) and converting outer chainrings to chainguards in same thread:
    What would you do?
    What would you do?
    Mine cost only the materials used to convert and polish it. Good deal. Works great and looks better! Oops my prides's showing.
    Jan 2011
    Wow...I'm surprised many of you can get away with only one chain ring. The final climb on my commute is kicking my ass even using my 26T chain ring and 32T cog. The only thing I'm carrying is maybe my lunch and lock in a backpack. I have triple chain rings at the moment and for almost everything else, I'm using the 36T chain ring.
    The last 0.5 mi of my commute involves climbing about 300ft. What are your climbs like?
    Fat-tired Roadie
    Nov 2007
    I'd say my hardest climb is that tall, but about twice as long. I alternate between spinning my 34/28 ratio and getting out of the saddle and climbing. It's actually the reason I lowered my gearing and bought a set of panniers - doing it in 40/28 with text books on my back blew.
    From your other thread, it sounds like you're just starting to ride regularly. So there are some things you can do to make it easier. Make sure your bike fits you right. There're a million resources on this topic, most are okay starting points, and none are written in stone. So pick one, go with it, and then experiment.
    Learn to pedal. It's easier with toe clips or clipless pedals, but someone who already pedals efficiently can do pretty well on flat pedals. REI has something about it somewhere on their web site. The basic idea is to pedal fast enough that rather than having distinct strokes, you're spinning your crank fairly smoothly. You can actually get some real use out of your low gears that way.
    Learn to climb out of the saddle. In San Francisco, the choice is sometimes between standing and climbing or pedaling extremely inefficiently and maybe buggering up your knees.
    And finally, Rule #5.
    Don't give into the temptation to buy smaller chain rings or a new crank, at least for another two weeks or so after learning to pedal well sitting and standing.
    Jan 2011
    At the moment, I don't intent to modify my bike aside maybe a rack and fenders.
    As much as the hill is kicking my butt, a 3 to 5 minute break does wonders.
    I'm not sure what you mean by having distinct strokes rather than pedaling smoothly. Although I have flat pedals, I like the pedals that came on the bike. They are not like regular flat pedals that have a H-shape interior section that attaches to the crank and then a separate U-shape piece that fits around it.
    They are more like a 1 piece design with the spindle going down the center and the surface has lots of little nubs. My sneakers and boots work very well on the pedals. They look similar to this one from performance:
    The Brutally Handsome
    Reputation: Sizzler's Avatar
    40 x 12-34
    Aug 2010
    Very good tips!
    Since I pulled my MTB out of storage last June ('10) I've been fitting my MTB via multiple stem lengths, various rise/angles from stems and handle bars, seat adjustments, etc. I've got my fit close to ideal.
    Before I modify or swap my triple, I want to lose my remaining 40lbs of fat. I think getting rid of unnecessary body weight will help with my climbing ability .
    I'm going to build a road bike with a Salsa Vaya Ti frame. I've been debating whether I should get a triple or a double crankset. Hopefully I'll have my answer by Summer, which is when I expect to lose the rest of my weight. Once I get down to 180lbs. (And have four more months of riding/conditioning) if I still feel I need a triple then I think that will be my route I'll take.
    There's a hill in my town that Olympic gold medalist Kristin Armstrong used to train on. It's 16 miles long with an average grade of 5% with plenty of 15.4% grades and an elevation gain of 3836ft. I want to be able to ride all the way up it without stopping. Do you think I can eventually ride up said hill with a double crankset or stick with a triple?
    Motiv 26'er
    Jan 2011
    If you train long enough and hard enough, I think you could do it with 52-9 combination!
    On a more serious note, you may want to keep the triple for now and then change out the parts as you get stronger.
    Quote Originally Posted by cda 455
    Sounds about like what an average day ride into the mountains would be like near my old stomping grounds in Northern AZ. Totally doable on a 40-ish inch gear singlespeed, Funny thing, you only find yourself "needing" the triple when it is available, You can really surprise yourself with what you can do with what you have... I used to haul my 2 year old up into the mountains (in his 2 wheel trailer) up 2000 ft. climbs all the time. Geared low? Sure. "Needed" a triple or even a double? Nope.
    I weigh about 180 geared up. Now, granted, this is rec/training ONLY. I don't race, so if yo want to be competitive, I have no idea what you would "need." Depends on the competition, I guess.
    Reputation: Schultz29's Avatar
    I run a 36t up front and an 11-34 in the rear. However, I ride my urban bike on trails as much as the streets. I'm usually able to keep pace with strong riders on road bikes as long as we're not on the flats for too long. Sometimes I wish for a 38t but I'm afraid I'd loose some climbing ability?
    Fat-tired Roadie
    Nov 2007
    Salsa's Vaya is, to my eye, a pretty sweet randonneur/touring bike. I haven't done any real laden touring, but from riding around with loads strapped to my bike for one reason or another, I can say that I really like low gears for that - like a triple.
    If you're not strapping anything to it and don't have anything against compact doubles, though, that 34t ring is already pretty small. I don't know that I'd bother with a triple if I was just going to use the stock 30t small ring, now that I've got some saddle time with a 34. (Often loaded, but for a short trip.) OTOH, the small ring on a triple can be smaller - one relatively uncommon standard goes as low as 20t. Which is very different.
    Schultz - the 38t ring would make a bigger difference to your high end than your low end. Compare the 38/11 and 38/34 with 36/11 and 36/34 with a spreadsheet or a calculator and you'll see what I mean.
    Oct 2007
    Assuming this was directed at me?...
    I throw the chain to the outside maybe once every 200 miles... it's always when I'm shifting up (inner to outer in rear), and usually when I'm popping by several gears at once. I have bar end shifters, and if I throw it through several gears and keep pedaling hard, I can accentuate the problem. You get a bit of a 'whip' action in the chain that throws it to the outside. Knowing that the situation exists, I can prevent it by shifting smoothly, while easing off of the gas a bit while I shift. I could completely eliminate it from ever happening if I always shifted up while pedaling very slowly, not engaging the hub. But I like to push my luck
    I think setting up chainline very carefully helps too...I am running the big outer ring as far inboard as humanly possible...trying to get it centered on the rear hub, which is pretty much impossible. But eliminate as many spacers as you can without getting contact with the big ring and your chainstay. Brian mentioned using the inner set of bolts if you can...some cranksets also let you mount it on the inside of the tabs rather than the outside if you eliminate the middle chainring. I'm still cross-chaining the heck out of it when I'm in the big gear on the cassette, but I still get 4k miles out of a chain. No complaints.
    I wouldn't do it on a race bike, but it's totally worth it for the simplicity for me on the commuter.
    Aug 2010
    Since it does have pannier capability front and rear, I might take advantage of it. For commuting and back country fire-road trips. For group rides (road) I'll just unbolt and go!
    The biggest reason why I like the frame is its' rather tall stack measurement.
    Motiv 26'er
    Reputation: CabezaShok's Avatar
    Oct 2007
    For a 1X9 commuter , does anyone know if there is any advantage to using a roadie RD versus a MTB long cage RD?
    Jan 2009
    IBIS MOJO CARBON - 1x9 setup, 11x34 rear cog w/ 36t front chainring... works perfect for my 2+mile climbs to the top of town... need to find a chain guide since the chain came off 3x yesterday and i cant use the simpel chain guides now with my frame design...
    Quote Originally Posted by CabezaShok
    Using a MTN Shimano Deore that can handle a 12-36 on a road bike. Not sure whether a road RD will.
    Bicyclochondriac.
    The issue is that the road RD will have a smaller maximum cog size than a mtb RD (which is a separate issue than the cage length). So, it depends on how big your biggest cog is.
    A short cage (or med or long) of either (road or mtb) will work in terms of having the capacity to take up the chain on a 1x9. The biggest capacity you would possibly need would be 24t (for a 12-36 cassette and single ring).
    Take up capacity is independent of max cpg size for at least one mfr. YMMV
    On my 3 x 10 bike, I have a long cage Campagnolo Centaur with 28 link capacity (handles 13-29 with 30-42-53) BUT it won't feed a cog larger than 32 with the standard mounting. It doesn't like a 30 all that much. Cutting the mount off and brazing it lower (check out Yellow Jersey if you wish to see an example on a touring bike) will allow an 11-34 cassette with a Campy long cage. A tad extreme to be called an adjustment.
    I don't know if some of the Shimano upper end road RDs may not have the same issue, it would not surprise me. I'd guess that would be the info the poster is looking for. I decided a MTN would work up to 36, so MTN RD it was for the road bike 1 x 9.
    I had a Dura Ace RD in the parts box that I used when building up my Yetimooter. I therefore went with a shimano D/A road cluster (so as not to overstress the short cage) and a Dura Ace barcon shifter on a thumbie mount. Keeping all drivetrain components consistent makes for a pretty reliable drivetrain on the road. I've only thrown the chain off the front while jumbling through rocky trails at speed.
    The added plus to the smaller cage RD is that the whole package is tighter - less derailleur "flap", so there's less chance of dropping a chain. I still want to get a chain keeper on the front, though. I like the tight ratio for road riding.
    The minus of the road cluster is of course small cogs - and since I want the bike to be somewhat offroad capable, I'm running a pretty small ring up front. I'll verify that tooth number when I get home if you need.
    I'm running 44t with 11-26t 9spd. It has been pretty good, with a wide range for loads or cruising at speed. I have a bit heavy bike though, 30lbs with everything minus cargo bag. I wouldn't want any lower gears than that unless there was snow. Fairly flat where I am though.
    This wonderful part solved all my chain drop problems though when switching to a single chainring.
    http://www.paulcomp.com/ckclamp.html
    Bicyclochondriac.
    Quote Originally Posted by jeeves
    Just to be clear, running a larger range cassette in the rear would have been zero problem in terms of the cage length. Since you are running a single ring up front, that gives you a lot of extra unused capacity. The problem you might run into with an mtb cassette (with some larger cogs) has to do with the max cog size of the road RD, not the tooth capacity of the cage, and you would likely have the same issue with a long cage road RD.
    What It Be ?
    Reputation: ChrisJ's Avatar
    Aug 2005
    I run a 32 up front with a MRP 1x chainguide and a 11/27 cassette. Its my crossbike. 1x9 works for me. I commute out of NW DC into Virginia.
    I have a similar setup to ChrisJ:
    36t front ring, MRP 1.x, 11-28 cassette.
    On an old rigid Rockhopper. Geared a little low, but the bike was put together using spare parts and I didn't have a bigger ring sitting around.
    Just to add to the general info...
    I'm running a 1X8 commuter. Single-speed 42 tooth up fornt with a bash-guard, 11-28 road cassette on the rear. Not a chain-drop yet to either side after several hundred kilometers on this set-up. I do have to stand in the pedals especially when weighted down, and I've still had no problems with drops.
    Running a MTB 1X9. 33 single-speed up front with a bash guard, 9-speed 12-34 in back. Three drops to the inside in about 10 hours of riding. Not terrible, but enough that I'm going to try a paul components chain keeper instead of relying on the bashguard. Icould get by with the bashguard setup and just accept the occasional drop, but this is the bike I intend to race this season.
    Jan 2009
    i have an old hybrid with a 39x12-28 cassette. i used an old 105 crank with 39/52 chainrings and removed the big ring, then put a 12-28 eight-speed cassette on the bike with a short-cage derailleur. there are some decent hills in ATL here, so it handles most of that just fine. extended climbs are a challenge, but manageable.
    Just started my commuting. Right now it is on the only bike I own, A Fisher Hi Fi 29er. I have it set up 1x9 for racing in Texas and I leave it that way for my commuting. It is 51 miles round trip but the fun part is that it is part concrete and part trail that goes for about 8 miles along my route.
    34 front 11-34 in the back.
