Results 1 to 36 of 36
    Reputation: JonnySpitz's Avatar
    What are the loudest brakes for the front range?
    Mine! Avid Juicy 7, tried organic pads and regular. The brake and rotors are about 3 years old. They get real noisy toward the bottom of trails like Deer Creek, Chimney Gulch, Mt. Falcon, etc... when they heat up. Are my rotors too old? Are avid pads known for this? Has all the PBR made me too fat for my brakes? The problem has become worse this year, even with replacement pads.
    The one upside is that the organics and the other pads make two different tones so I can harmonize when I come down the hill, having organic in the front and the other ones in the back.
    my juicy 5's do the same thing.
    "Oldfart from Wayback"
    Reputation: onbelaydave's Avatar
    Juicy 5's here and only the rear makes noise. Front is quiet as can be.
    Juicy 7 here sound like a dieing ostrage when hot. Not to mention this year am getting a nice vibration to go along with it. I have tried everyting aswell. Maby time for an upgrade.
    Reputation: Kaba Klaus's Avatar
    What rotor size are you using?
    My wife runs Avid Jucy 7" front and rear. No sound unless wet.
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
    3nf
    3nf is offline
    Aphonopelma Coloradanum
    Reputation: 3nf's Avatar
    I like to think that my Juicy 5s help to avoid trail conflict by warning other trail users of my approach well in advance.
    Mine can be quieted down somewhat by chamfering the pads and shimming the calipers away from the axles a little. I have also found that Hayes rotors work a little better than the wavy Avid rotors.
    Oh, So Interesting!
    Reputation: davec113's Avatar
    You use brakes?
    I'm with stupid
    Reputation: hitechredneck's Avatar
    juicy 7 when they are not aligned right or when wet or when hot. yep about sums it up. lol
    Stiff yet compliant
    Reputation: Moustache rider's Avatar
    When your brakes make noise you are supposed to oil them. Makes them quiet as can be.
    Tribe Member
    Reputation: yetirich's Avatar
    my xtr brakes with metallic pads, 160mm rotors. they will scare wildlife off the trail.
    Proud Tribe member since 1992 - looking for better singletrack to be ridden year round
    ride
    Reputation: ignazjr's Avatar
    Do a search on the brake forum for that Juicy squeal. Not all of them do it but certain frame/brake combos will. Avid makes a solid rotor that usually takes care of it. Your LBS can order it for you.
    yetirich - in each caliper run 1 organic pad and 1 metallic pad. Works just as good and no noise. You could go all organic pads for no noise as well but it won't work as well.
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    Avid BB7's. Many combos of rotors and pads (though I didn't go the organic pad route yet), plus a ton of adjustments. What worked for me:
    Stop the vibration - Pull the pads, put a dab of HIGH TEMP grease on the backside, between the pad and caliper - NOT THE BRAKE SURFACE. Or, as an experiment, put a single thin strip of electrical tape on the back of each pad. Readjust. Enjoy sneaking up on people again. Or, get some vehicle Disc Brake quiet that is applied to the non-brake surface of the pad and use that to stop the vibration.
    jon.
    ..ouch
    Reputation: thump's Avatar
    Every time I've had issues with noisy avid's it's been due to small alignment issues. Those fancy dished washers make it easy for them to get slightly off vertical alignment (camber, tilt, whatever)..
    Rolling
    Reputation: lidarman's Avatar
    Quote Originally Posted by 3nf
    Perfect for those blind corners on Apex.
    Can I recommend a hollow carbon monocoque frame like the Ibis Mojo to go with them, then frequency of the squeal resonates through the frame which acts like an amplifier much like an acoustic guitar. Wonderful sounds and it feels like the bike is a tuning fork when you are riding.
    Thread Terrorist
    Reputation: IndecentExposure's Avatar
    All of these cannot compare to mine...
    HS33 (the old hydraulic rim brakes) with a fresh rim grind (yep, grinding the rims)..
    .....okay, so its a trials bike
    Golden Bike Park Group
    Peak Cycles Gravity Team & Bikeparts.com
    Trestle Bike Park
    Reputation: zorro's Avatar
    Feb 2007
    Juicy 5's here and yes I do not have to warn hikers, or anything else for that matter, that I am approaching. I think the vibration in addition to the sound will alert anything within one square mile.
    PS - Thank you OP for making me laugh this morning. I miss funny posts rather than these (I had a run in with a hiker/someone didn't yield to me/downhillers are going to kill somebody/etc... posts).
    Awesomist™
    Reputation: Full Trucker's Avatar
    Quote Originally Posted by IndecentExposure
    ...and it d@mn well BETTER be noisy.
    The older I get, the faster I was.
    Punch it, Chewie.
    Oh, So Interesting!
    Quote Originally Posted by Coloradoxj13
    The rear triangle of my Trek Remedy and Session both amplify brake vibrations. It does feel nice, little vibro-massage action
    ONE WORD: GRAVITY
    Reputation: nhltfour's Avatar
    Get Saints!!!
    Reputation: Comrade K's Avatar
    I must just be lucky...
    I've got J-7's on two bikes and they are all silent nearly all of the time - hot or not. Metallic pads, Avid rotors.
    One thing I have noticed though, my last couple of rides were in extremely dusty conditions and my rear brake did begin to squeal late in the ride. The brakes were already hot so I've been blaming it on the dust.
    I think I'll try that brake silencer stuff and the stiff rotors. If that doesn't work I'll just take the brakes off and use the foot on the rear tire trick. Less modulation that way, but at least I'll keep my ear drums.
    hehe ...you said "member"
    Reputation: jake7's Avatar
    Quote Originally Posted by ignazjr
    Now that's an idea I've never heard of before ... interesting!
    “Me fail english? Thats unpossible.” - Matt Groening
    ..ouch
    Quote Originally Posted by jake7
    It gives a nice mix of modulation and power. Down side is the organic pad always ends up wearing out quicker.
    Medicine Wheel Guy
    Reputation: Martlet's Avatar
    I got a great tip from some guys at SRAM for my Elixirs. Just take the pads out and swap them inboard and outboard (only works if the pads are symmetrical, as they are on the Elixirs). Worked like a charm for me.
    Your bike is incorrigible
    Reputation: Guyechka's Avatar
    My Louise FRs sound exactly like a turkey gobbling. I can't ride at PR for fear of being attacked by wild turkeys in heat!
    I have J-5's on one of my bikes and elixers on the other. The 5's have been quiet, but the E's began squealing a bit recently. I work in the auto industry and so I tried a VERY small amount of disc brake quiet (available at any auto parts store) on the back of the pad, and the noise was gone. Most of the time the noise is caused by a high frequency vibration of the pad/rotor. The purpose of this disc brake quiet is to absorb and dampen the vibs... Worth a try.. Cheaper than buying new pads too...
    Stand back
    Reputation: dbabuser's Avatar
    The rear 7's on my Jedi squeal, and the rear carbon 7's on my sx have the turkey gobble with a little squeal. The only Avid rotor I'm running is a front that is silent, but as others have said, I think a little brake noise is a good thing. That, and I've got so many other things to work on that noisy brakes are waay down the list...
    Golden Bike Park
    Golden Connector Trails need your support!
    Reputation: claystrick's Avatar
    Nov 2008
    Hayes
    I think my Hayes 9 are the worst...I certainly don't sneak up on anybody, even those wearing IPods
    Reputation: pko142's Avatar
    Nov 2008
    Mine were the loudest until....
    I was embarrassed to ride this year with my avid juicy 7's... no joke, i was skipping rides that required any downhill braking... I posted earlier in another forum how to fix this, and feel i need to again for all you poor souls with howling avid's...
    1. log onto your favorite online retailer.
    2. order hayes v-style rotors and NON-avid brake pads (i used Koolstop sintered).
    3. install, ride, and enjoy the sounds of silence.
    the fix was under $40 for each wheel. Will never use avid rotors or pads again.
    Reputation: brandonj1979's Avatar
    Any Juicy. Worst brakes ever!
    Catalina wine Mixer!
    Dose hayes make a 160 mm rotor??
    I had juicy5 howling, vibrating problem on rear brake only on G Fisher Hi-Fi 29. Tried everything to fix it and finally tried organic brake pads. Problem solved. Put them on both front and back and have not really noticed less braking power; only notice the lack of noise and bike-rattling vibration
    A local shop employee was nice enough to talk me out of new XT brakes and buy his juicy 7's at a decent price early last season. The was a disaster and eventually I went with XT from another shop and solved my issues...My new bike has XT's as well...don't think I will ever use Avid brakes or the other bike shop...BR
    Pivot Rider
    Reputation: Yetigirl's Avatar
    Quote Originally Posted by yetirich
    Mine too! I just use it as an early warning system.....since I don't have a bell to warn people I'm coming!
    Dirt Divas website l Twitter: @thedirtdivas l Facebook
    Quote Originally Posted by pxforti
    ...finally tried organic brake pads.
    FDA certified or just claimed "organic"?
