Results 1 to 39 of 39
    Reputation: nixgame22's Avatar
    Tire opinions.....yes, another one :)
    So, I'm trying to narrow down my tire choices on my Yeti 575. I'll mainly be riding Front Range trails, so I would like something that works well here.
    The bike came stock with Schwalbe Fat Albert 2.20 (front/rear).
    I would like to upgrade the:
    -rear to a Kenda Small Block 2.35 DTC
    -front to a Bontrager Big Earl 2.35
    The wheel set is a Hope Pro II/Mavic 819.
    What do you think? Do you think this would be a good setup for the Front Range trails?
    Thanks much
    Maintain internal heights.
    hehe ...you said "member"
    Reputation: jake7's Avatar
    go tubeless ... you'll thank yourself with uninterrupted rides!
    “Me fail english? Thats unpossible.” - Matt Groening
    Quote Originally Posted by jake7
    I have Mavic 819's, so they're tubeless ready. Will certainly be without tubes.
    same rims - run the Maxis Ignitor 2.35 and find them to work well in many/all CO front range conditions.
    Yeah..yeah...yeah - ask 20 FR riders and you'll get 30 different opinions. I know. having run a number of different UST tires, I have found the biggest difference to be running tubeless vs. tubed. Wear/hookup seem more effected with being able to run lower pressures without pinching vs. the specific tire (but I am 6'7", 250 - grain of salt and all that).
    bacon! bacon! bacon!
    Yeah... except when they go flat.
    Your bike is incorrigible
    Reputation: Guyechka's Avatar
    Quote Originally Posted by SkaredShtles
    Or burst while zipping down I-25 on the way to Pueblo. Of course, this is less likely to happen if you just run your bikes forward facing in the racks.
    Reputation: bedell99's Avatar
    Right now I have the Schwalbe Nobby Nics 2.25 with snakebit. It is a good tire, light and rolls good but is terrible with any moisture. When I get new tires I want to try out the Maxxis ardent 2.4 and 2.25 on the rear.
    Erik
    still riding
    Reputation: Shrederland's Avatar
    mountain king front
    ignitor rear
    Reputation: andrewnielson's Avatar
    Quote Originally Posted by Shrederland
    mountain king front
    ignitor rear
    I concur with this!
    I've got a 2.4 Mt. King up front and a 2.3 Ignitor in the rear and love em!
    Any thoughts/opinions on the Kenda Small block 2.35 for the rear?
    Mar 2006
    Kenda El Moco 2.35. Why can't they make this in the DTC?
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Quote Originally Posted by nixgame22
    It's a great tire for a 3in travel XC racer or a DJ bike. It's only good on dirt roads and hardpack.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Reputation: brandonj1979's Avatar
    Quote Originally Posted by Guyechka
    Or you realize you're still carrying tubes and a patch kit in your camelbak anyway!
    Catalina wine Mixer!
    Alt-132
    I've run the Big Earl 2.35 Tubeless tire a couple times, it works pretty well for Front Range stuff, is easy to mount up tubeless, measures a full 2.35" wide, and not too heavy for what it is. I think it's probably wise to put something that rolls faster in the rear, as it looks like you're planning on- even being dual compound, it still rolls slow and wears out fast in the rear.
    As far as grip, the Dry version works well in the dry and sucks horribly in the mud (imagine that). I've tried the 2.5 Wet compound on my DH bike, and it seems to be a better all-around version if you plan on riding in the wet.
    It's a "transition knob" tire, and has consistent grip at across the lean angle, which is nice, but overall doesn't have the ultimate grip of a tire with a nice open channel in the transition area.
    It does seem to like fairly low pressures, so try a few psi lower than normal.
    Overall, if good consistent grip is your main goal, it is not a bad choice. The trade offs are rolling a little slow, faster wear, and not quite the ultimate grip of an open channel tire.
    Reputation: Kaba Klaus's Avatar
    Maxxis Minions - tubeless setup
    Hooks well to the ground. Excellent for steep and technical. Slow for fire roads and smooth/pedally trails, though.
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
    I heart the drops
    Reputation: giantsaam's Avatar
    Continental rubber queen 2.4 ust front, 2.2 ust rear. Best trail setup in colorado
    "its not how slack your head angle is, its how you ride the bike"
    I am not a front range guy so feel free to disregard my opinion, but I have ridden in Colorado a few times and my normal terrain is nothing but knarly roots and rocks. One of the best all around tires I have even encountered (been running them for 8 years, despite trying countless others - I just keep coming back) is the Continental Gravity pro 2.3. It has excellent and predictable traction in all conditions except for deep mud (no 2.3 can perform in deep mud). It is avaible UST, and also in a PROtection sidewall version which is tough as nails. In my 8 years of riding them I have never had a puncture.
    One thing I really love about this tire is that it combines the good features of several designs into one package. It has a raised and squared edge created by the side knobs, which allows the tire to bite into the ground when cornering. It has a more rounded center section, so the tire rolls very quickly (much faster than any other full sized knobbed 2.3 I have tried). It also has chunky, well spaced knobs so it grips just about everything.
    Thats my $0.02
    Continental Gravity PROtection Tire Black/Black DuraSkin Foldable 26 x 2.3
    Looking for/WTB : Grove Innovations Assault Fork, Grove Innovation Hammerhead Stem or Hothead Bar Stem
    Conti Vertical Pro 2.3 front and back or front with an Explorer Pro in the back works great. My new Turner 5 Spot came with Kenda Neveigal 2.3 front and 2.1 rear. They work much better than the reviews suggest.
    Murph
    Living the High Life
    Reputation: Ithnu's Avatar
    Feb 2007
    I've run Maxxis Ardents, Advantage, Minion, High Rollers, Kenda Nevegals, Nokian Gazzalodis, Hutchinson Pythons, that's all I can think of right now. Varying sizes, 2.4, 2.35, 2.25, 2.10, 1.95.
    My favorite combo has been Nevegal 2.35 front, 2.1 rear or High Rollers 2.35 F/R.
    Its a toss up between rolling resistance, grip, weight and durability.
    You have just been mentally Rick Roll'd. Yup you're thinking about it right now aren't you? Don't fight it.
    I have been on a bike that had Big Earl's on them-- and honestly I hated them-- they were all over the place. Also I think the small block might be a little bit too small for the loose crap around here (but I have never been on them --- they do look awesome for a DJ though)
    For the FR on a 575 (especially the new 575)-- I would go w/ a high roller front w/ something like a Larson TT on back. Minnon DHF’s are also always good (but I guess kinda slow rolling). I hate Nevegals on my DH bike but they work ok on a XC bike. Crossmark also kinda a cool tire for the rear.
    I have been hearing good things about the El Moco (Lopes used to have the maxis Bling Bling—the Moco is his Kenda design – and I have heard awesome things about the bling so I would venture to guess the moco will be good as well.)
    Also beware the Maxxis UST ( I think they have thinner sidewalls—I blew out my sidewall first day out on Apex—just use stans)
    Oh, So Interesting!
    Reputation: davec113's Avatar
    Quote Originally Posted by giantsaam
    x2
    The 2.4 is a $75 tire, on sale here for $37. I have a small stockpile of 2.4s. It's by far the best tire I've used for a trail bike, and I've been through a lot of tires.
    http://www.bikebling.com/Continental...een-kevlar.htm
    They have the USTs on sale too, but I don't do tubeless.
    Thread Terrorist
    Reputation: IndecentExposure's Avatar
    Thanks much
    I think (this is my opinion) you'll be run off the trails by a mad fundamentalist mob when you try to slow down using the Small Block 2.35 DTC's. They'll have pitchforks waiting for you as you attempt to slow for the switchback when your rear breaks loose easier than expected.
    With braking forces going forward toward the front tire, you'll want/need the extra traction in the back. Having something deep grooved tread will help keep you from braking loose in the backside. An XC buddy of mine (and jeffco volunteer ranger) uses treadless xc tires and pays for it when trying to slow at a higher rate of descent.
    We all practice treadology on these forums... no one has the holy grail, but most of the aforementioned tires should do you good. I personally run the Minion DHF front AND Rear for better cornering. They stop well enough. That said, I've had the worst luck with Conti-vertical pro's and the most flats with Nevigals (Although their tread pattern is nice).
    My Schwalb TableTops are FREEEKING Awesome, but not meant for hooking up in anything loose (think urban, DJ, etc).
    Golden Bike Park Group
    Peak Cycles Gravity Team & Bikeparts.com
    Trestle Bike Park
    Oh, So Interesting!
    Quote Originally Posted by IndecentExposure
    DHF ft and rear would be my choice if the rubber queens weren't around. They last about 1/2 as long as the rqs, roll slower and are easier to flat though.
    I agree nevegals suck bawls... slow rolling, pinch flatting POS... They are super easy to pinch flat, even when they were brand new and I was running 45 psi they pinch flat before the bike even bottoms out.
    Feb 2007
    Quote Originally Posted by davec113
    Fast and loose, stop plowing
    Oh, So Interesting!
    Quote Originally Posted by Ithnu
    You haven't rode with me in a few years, have you
    Anyway, they pinch BEFORE the bike even bottoms. $hitty sidewalls. All other tires in existance are superior to the Nevegal.
    still riding
    not to mention the side knobs rip off if you look at them funny
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Hey, hey, hey......
    Fat Albert 2.4's
    Whne I rode Fat Alberts 4 years ago they shed knobbies in a blink. Ripped then right off on the first technical descend.
    Have they changed?
    Oh, So Interesting!
    I got 2 Schwalbe Big Betty Guey Glueys a couple years ago and the side knobs must have been held on by elmer's glue. They were also poor in wet conditions. Others seem to have had better luck with the triple compound tho...
    Light freak
    Jun 2005
    This is the first pair that I have owned (took me years to save up for them). I rode them all summer and thru this winter (average about 3 rides a week) and they are holding up great. No knobs missing yet, just the usual wear on the leading edge of the knobs on the back tire.
    Feb 2007
    Kenda has some decent tread patterns. The El Moco and Excavator are good. But their sidewalls do need improvement. Our team had several rip/blow out/fail last year. We switched to Maxxis this year.
    Oh, So Interesting!
    If Maxxis tires lasted longer and/or cost less I'd be a lot more psyched on them.
    Have you tried the Conti Der Kaiser or Rain King? I'm thinking of trying them out, but I hear the Der Kaiser is currently being redesigned to roll faster. The new Conti Black Chili compound performs like Maxxis ST but lasts longer than Maxxis 60a.
    review:
    http://www.pinkbike.com/news/contine...view-2010.html
    I've been mixing and matching Alberts and Advantage for a while now, and I really can't see that much difference. If I had to choose, then I'd go for another set of Advantage because they are a lot cheaper than the Alberts.
    I used to run Nevegals on the DH bike and never really had a problem w/ pinching or rips? I still have a nevegal UST on the front of my xc bike and that has been good too? Maybe I had a good batch (though I still don't like them)
    I have heard from PHX people that the excavator works well down there (so for front range probably the same).
    Anybody got experience with Kenda Excavators and Stans?
    Reputation: inkpad's Avatar
    High Roller 2.35 LUST front & rear here. Though sometimes I run the Crossmark LUST on the rear. Very predictable set up, not too bad in the wear dept, but I will chose performance over longevity any day.
    Feb 2007
    Quote Originally Posted by Kaba Klaus
    Klaus that's a big no no. Ryan and I each tried that last summer. We each had two punctures. And I don't mean a little one, it looked liked some one took a knife and stabbed right through the center of the tread. I had Stans spraying everywhere.
    Kenda isn't kidding when they say they don't endorse sealant in their products. Stans erodes their rubber and it loses strength. No tubeless with Kenda DH tires. Its too bad, the Excavator is a great tread pattern.
    MK_
    MK_ is offline
    carpe mañana
    Something like this?
    ^ this is the main reason I stopped running Stan's
    There is a good alternative to it, though, amonia free (amonia is the corrosive agent that de-laminates the tread from the casing). It is called Caffelatex from http://www.effettomariposa.com/
    _MK
    Reputation: SylentK's Avatar
    Yes. Good and bad.
    Good:
    I've had good luck running them on my Nomad. 2.35" DH bead, StickE compound w/ Stans. They are about as wide as a maxxis 2.5. No problems whatsoever. Even at lake ptown, moab, Keystone, etc. But you must keep pressure on the high side. I believe there is a misnomer about running tubeless w/ less pressure.
    Bad:
    Racing DH on 2.5 DH bead stickE w/stans. I would put a hole in the sidewall bead, right by the rim just by looking at rocks. Maybe I didn't have enough pressure. Were much better w/ tubes.
    Note: I run Mavic DeeMax and CrossMax on these bikes. They are known for being very stiff and a little on the narrow side. This setup has been known to be very hard on sidewalls and beads. I've had to up my pressure quite a bit since this mavic tubeless jive conversion.
    Oh and I do believe not all tires cooperate w/ stans. Especially Kendas.
    Biker? I don't even know her.
