Results 1 to 12 of 12
    My leg feels funny
    Reputation: liqwid's Avatar
    Swaping chain rings, shorten chain?
    I'm dropping my 40t to a 36t on my DH bike. Anyone know if I should drop a couple of links off the chain or should I be fine with the length that worked with the 40t?
    skillz to pay billz
    Reputation: nOOby's Avatar
    humm... I just replaced my big ring w/ a bash ring and was wondering the same thing?
    As a rough rule of thumb I leave just enough chain so that I can shift into the big chainring and the big sprocket on the cassette.
    Reputation: heckler_asx's Avatar
    This might help: http://www.parktool.com/repair/readhowto.asp?id=26
    I use the largest cog to largest chainring method
    My leg feels funny
    Quote Originally Posted by heckler_asx
    Awesome, that is helpful. Thanks
    Rides Uphill Slow
    Reputation: The Hookler's Avatar
    I would say that if you were going from a 40 to a 38 it shouldn't be a big deal but since it's a bit more I'd use the big ring to big cog method as already stated. You should be fine either way.
    I'm here for the downhill
    Rides Uphill Slow
    Quote Originally Posted by nOOby
    Did you keep the 22/32/bash set up or did you change out the middle ring? I'm running a 22/36/bash set up and really like it. I still have a pretty decent top end and I seem to ride just a little bit faster with the 36 and any combo in the back. I also feel better ramming into things and not having to worry about breaking teeth off of a big ring.
    skillz to pay billz
    haven't changed out the middle ring, Might try changing them but I leave it in the middle ring so much nowadays that it might put me back into the granny more often if I swap it.
    Rides Uphill Slow
    You'd be surprised that it just makes you a bit stonger. Maybe start with a 34 tooth and see how it goes.
    skillz to pay billz
    eventually for sure Hook.
    I just removed 6 links from my chain, my bike is so much lighter
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Technically, for ever 3 teeth you remove from the biggest ring you can remove one chain link.
    _MK
    My leg feels funny
    Hey man thanks again for the link, that largest cog to largest chainring method worked like a charm.
