Results 1 to 6 of 6
    Dec 2004
    Stumpjumper 2007 Expert
    I hope this doesn't get moved but I don't want to post in the Classifieds because im looking for a Local Front Range Trade.
    Anyone out there have a 2007 Specialized Enduro Expert Med?
    Looking to maybe swap my 07 Med Stumpy in perfect condition
    looking for a bit more travel and a bike leaning more towards the downhill
    Thank you
    How would you like to be an egg?
    You only get laid once.
    You only get eaten once.
    It takes four minutes to get hard.
    Only two minutes to get soft.
    You share your box with 11 other guys
    But worst of all..
    the only chick that ever sat on
    your face was your mother!!!
    So cheer up, Your life ain't that bad!!!!
    Dec 2004
    actually, anything with a bit more travel and geared towards the Downhill, I do need to pedal it though so no tanks please.
    But worst of all..
    skillz to pay billz
    Reputation: nOOby's Avatar
    you might want to be more specific about your bike, build etc. Although it's far fetched to think someone on the front range would want less travel on their FS bike IMO. good luck.
    Dec 2004
    oh, i figured by saying its a Expert they would either know or look on the web for componets but here it is.
    Thank ya
    http://www.specialized.com/bc/SBCBkM...16&language=US
    # SR M5 manipulated alloy frame w/ Transform monocoque TT, Spinal Tech 1pc forged BB, seat tube, and seat bridge
    # Fox Brain Fade remote shock
    # Fox Talas RL fork
    # Avid Juicy 7, hydraulic disc brakes
    # SRAM X.0, 9-speed rear derailleur
    # Shimano M-760 XT Hollowtech II, 2pc crank/BB
    # DT custom for Specialized X430 rims
    FRAME FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, carbon reservoir mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
    REAR SHOCK Fox Brain Fade remote, adjustable trail tune range, adjustable rebound, 7.75x1.75"
    FORK Fox Talas RL, 100-140mm, rebound/compression adj, lock out, alloy steerer
    HEADSET 1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
    STEM Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
    HANDLEBARS Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
    TAPE / GRIPS Specialized MTB, dual density
    FRONT BRAKE Avid Juicy 7, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL: 200mm rotor
    REAR BRAKE Avid Juicy 7, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL: 185mm rotor
    BRAKE LEVERS Avid Juicy 7
    FRONT DERAILLEUR Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
    REAR DERAILLEUR SRAM X.0, 9-speed, long cage
    SHIFT LEVERS SRAM X-9, aluminum trigger 9-speed
    CASSETTE / FREEWHEEL Shimano HG50, 9-speed, 11/34t
    CHAIN SRAM PC-951 w /Power Link
    CRANKSET Shimano M-760 XT Hollowtech II, 2pc crank/BB
    CHAINRINGS 22A/32A/44A 4mm thick outer, 4 bolt 104/64mm
    BOTTOM BRACKET Shimano M-760 XT, integrated with crank
    PEDALS Shimano M-520 SPD
    RIMS DT custom for Specialized X430, 24mm w/eyelets, 32h
    FRONT HUB Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
    REAR HUB Shimano M-525 disc, 32h, alloy QR
    SPOKES DT Swiss 1.8mm stainless, black, alloy nipples
    FRONT TIRE Specialized Resolution Pro 26x2.1", 120TPI, aramid bead, dual compound
    REAR TIRE Specialized Resolution Pro 26x2.1", 120TPI, aramid bead, dual compound
    TUBES Specialized Ultralight 26x2.0", presta
    SADDLE Specialized BG Rival, hollow Cro-Mo rails
    SEAT POST 2014 butted alloy, black, 30.9 x 350/400mm
    SEAT BINDER 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
    But worst of all..
    Trades can be tough to come by. Do you want to sell it outright?
    Dec 2004
    sure, if say worth $2200 ish, make a offer
    its in perfect condition
    But worst of all..
