Results 1 to 10 of 10
    !Vamos, flaco!
    Reputation: Pabs's Avatar
    Stan's with tubes?
    Can you put Stan's in normal tubes? Gracias.
    "Fact is only what you believe; fact and fiction work as a team." Jack Johnson
    ride
    Reputation: ignazjr's Avatar
    I have used it in stroller tubes with success.
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    !Vamos, flaco!
    Quote Originally Posted by ignazjr
    Was it a FS stroller with small wheels, or a rigid stroller with big wheels?
    Do you sell Stan's and the applicator?
    Your retarded
    Reputation: Nickle's Avatar
    Pabs, what's the appeal in running a Stans filled tube over a ghetto tubeless with Stans and non-UST tire?
    A trail thatís too difficult wouldnít exist because itíd never be used. But, trails can exist thatíre too difficult for you.
    That's what I used to use for cross till I went with tubular's. Still in my pit wheels. Have official "Slime" tubes on my commuter.
    For DIY, just have to buy conti or QBP (probably others) tubes with the removable valve cores.
    Yappy little dog!
    Brings back memories!
    This subject brings back memories of Pete F.'s old site. Sadly, it has gove to InterWebz heaven, but pieces of it live on here.
    Now with 20% more fat!!
    Reputation: JSD303's Avatar
    Pabs - I've run Stan's in tubes before - remove the core and BAM, hit it with the spice weasel - I mean insert Stan's and replace core. Good to go! I've converted all my wheels except the cyclocross bike to tubeless with Stan's since. I run the cyclocross bike with Stan's in the tubes, still, and it works well enough.
    Reputation: pulser's Avatar
    Dec 2004
    I run stan's in my road tubs.
    Big Boned
    Reputation: Manmountain Dense's Avatar
    Feb 2007
    Quote Originally Posted by JSD303
    (golf clap)
    I love you Elzar!
    Stan's in tubes works fine, until you hit something really big.
    And you don't necessarily need to use a tube with a removeable core. Back in the day, to get Slime into my cheapo tubes, I would just poke a small hole in the tube, squeeze in the juice, and then patch it with an old-school rubber cement-style patch. Worked fine.
    OMG!
    Reputation: adjunkie's Avatar
    Feb 2007
    Quote Originally Posted by Manmountain Dense
    (golf clap)
    I love you Elzar!
    Don't poke holes or use a removeable core. Use any presta tube. I do it to my road bike tubes or when i have a flat and i'm out of tubes.
    The procedure:
    1. Unscrew the nut offf the pin.
    2. Hold the backside of the stem through the tube to prevent the pin from falling in.
    3. Use a small diameter hose (ex. fish tank hose) attach to stans bottle and core.
    4. Squeeze a decent amount in.
    5. Replace nut on pin.
    6. Pump it up.
    This trick also works to fix flat tires without having to remove the wheel.
