Results 1 to 16 of 16
    That about sums it up.
    Reputation: outaluck's Avatar
    Stans in Schwalbe?
    I recently read that Stans can breakdown the inner lining of Schwalbe tubeless tires. Anyone use this combo or have any problems with it?
    ..ouch
    Reputation: thump's Avatar
    I've used it in their DH tires without issue but only ran the tires for a few months so it may not have been enough time to see any effects. The Schwalbe website says you're supposed to use some of their branded goo instead.
    Reputation: Phatpants's Avatar
    Jun 2010
    I can't say that I have used stan's with schwalbe tubeless tires, but I have had no problems with stan's and schwalbe non-tubeless tires.
    Quote Originally Posted by thump
    I have no experience with this but the above tells me about all I need to know.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    No problems at all running Stans with RaRa EVO's. Just setup RaRa pacestar's too and I'd do it again every day and twice on Sunday's.
    I have had no issues with Stan's and Scwalbe. The tread will probably wear out first anyway.
    danaco
    Guest
    Been using that combination for years without any issues.
    simple
    Reputation: 69erSycip's Avatar
    I go through dozens of Schwalbe tires with Stan's in them a year. Not one problem yet.
    You are good to go. Schwalbe and Stan's are actually working together at this time to develop a product that improves the Doc Blue sealant.
    Moderator Moderator
    Reputation: 2melow's Avatar
    Quote Originally Posted by outaluck
    Muy bueno...no issues with Schwalbe and Stans. A good marriage.
    Front Range Forum Moderator
    Ka-coo-ka-cha!
    Reputation: snigs's Avatar
    Feb 2010
    Word. Stan's + Schwalbe TL Pacestar = excellent combo so far
    Get a bicycle. You will not regret it, if you live. ~Mark Twain, "Taming the Bicycle"
    Reputation: wilsonblur's Avatar
    Its interesting, I had a casing break on my Nevegals after about 10 rides. I called Kenda and asked about warranty issues. When he found out I was running Stan's inside my UST's he said I invalidated the warranty because the sealant breaks down the rubber.
    I ran Stan's in regular Schwalbe's for 4 years with no issues.
    Narrow is the path to life, few are those who find it.
    Reputation: hairylegs's Avatar
    There's supposedly ammonia in sealants like Stans which causes the lining to breakdown over time. This is probably true in laboratories but I always wear out the tread long before this becomes a problem in real-life. So the solution is to ride often and change your tires when they wear out. I'm currently running Schwalbe Fat Alberts with 2 oz of Stan's in each.
    I've had no issues (unless you count the fact Fat Alberts turn slightly damp logs into shear ice covered in vaseline and bannana peels- but that's hardly the sealant's fault)
    simple
    Quote Originally Posted by wilsonblur
    There are many many instances of Stan's and Kenda tires being problematic.
    Looks like I'll go ahead with the tire purchase... thanks for all the positive feedback. I'm seriously considering the Muddy Mary UST for my next tire.
    ..ouch
    Schwalbe used to say the same thing on their website. Stans = no warranty... but I can't remember the last time I tried to use a warranty on a bike tire anyway.
    Ka-coo-ka-cha!
    Feb 2010
    Quote Originally Posted by hairylegs
    Word. And have the scars to prove it...
