Results 1 to 31 of 31
Thread: Riding form...
    Riding form...
    So here is the story..
    For a solid ten years, plus or minus a few months, I had ridden my 99 fsr in mostly stock form suspension wise, wheel set wise, and brake wise.. (never had a problem pushing the front end)
    Now fast forward to this season..
    (longer travel fork, bb7's and mavic 717's w/xt hubs etc..)
    Now I find myself hunting for a setup that wont leave me pushing my front end all the damn time through corners (fast or slow)
    I am wondering if i need to also finally junk my sid "dual air" rear shock, and find somethign a lil newer...
    Any suggestions, I have this in the front range section because obviously that is were I ride..
    Thanks in Advance guys..
    here is a pic pre-brake install..
    contains quinine
    Reputation: Debaser's Avatar
    As much as I'd love to say its the lock... maybe its the fork?
    Take the long cut, we'll get there eventually.
    Quote Originally Posted by Debaser
    your frame probably wasn't designed for that much front end travel
    I am still playing with certain air settings on the fork, and rebound settings.. etc..
    I would hate to say my judy SL was more fluid than this unit...
    luckily my frame has some stress cracks near the rear shock mounts I have been meaning to get looked at for a frame "upgrade"
    had bike since new, and still have receipt, so i guess we will see..
    Apr 2005
    By pushing you mean understeer? I.e. front wheel not wanting to turn? I would try a shorter stem which will allow you to weight the front end more easily without feeling like you're going to go over the bars.
    Anyway that geometry looks fine - not raked out at all...I wouldn't worry about the travel but those stress cracks?? Time for a new frame!
    Yeah its pushing the front, as in UNDER steer..
    thanks for the info
    Yeah at Mt Falcon, about 8 years ago I hit a water bar and landed smooth (or so I thought) and well, the bolt that holds the shock on the frame side snapped, sending me through the air after my landing, super man style..
    Shortly there after I had to fly to Alaska for my summer job as a commercial fisherman, and played fight on the phone with Bi-village to get a new frame, and they offered me a lesser model, and I told em to shove it.. Hopefully it goes better this time around..
    Never had an issue with the cracks.. Just pushing the front.. man that is sketchy...
    Apr 2005
    Sounds backwards but understeer is when your front wheel slides so you don't turn as much as you intend...oversteer is the opposite, you turn more than you intend, i.e the back slides out. Much preferred!!
    But I digress, I suspect the longer fork shifted your weight back and is causing this. Less traction on the front end is the culprit. You might also try a bigger front tire run at a lower PSI. You'll probably like how that smooths out the Front Range sharp edged rocks too!
    hahaah i am an idiot, as an old racer i cant believe i just wrote over instead of under..
    hahahaha... (kicks self in head)
    yeah UNDER steer.. lol
    cracks
    i would have taken a pic of the other side, but a washer covers most of the cracks on that side..
    actually now that i think about it, i switched from straight carbon bars to carbon risers,
    now that i have the riser bars, i should prolly get a shorter stem..
    Many heads are better than one..
    thanks!
    -meat
    ..ouch
    Reputation: thump's Avatar
    On the second pic, is that a crack running along the thin edge of the metal? If so, good luck with warranty, they may blame that on overtightening of the shock bolt.
    Quote Originally Posted by thump
    i never touched it or removed it, all (warranty) work was done by bicycle village, when the mount snapped, it caused the mount too "V" causing the mark you see to the right of the bolt...
    they tried to cheap out on it in 2000, so i would expect nothing less today... (i mean the bike was brand new and they still would not offer me an equal value frame..
    specialized service sucked back then, and i am sure it hasn't gotten any better in 8 years...
    Oct 2007
    I have a 99 fsr Elite with a Risse Racing rear triangle, 5.5 inch travel and a 140mm fork and it rides very nice, no plowing thru turns. Try a riser stem and riser bars that might help. I've owned this bike since 01 and love it. Hope you get her dialed in, i love seeing these bikes on the trails. CHEERS.....................
    Oldest daughter doesn't ride.
    ..ouch
    Quote Originally Posted by meat-market
    i never touched it or removed it, all work was done by bicycle village, when the mount snapped, it caused the mount too "V" causing the mark you see to the right of the bolt...
    Ah.. in that case, good luck dealing with BV (and their burger flipping, dime store mechanic staff).
    nah i know better to walk in there ever again, If this thing ever breaks, it going on my wall as art..
    as you can see by this pic, my garage is stocked, and the bike hasn't seen a dime store mechanic in years..
    I just never had any reason what-so-ever to want to pull that piece off..
    (bike was originally purchased from Summit City Cycles Ft Wayne Indiana, Aug 1999)
    skillz to pay billz
    Reputation: nOOby's Avatar
    warranty on a 10 yo bike?
    Slopestyle Rider
    Reputation: joelalamo45's Avatar
    This thread delivers bro... you got Skip Canfield to reply.
    BTW Skip, do you guys plan on making a short travel slopestylish bike? I know a guy *cough* who can trick a little and would love to ride one...
    Quote Originally Posted by nOOby
    last i checked lifetime frame warranty meant lifetime..
    I've seen beat to **** specialized frames get replaced no questions asked, (5+years old) but then again it wasn't my frame, so of course it went smooth..
    skillz to pay billz
    sorry, did not realize it was lifetime, carry on
    Gaa-zee-raaaa!
    Reputation: Godzilla's Avatar
    Mar 2005
    Quote Originally Posted by joelalamo45
    You may as well ask Madeleine McCain about her energy policy.
    Now with more vitriol!
    Oct 2007
    Oh, So Interesting!
    Reputation: davec113's Avatar
    With a longer fork and riser bars, you'll need to weight the front end more to achieve the same weight distribution you had before. Lean further forward and lower your cg by keeping your elbows out, and you can move your cg further forward by moving your knees forward as well. Bike doesn't look too raked out, imo...
    Slopestyle Rider
    Quote Originally Posted by skip canfield
    I meant, are you guys ever planning on a 5"ish bike (similar to the Balance)?
    I'd love to ride one.
    Gaa-zee-raaaa!
    Mar 2005
    My point with the Madeleine McCain comment was that, Just as Madeleine McCain has no thoughts on energy policy - Skip Canfield probably knows nothing about the plans of Chris or Lance Canfield as far as new bikes go.
    You're barking up the wrong tree.
    Oct 2007
    Quote Originally Posted by Godzilla
    you are correct, I am not part of THAT Canfield family. I would'nt mind though, couple of new bikes from them. YEAH !!!!!!!!!!!!!!!!
    well i hit up heil ranch today, and adjusted my riding style accordingly, had a blast, but toward the end of the ride (the down hill of course) my fork decided to stay in lockout mode, no travel mode.. ugh..
    so i need to dig a lil deeper..
    maybe time to send it off, and throw the old judy sl back on.. meh...
    maybe the lockout needs adjustment i dunno, didnt think i was that hard on equipment..
    -MM
    Moosehead
    Reputation: moosehead's Avatar
    Time to buy yourself a new horse partner. That one doesn't look like it owes you much, rode hard, put up wet.
    the fork does not even have but 6 rides on it, that is why i am at a loss....
    vid to follow...
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/2s9TzPTc2Fo&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/2s9TzPTc2Fo&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
    bike is at the shop getting a new rebound assembly installed in the fork.. (apparently answer/maniscrew sent the wrong assembly last week, hoping to have the sled back by weds)
    first time the bike has been in a shop in its life.. wow i just realized that.. (since new)
    bacon! bacon! bacon!
    <snip>
    How new is it?
    1999
    It has been maintained by various mechanics including myself, but never in a shop for repair..
    oh wait..
    its been twice.. once in 99 for blown spring stays in the judy sl it came with, and now..
