Results 1 to 7 of 7
    Reputation: ds2199's Avatar
    OT: Internal geared hub for old cruiser - retrofit
    Yes - a bit off topic. I'm wondering if anyone here on the front range knows where I can go to get an internal geared hub (maybe build a wheel) AND have the spacing on an old steel frame cold set with wider spacing to accomodate the wider hub?
    Specs:
    Current spacing 110mm
    steel frame
    would like 7 or 8 speed (but may settle for 3 if the spacing on the 7/8 spd hubs are too wide to stretch from 110)
    Anyone completed a project like this? know any shops that work on old cruisers?
    I think there are some Sturmey Archer hubs with 118 or 120 spacing?? Ideas??
    Thanks!!
    Diggity Dog
    Reputation: ShinDiggity's Avatar
    The newer Sturmey's aren't near as good as the SRAM's.
    I'd possibly check into a Spectro P5 5 speed hub. They are spaced for the older frames at 122 OLN. Jenson has them for about $125 and the shifter is another $30.
    This is the set up I'm going to use on an older cruiser when I get around to it.
    friend of Apex
    Reputation: WKD-RDR's Avatar
    You may be able to space the frame your self.
    http://www.sheldonbrown.com/frame-spacing.html
    OT? shoot, this is bikes, not lookin for work. I'd say on topic
    the drugs made me realize it's not about the drugs
    Quote Originally Posted by WKD-RDR
    I guess I meant off "MTB FRONT RANGE" topic. Maybe I shoulda done a "best internally geared hub for the front range" instead?
    I looked at the Sheldon Brown tutorial on spacing the frame and I might just do that. So then I just need to decide on a hub that has the biggest gear range and the narrowest spacing (with a coaster brake would be best too - as I don't want to have to deal with adding rim brakes).
    Heads up Flyboy!!
    Reputation: mountaingoatepics's Avatar
    Dan, I've got my Alfine laced to a 700c DT Swiss TK7.1D rim for sale. The rim is disc only though so you'd have to braze a mount. PM me if your interested.
    MGE
    Quote Originally Posted by mountaingoatepics
    MGE
    Thx Jeremy!
    I think the Alfine is not ideal for my plan... I am looking for narrower spaced and am hoping to go with a coaster brake (so that I don't have to deal with any other cables or braze mounts).
    ride
    Reputation: ignazjr's Avatar
    Quote Originally Posted by ds2199
    Specs:
    steel frame
    Thanks!!
    I've got an old 3sp SA wheel and shifter here for you if you want. Believe it's 110 as well.
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
