Results 1 to 8 of 8
    Reputation: cbgoring's Avatar
    New wheelset for Transition Bandit - Arches or Flows?
    Right now I have a set of Mavic 819s. The back one has quite a wobble that can't be trued, so I'm looking at building a new wheelset. I can get a deal on either a pair of Stan's Arches or Flows (Not ex). I'm 5'7 and 160lbs with gear. I ride aggressive, like to run 2.4 tires, and ride every rocky/techy trail the front range has to offer. Which set should I go for? Thanks much!
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Flows. I had a set of Flows built for a Turner 5 Spot, and the same wheelbuilder built a set of Arches for my Jet9 RDO. The Arch set needs a new rear rim, the Flows have never even been trued.
    Kaj
    Kaj is offline
    Reputation: Kaj's Avatar
    Flows for riding hard, Arches for saving weight and replacing every now and then.
    Kona Wo for Fat Biking, Ibis HD3 for Trail Shredding, Merckx Road bike for collecting dust
    OP: Are cheap carbons w/in your budget...~$400 to your door for a pair.
    Quote Originally Posted by Pau11y View Post
    Do tell. Where do I get a pair of carbons for $400? Thanks!
    Reputation: sfgiantsfan's Avatar
    Dec 2010
    Im 6'3 220 and ride the Flow EX and beat the crap out of them and only had to true them once. They are great wheels and I imagine the Flow's would be fine for your size and weight.
    I'm sick of all the Irish stereotypes, as soon as I finish this beer I"m punching someone
    ride
    Reputation: ignazjr's Avatar
    Whichever you get, make sure to build them with brass nipples so they will be more tuneable down the road. Little heavier but it'll make for a longer lasting wheelset.
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    Quote Originally Posted by cbgoring View Post
    Just scroll down a bit and look, or search this forum, for "group order". I started one and _mk finished it. Maybe you can arrange for another...?
  1. Flows vs Arches
    By bikeriderguy in forum Wheels and Tires
    Last Post: 09-14-2017, 05:50 PM
  2. Transition Bandit 29.........
    By ChampCyclist in forum Transition Bikes
    Last Post: 04-13-2014, 11:56 AM
  3. Built my first FS 29 - Transition Bandit 29
    By Jonesy22 in forum 29er Bikes
    Last Post: 02-26-2014, 06:32 AM
  4. Transition Bandit 29er
    By LeeL in forum 29er Bikes
    Last Post: 08-25-2012, 06:03 PM
  5. Transition Bandit
    By buckshotsktm in forum Transition Bikes
    Last Post: 07-12-2011, 02:31 PM
