    how heavy are you ??
    Reputation: Scottay5150's Avatar
    i have some juicy 7's ...
    and I am thinking that there is too much fluid in the lines. The margin of error is too little for pad to rotor contact (i.e. rubbing). Can I take some of the fluid out of the lines and if the pistons are sticking a little can I un stick them with having to re bleed them?
    Scott
    P.S. how much space between the rotors are there supposed to be between pads and rotors anyways?
    Schipperkes are cool.
    Reputation: banks's Avatar
    Push the pads back into the calipers with a medium-large flathead screwdriver and get it to 'stick' between the pads. Take the Torx #7 to the bleed port in the lever and slowly loosen it with a rag. Excess fluid will piddle out.
    Scoty
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Living the High Life
    Reputation: Ithnu's Avatar
    Feb 2007
    Yeah, you probably just need to push the pads back. I usually put some electrical tape around my screw driver just to avoid taking any chunks out of the pads.
    Card Carrying Member
    Reputation: kitchenware's Avatar
    pull the pads, then push the piston.
    juicy's have the worst factory bleed imo.
