Results 1 to 37 of 37
    Wish I was riding
    Fellow AC Riders
    I picked up one of those Giant AC's down at Supergo a while ago, and finally got it built up. (it was torture just looking at the frame sitting in my room begging to be ridden!)
    Anyways, all you other ACs out there: what's the deal with the seatpost? Comes with a 30.8 to 27.2 shim. I'm running a 30.9 right now, but it stops short where the seat tube narrows. Do I have to run a 27.2, or will a 30.8 fit all the way down?
    What are you guys running? Okay...enough about seatpost.
    [thanks]
    locked - time out
    Reputation: s1ngletrack's Avatar
    Unfortunately you have to run the stock size seatpost with the shim - the seat tube tapers - and I have actually had a guy from Giant tell me that my warranty is void if I do not use the shim when I called to ask about it... oh well. Enjoy your new bike.
    Wish I was riding
    thanks
    Thanks for the info. I've heard bad things about shims, so I was hoping to avoid using one. Why are shims so bad anyways?
    I Want My Bike!!!!!!!! Now!!!
    Card Carrying Member
    Reputation: kitchenware's Avatar
    I've been using the shim without problems. No movement, no creaking... nothing...
    locked - time out
    I think that people just dislike shims because they seem like a "band-aid" fix - to the best of my knowledge, there's nothing really bad about them - they're just annoying.
    Quote Originally Posted by s1ngletrack
    They work very well in this application. Just dont lube between the shim/frame... post/shim lubing is ok, but shouldn't even be needed.
    BTW, anyone know what size/pull front der this thing takes? I'm thinking I need a granny ring up front. I guess I can redeem myself by only putting one gear back on the Chameleon.
    Shinobi-Wan Kenobi Moderator
    Reputation: kristian's Avatar
    Quote Originally Posted by kitchenware
    Just get a new XT front derailluer--it works top and bottom pull and has shims to fit all three sizes. Of course, if you can figure out how to do it based on the shitmano directions, you're a smarter man than I am. I figured it out eventually (hint: ignore the colors in the directions).
    For Bike Addict: In terms of seatpost shims, I am using them on both the Fluid and the Bullit. As long as you grease between the shim and the seat tube and don't grease between the post and the shim, you shouldn't have any problems with them.
    Quote Originally Posted by kristian
    good thing I haven't put anything on my post. I think it gets moved around enough to keep it from seizing.
    Oh, and I'm going to go grab one of those XTs after lunch. Thanks for the tip.
    One thing I didn't mention, it's the bottom swing XT that has the shims and is bottom or top pull. I'm not sure if the top swing one has them or not (although, I'm not sure why you would use a top swing unless you're frame requires it).
    Perpetually single track
    Reputation: ibmkidIII's Avatar
    Would somebody PLEASE explain the differences of all these freaking front derailleurs please. Top/bottom Swing, Top/bottom pull (which I think I understand), and e-types...so confused...so confused...
    BTW, Kristian, making a fresh batch of jerky this weekend...ahh yeah!!!!
    Quote Originally Posted by ibmkidIII
    Top swing is the old school looking derailluer with the clamp about 2" above the level of the big ring. They are always (to my knowledge) pulled from the top. Bottom swings have two different types: top pull and bottom pull. The clamp about the same height as the granny ring and the cage sits above the clamp. The pull is the direction from which they are pulled. Some bikes run the cables down the down tube and under the BB up to the derailluer (oddly enough, that's called bottom pull) while most bikes run the cable along the top tube to the seat tube and pull from the top.
    E-types are designed for bikes that are either lacking a seat tube or that have too much suspension crap down there to attach a standard derailluer. The E-type has a ring that goes around the BB to hold the derailluer in place (and sometimes they have a little clamp to stablize them on the seat tube too). I have never met anyone who used an E-type who didn't swear a blue streak at the thing...
    mmmmm....Kirkyjerky!
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    e-types are a mounting type that are mainly used for unusual frames that can't use typical mounts, and I believe most of the frames that use e-type are Specialized.
    Top/bottom pull has to do with where the cable is pulled from.
    Top/bottom swing I really don't know either.
    Now Uploading
    Reputation: mtbdirteater's Avatar
    I put an XT top pull-top swing 34.9 FD on my AC. With an e.thirteen DRS. See pic for what a top swing FD looks like. A bottom swing will not fit, as it would not fit on the frame with the seat tube shape below it. Yes, the new 760 XT "dual-pull" works, but the little arm you wont need for a bottom pull install comes very close to that screw coming out of the back of the bottom of the seat tube (is this to clamp the loose end of the FD cable in?). Mount it high enough so it doesn't hit it like in this pic and you will be fine. Or you could cut off the excess arm for BP with a dremel tool.
    BTW, on the post, I too tried a 30.9 post, but it won't make it down past that ridge inside the frame, so you do need to use the 30.8 to 27.2 shim with a 27.2 post to be able to drop it down, but watch for how far it can protrude out the bottom, I had to cut my 27.2 post to 250mm length to keep it from hitting the shock coil when dropped all the way.
    My Giant XTC hardtail came with a 27.2 (Titec, which I promptly broke and had replaced) post with a shim in it, and it caused nothing but problems and creaked terribly regardless of how much lube was where. So I replaced it with a 31.6 Thomson and it's been perfect for the last year and a half. If Giant says that voids their warranty that they can welch out of because they get better deals on bulk 27.2 posts that they can use in more bikes with cheap shims, then screw that bike company very much. I only bought this AC frame because it was $299, but I like riding it. And the warranty would have been void on my Giant XTC frame anyway, I kept trashing the internal headset and had some CNC adapters spin and pressed in and faced in my frame, becoming part of the frame, and installed a regular CK headset in it. The best thing that ever happened to that bike. If this AC frame/headset gives me any problems at all, I'm doing the same to this one.
    Cheers,
    Dave
    Just Passing Through: eatin' dirt & crappin' dust
    Arrrgggghhh!!
    Reputation: BBOC's Avatar
    I broke the stock 27.2 post and replaced it with a 30.8 thinking it would be less of a pain in the ass. I still have it on, but you really lose the ability to lower your seat as the post hits the bend in the tube much sooner than the 27.2 does (which is already too soon). I would not recommend it regardless of warranty issues with Giant.
    Give 'da people 'da air.
    Now Uploading
    e.thirteen makes a special DRS bracket that is e-type mount if you have to use one, saw one on a VP-free. Looks beefier than the standard e-type bracket if you are using a dual-ring guide anyway.
    http://www.e13components.com/images/...E-type_600.jpg
    Cheers,
    Dave
    Thanks Kristian...I know have a much better understand of front D's now. I have to assume my heckler is a bottom swing/top pull. It's mounted just above my middle ring....I think I'll poke over to the SC forum and double check that...
    edit: nope, top swing/top pull....
    Reputation: Air-Time's Avatar
    Dec 2004
    Quote Originally Posted by mtbdirteater
    Cheers,
    Dave
    Just wondering about the DRS you got on your AC. Im thinking of getting one for my stock 2004 AC2. Is there anything specific I should ask for when ordering one ?.
    Apart form that are you happy with the DRS ?
    Air-Time
    Now Uploading
    Quote Originally Posted by Air-Time
    No, just get one with the 2004 rubber roller if you want it quieter, or the older (still available) hard (plastic?) roller if you want longer wear out of the roller (they are only about $16 to replace). My DRS came with ISCG mounting holes on the backplate which you can't use on the AC anyway (mounts with the drive side of the BB or bearings). I only mention it because if you or someone else were to install a DRS on a frame that actually had ISCG mounts on it (like my Chase where they are so far misaligned/rotated that they were not usable), I am told from e.thirteen that the new 2005 model DRS may not have the ISGC holes in it any longer.
    Also note that if you are using Saint cranks, you will need an e.thirteen 2005 bash with the wider crank indentation, the old one won't clear a fat Saint crankarm. Just don't get old store stock if you need the new one. You can tell the new bash because it has the e.thirteen name and logo embossed into it in addition to the regular white lettering on it elsewhere.
    Air-Time
    Very much so, everything e.thirteen I've ever used or installed rocks!
    Cheers,
    Dave
    I was about to bump this thread back up anyway today... I had a question for you other ACers.
    What's your weight and spring rate? Anyone find that the stock 500 wasn't enough?
    locked - time out
    I think I'm actually running 450 (I weigh 185) - my frame is an 18". I considered swapping it out, until I buried the red volume adjustment on the Swinger. I don't think I've bottomed it since.
    I'll try that...
    locked - time out
    I'll try that...
    Don't forget to let the air out before you crank it down - I almost did, it'd suck to blow a seal sitting in your garage.
    hehe, I have to let the air out first, my pump can be used to tighten it down when it's empty.
    Dec 2004
    [QUOTE=mtbdirteater]No, just get one with the 2004 rubber roller if you want it quieter, or the older (still available) hard (plastic?) roller if you ...........
    Thanks for the info, But how did you mount it to your AC if the ISCG mounts dont fit the AC frame ? Is it something to do with the E-Type Boomerang "e.13" have on their website ?
    Air-Time
    Now Uploading
    [QUOTE=Air-Time]
    Air-Time
    The DRS mounts sandwiched between the bottom bracket shell and the bottom bracket. Rotate it to where you want and tighten the BB.
    Cheers,
    Dave
    Now Uploading
    500 spring on mine, sometimes I think it feels a little too light. I'm about 175lbs., got 130psi in the SPV chamber and 2.5 turns down on the red bottoming nut on my Swinger 4-way at 6.3". Close to bottoming at times, but not a big issue most places. Rode it downtown a few times and regularly bottomed it, would turn that red bottoming nut down all the way next time.
    Dave
    Dec 2004
    Cheers,
    Dave
    Dave
    Have you had any clearance problems since fitting the DRS ? Either the DRS being to close to the swing arm, the chain running to close to the tire (what size tire are you running), the cranks being to close to the swing arm ?
    Air-Time
    Now Uploading
    Dave
    Air-Time
    No problems, except I have bashed the DRS roller on a few things hard enough to have it move, uh, rotate up towards the swing arm, once hitting it. Required loostening the BB bearing and moving it back later, but no ill effects. That problem would have been solved perhaps if the AC would have had ISCG mount holes... however, the 2005 DRS backplate is supposed to be without ISCG mounting holes now, so... BB mount only on the new one.
    I had RaceFace Diabolus cranks on it, lined up perfectly, swapped cranks between two bikes and now have Saints on it. I have two of the three 2.5mm BB spacers on the left side, and one on the drive side with the DRS plate. Good chainline. If only one 2.5 spacer on the left side, the Saint crank arm right at the bottom bracket bearing would be very close to the swingarm. I have 5mm of space (I just measured it) between the plastic plate of the DRS and the tire, but the tire is behind that, so it would never hit it, even with a wider tire. I am running a Maxxis Minion R DH 2-ply 2.35 on the back of my AC (on a 2003 DeeMax rim). I'd put a 2.5 back there, but mud clearance would suffer. But Maxxis 2.5 Minions are narrow 2.5s, so wuldn't be much difference.
    Go for the DRS on your AC, I'm riding mine as a freeride trail bike and need to be able to climb on it, single chainring wouldn't cut it for me, this ain't a DH bike I built here.
    Post pics when you get yours built with the DRS.
    Cheers,
    Dave
    Dec 2004
    Cheers,
    Dave
    Thanks Dave
    What size bashring did you get ? 36T or 40T ?
    Air-Time
    Now Uploading
    Thanks Dave
    Air-Time
    36T. I'm using the 22/32 rings from the Saint cranks. Had considered swapping out for a set of steel Deore 26/36 rings that I've got though.
    Cheers,
    Dave
    Now Uploading
    Idea! Loose shim
    I just got tired once and for all with this 30.8 to 27.2 seat post reducer shim in my AC pulling out when I pull the seat back up, so I got medieval on it's arse. I jammed some alcohol (isopropyl, not Heineken...) soaked shop rag down the seat tube to clean it and brushed in some contact cement. Same on the shim. Greased the post, and it looks like the shim is staying put now. Yeah, you do need the silly shim to be able to drop a 27.2 post down through the odd seat tube, already tried a 30.9, it won't make it down past the ridge part way through the tube.
    It's always these little things that eat at me the most...
    Dave
    Dec 2004
    No problems, except I have bashed the DRS roller on a few things hard enough to have it move, uh, rotate up towards the swing arm, once hitting it.........
    Cheers,
    Dave
    Dave
    All done and dusted, the DRS makes a big difference well worth the cash.
    Cynical Bystander
    Reputation: COmtbiker12's Avatar
    Dave
    That's just about the sweetest looking AC I've seen. I think mine will have to look something like that.
    Tony
    is making a comeback.
    Turns out that five years of not mountain biking, really makes one strive to get back to it.
    wow, nice setup. How much does it weigh? Mine has a Z1 FR3 and Im guessing it weighs around 35-40 lbs, although I dont know for sure. Just curious.
    Now Uploading
    Dave
    Awesome. Like that fork on there.
    Cheers,
    Dave
    Dec 2004
    Quote Originally Posted by twouareks
    It's bang on 35 pounds. Some other details for you....
    2005 Marzocchi 66RC (150mm) fork, 2005 Fox DHX 5.0 (7.5x2.0) rear shock, Shimano XT derailers front/rear, Raceface FR BB (isis) & Evolve DH 22x32 Splined cranks, e.13 DRS chainguide and e.13 bashguard. Sun Rhyno Lite Rims 26x36H, Panaracer Fire FR 2.4 tires and Hayes HFX-9 HD Hydraulic Disc w/8� Rotor.
    I kept the bike setup so I could still comfortably ride up hills, which is a must around these parts. It's long enough in the travel to easily cope with the big hucks + the big offs which usually follow atempted big hucks.
    Air-Time
  1. Giant Ac Riders: What Fork Do You Use?????
    By twouareks in forum Shocks and Suspension
    Last Post: 11-02-2004, 12:13 PM
  2. fellow fsr xc riders
    By shvedraki in forum Specialized
    Last Post: 09-14-2004, 12:03 PM
  3. Calling out to fellow Toronto riders
    By precar in forum Eastern Canada
    Last Post: 06-18-2004, 10:11 AM
  4. Name's of fellow Utah riders.
    By Bikerdude in forum Utah
    Last Post: 04-14-2004, 01:56 PM
  5. Fellow Riders are never strangers
    By element in forum North & South Carolina
    Last Post: 03-29-2004, 09:08 PM
