Results 1 to 23 of 23
Thread: Best mini pump?
    Reputation: edenger's Avatar
    Best mini pump?
    Edited: What is the Best Mini Pump for the Front Range?
    I have had nothing but useless minis and I now add Crank Brothers power pump to this list after having two break on me.
    Oh, So Interesting!
    Reputation: davec113's Avatar
    Quote Originally Posted by edenger
    Anyone have a good pump recommendation? I have had nothing but useless minis and I now add Crank Brothers power pump to this list after having two break on me.
    Is this "For the Front Range"?
    Stiff yet compliant
    Reputation: Moustache rider's Avatar
    I have been liking my Lezyne alloy drive. Compact, light and it has a handy hose that stores inside the body when not in use. It actually appears that the entire thing is made out of metal. You know, metal. That stuff lunch boxes and cars used to be made of.
    It is also Front Range compatible.
    bacon! bacon! bacon!
    Shread Ready
    Reputation: Thrasher's Avatar
    Jun 2005
    Quote Originally Posted by SkaredShtles
    Yeah, for CO2's this one is great! I've been using it and it's perfect for my mini-MULE Camelbak.
    Reputation: BobGolden's Avatar
    That's been my mini pump for the last 5 years, never has let me down.
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    I haven't found one that will automatically make my bike yield to uphill riders, but I have had good results with the following pumps:
    • Blackburn Mammoth
    • Lezyne Alloy Drive
    The Lezyne is nice because the flexible rubber hose reduces the likelihood of damaging the valve. I use the higher-pressure version on my commuter, and it's been a godsend. One tip: attach the hose to the valve first, and THEN attach the hose to the pump.
    And because I'm anal, I also carry a CO2 inflator. Lezyne has one that uses all metal construction, and it works great.
    GRAVELBIKE.COM - ride everything
    formerly Nomad rdr
    x2 on the Blackburn mammoth
    I have the 2 stage and it fills fast
    Your bike is incorrigible
    Reputation: Guyechka's Avatar
    Lezyne. Period. End of debate. What is more crucial is finding the best patch kit for the front range. And why the hell do they give you so much glue if they expect you to only smear a thin film? I always end up with at least half a tube left after the patches are gone. They ought to stop including so much because that is certainly not the way to do it on the front range.
    Quote Originally Posted by Guyechka
    Team Inflexible
    Reputation: Jaydude's Avatar
    Mar 2006
    + whatever for the Lezyne. I see this pump lasting me forever!
    Reputation: ds2199's Avatar
    Quote Originally Posted by Jaydude
    Lezyne PERIOD.
    One note on the "forever" thing. Make sure when you put the hose back inside the pump after use that you tighten it well. I saw a the hose peice on a trail once and I'd hate to be that guy when he went to grab his pump when he flatted and found that there was no hose.
    friend of Apex
    Reputation: WKD-RDR's Avatar
    Crank bros failure? Go figure
    Blackburn Mammoth has been bulletproof for me, and they are on Chainlove for like $8.99 (plus $19.99 S & H)
    the drugs made me realize it's not about the drugs
    I don't know. I'm always afraid of glueless patches. Tried some others and found that they were ok for a quick fix but wouldn't last.
    friend of Apex
    They're fine for the quick-fix. They last until the next time the tire goes flat in my experience. Which is OK - 'cause I toss the tube if there's more than one hole in it.
    Thread Terrorist
    Reputation: IndecentExposure's Avatar
    $2 and a hot chick to blow up your tire with her pump.
    Golden Bike Park Group
    Peak Cycles Gravity Team & Bikeparts.com
    Trestle Bike Park
    Thread Terrorist
    One you can beat a dead horse with (good for these forums)
    My favorite is something high-volume. Those itty-bitty-#itty pumps will get you into jerk off shape, but your buddies will be on down the trail by the time you finish. Get something that is the largest you want to carry and has very few moving parts.
    Trestle Bike Park
    Yappy little dog!
    I use this:
    http://www.lezyne.com/products/hand-...floor-drive-hp
    It's pretty damn cool and a very solid construction. The looks I get on the trail when I help with flats and tell them to wait while I get my floor pump out of the pack, are priceless.
    I like the CO2 as well, but more for getting a Stan's tire seated. I am always afraid I won't have enough whippets with me, that a pump provides more piece of mind.
    Kaj
    Kaj is offline
    Reputation: Kaj's Avatar
    Lezyne Alloy Drive #1
    Blackburn Mammoth #2
    I still have my blue anodized Blackburn Mammoth from 1996(that's 15 years old), it just won't fail. I went thru 3 of them in 1995, then I started keeping it in my camelbak--keeps going and going.
    I recommend the Lezyne a bit more though, as it's got the hose so you don't bend and break the end of your presta valve.
    Kona Wo for Fat Biking, Ibis HD3 for Trail Shredding, Merckx Road bike for collecting dust
    hehe ...you said "member"
    Reputation: jake7's Avatar
    I'll have to check out that Lezyne.
    I've used the Blackburn Mammoth with good results, but I did just snap off a stem on my spare tube a few weeks ago. The hose is a nice feature.
    “Me fail english? Thats unpossible.” - Matt Groening
    "Oldfart from Wayback"
    Reputation: onbelaydave's Avatar
    What's a "tube" ?
    I thought this was the tubeless Front Range Forum.
    I'll have to check out the Lezyne.
    I carry an el cheapo Topeak Road Morph that I got for "free" with an REI rebate. Big volume/light weight.
    Thanks for the input -- just ordered myself a Lezyne.
