Results 1 to 33 of 33
    rubber side down
    Reputation: russman's Avatar
    Apr 2005
    Best Chain Lube for FR
    I need some good advice on what you find works here on the Front Range for keeping your rides smooth. I've been using Finish Line dry lube for the past 2 seasons, and I'm tired of chipping the wax/dirt crap off of my deraileur. It just seems to always gum up the works. It also is not very cold weather tolerant. I bought a thing of Pedro's Road Rage (it was cheap), and hate it. Even for my road bike...it's narsty. So what do you guys use that works and works well?
    R
    enlightened.
    Dec 2005
    Wd-40
    Reputation: Kaba Klaus's Avatar
    Quote Originally Posted by athalliah
    Wd-40
    Feeling like being nasty today?
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
    Reputation: BaeckerX1's Avatar
    Oct 2007
    I've had some good success with Rock N' Roll Gold lube so far. It seems to repel dust even. Chain is pretty clean even when rear wheel has a coating of dust all over it. It also doubles as a cleaner, so it's pretty easy to clean your chain and re-apply at the same time. They should stock it at most bike stores. I personally found some at Bicycle Village by my work. That being said, I haven't had it on there long enough to give extensive feedback on it. It does seem to be working well so far though.
    http://www.rocklube.com/products_detail_gold.html
    http://www.competitivecyclist.com/ro...4190.52.1.html
    Reputation: edenger's Avatar
    I'm a fan of the Finish Line Dry Teflon -- hate Tri-Flo and white lightening.
    pain intolerant
    Reputation: jradin's Avatar
    I like ProLink. Definitely keeps my chain cleaner then Finish Line.
    @2whlfun
    I've been really happy with Dumond Tech "lite". I wipe the chain thoroughly before & after applying which is important with all types to avoid build up and collecting dirt. I use it on my road bike & mtb. I put it on almost every ride just to keep things smooth and quiet.
    http://www.backcountry.com/store/DMD...brication.html
    I used white lightning until my chains started kinking/developing stiff links.
    ride
    Reputation: ignazjr's Avatar
    Rock and Roll Gold is really good but only seems to last about 1 long ride for me. For something that is 99% as clean as the Gold but lasts a little longer try RnRs Extreme, the blue stuff.
    Pro Link was probably my favorite before I found RnR. I've also been using Squirt, which has been really, really good. It's just a little tougher to find.
    dave
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    <100%
    Reputation: JackJr's Avatar
    Pro Link Gold until things get really messy, then Tri-Flo.
    "Oldfart from Wayback"
    Reputation: onbelaydave's Avatar
    ProLink Gold
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Rock and Roll blue is my all time favorite, thus far.
    I think what I'm using now is the Finish Line Pro Road lube, which I found at Performance, and it seems to work OK. Not quite as good as the blue stuff, but not bad, neither. Little build up, but doesn't seem to last as long.
    I've also tried the Dumonde Tech Lite lube which seems to last a good amount of time on my townie but it worthless on my MTB.
    Pedro's is the worst garbage lube I've spent money on.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Team Inflexible
    Reputation: Jaydude's Avatar
    Mar 2006
    T9 rules them all
    I have tried them all and think T9 works the best. Even better than Rock and Roll.
    Does not gum up as bad as the others and keeps the chain slippery.
    Wax based lubes plain suck.
    MK_
    MK_ is offline
    carpe mañana
    Quote Originally Posted by Jaydude
    How can you say T9 is best and then say wax lubes suck?
    _MK
    Not just famous; infamous
    Reputation: coolhandluchs's Avatar
    Good job! Boeshield T9
    +1 for Boeshield, even though it's wax-based.
    (Damn, MK beat me to the punchline)
    I've used T9 for years and haven't found a reason to switch...other than it can be hard to find locally for some reason.
    Your retarded
    Reputation: Nickle's Avatar
    Quote Originally Posted by MK_
    _MK
    Tears... tears, I tell you... I'm laughing so hard it hurts....
    A trail that’s too difficult wouldn’t exist because it’d never be used. But, trails can exist that’re too difficult for you.
    Oh, So Interesting!
    Reputation: davec113's Avatar
    Amsoil 5w-30 synthetic for the last 6 months or so... same stuff that's in my Subaru. The results are that my chain picks up a little more dirt, but it's not accumulating anywhere either. You only need to use it every few rides, and if you forget its no big deal because it wears off so gradually. Some crap I've tried lasts halfway through a long ride and wears off real fast. Amsoil isn't cheap at $10/quart, but thats about 8x less than a lot of chain lubes.
    I think I can.
    Reputation: JOEMTBR COLORADO's Avatar
    May 2005
    Quote Originally Posted by davec113
    Wd-40
    Are you two just bored of the question, really
    This is such a serious subject and people really do want to know
    For the original question I have been using ProLink Gold as well, tends to only be good for one ride but does not build up.
    As with others on this post White Lightning built up like a melted candle and chipping off old wax was not my idea of fun.
    No one has mentioned the old rule, Oil based for wet conditions and Dry Lube for normal FR conditions.
    Any other thoughts?
    Dam,
    Bikes are FUN
    Reputation: skullybones's Avatar
    I have been running Squirt for the past month, riding every day. Can be hard to find, but is definitely the best out there for all weather conditions. To clean the chain, simply wipe with a toothbrush and reapply. Boeshield T9 lubes well, but does not last past one long ride.
    ..ouch
    Reputation: thump's Avatar
    Quote Originally Posted by edenger
    +1 for Finish Line Dry Teflon
    Reputation: lginzkey's Avatar
    Boeshield T-9
    I've been mountain biking more than a dozen years and have tried many different lubes. T-9 is my favorite. Here's why. First, it is very fluid and penetrates quickly and easily. Second, it wipes off cleanly and won't leave a grease streak on anything that might rub against the chain. Third, it does not attract dust and dirt. I clean and lube the chain regularly, so can't testify how many rides one application is good for.
    For the record, I use a Finish Line chain cleaner tool (good sale price at Performance Bicycles) with ordinary naptha (purchased by the gallon every few years at a local petroleum distributor). With this set-up I usually go through just one chain a year, even with lots of hard riding.
    ride
    I think it's also important to note that all chain lubes (even the good ones) are not a good match for everyones style of bike maintanence. Some of the dry/synthetic lubes out there need a lot of time (overnight) to setup and harden on the chain. If you're a lube it then ride it type, you won't have as good of results with those kinds of lube. One thing that I often recommend is to clean your chain then lube it as soon as you are done riding. Your chain will be all set up for the next time you head out.
    Redstone Cyclery
    web - tweet - FB
    Lyons, CO
    hehe ...you said "member"
    Reputation: jake7's Avatar
    Quote Originally Posted by twowheelfunman
    +1 on Dumond Tech Lite. This stuff is great in dry climates - doesn't build up/attract dirt on your drivetrain.
    Also, and maybe it's just me, but this stuff smells GREAT. Even my kids love the way it smells. Weird? yeah, but that's my $.02
    “Me fail english? Thats unpossible.” - Matt Groening
    _MK
    My experience with T9 is it attracts dirt and builds up easily without too regular of maintenance.
    Wd-40
    Obviously a joke ... but one thing that WD-40 works well for is to de-grease your chain before cleaning and re-lubing it.
    Also works well to get those gummy stickers off your skis that they stick on when doing tunes.
    bacon! bacon! bacon!
    Spit's better than any of the $hit recommended here.
    And it's free.
    friend of Apex
    Reputation: WKD-RDR's Avatar
    I've used chap stick in a jam. Better than spit
    the drugs made me realize it's not about the drugs
    Quote Originally Posted by WKD-RDR
    You've never used spit. So STFU.
    friend of Apex
    You're right, spit is a great lube... on BrokeBack mountain.
    This is the FR, sir
    Whoa. I'll have to take YOUR word for that, my good man.
    NTTAWWT.
    Yappy little dog!
    3 in 1
    But, only if it's in the old fashion tin man lube can. You have to have some rust in there for it to work right.
    Home of the Gravedigger
    Reputation: jkaber's Avatar
    Nov 2006
    I'm a chain lube snob. I've tried them all, and here it what I like:
    Mountain Bike: Rock N Roll Gold
    Commuter: Rock N Roll Extreme - Blue
    Road: Dumonde Tech Lite
    Cables: Rock N Roll Cable Magic
    Der. Pivots: Pedros Road Rage or Pro Link
    Yappy little dog!
    Quote Originally Posted by jkaber
    Holy crap! You spend more on lube than I spend on hookers!
    Umm... That is a joke. Just in case.
    Dude...
    Reputation: Jessep's Avatar
    I use "demon semen".. Just tried to google a picture for this, don't ever do that.
