Results 1 to 5 of 5
    Towlie for prez
    Alu frame repair/welder in Boulder area?
    Can anyone recommend a builder/shop,etc to take a look at my cracked frame and see if it can be repaired? It cracked at a weld.
    Thanks in advance!
    Almost Human
    Quote Originally Posted by shoulderfu View Post
    Thanks in advance!
    I've always been under the impression that repairing an AL frame is risky.
    Reputation: pulser's Avatar
    Dec 2004
    You can't repair an aluminum frame its junk. What happens is you reheat treat the area and make it more brittle. It cracked in the first place because the weld was too hot.
    May 2013
    Good excuse to throw away that AL frame and invest in a different material that has more durability.
    Reputation: bikepunk13's Avatar
    Mar 2012
    Quote Originally Posted by pulser View Post
    This is not entirely true. Aluminum can be re-welded but it must be heat treated again after. If a frame is 6061-T6 to start with (T6 being the level of heat treatment) then welded the area around the weld returns to 6061-0. If its not heat treated again after the repair weld its worthless.
  1. Searching for a frame welder
    By Goinslo in forum Massachusetts
    Last Post: 10-20-2012, 12:22 PM
  2. Searching for a frame welder
    By Goinslo in forum Vermont, New Hampshire, Maine
    Last Post: 10-18-2012, 01:32 PM
  3. Frame repair in Miami area
    By robpad in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 08-18-2012, 03:47 PM
  4. Broken chromoly frame; how to find a welder to repair?
    By veryavgwhtguy in forum Frame Building
    Last Post: 02-26-2012, 08:50 AM
  5. Frame repair in Sacramento area?
    By meSSican in forum California - Norcal
    Last Post: 01-24-2011, 06:13 PM
