Misses elastomer shocks
1x9 chain line
So before I get chided, I did use the search function before I posted
I don't want to use one of those clunky DH chain guides, or a bash ring for that matter if I can avoid it, but I'm having one heck of a time keeping the chain on my 1x9. In fact, I've actually made it a 1x8 by taking the second smallest cog and putting it all the way to the inside of the freewheel body to act as a spacer narrowing the spread of the cassette by one full gear. This worked, mostly, but the chain still drops unless I'm in the biggest going downhill.
I'm considering shortening the chain, but I don't want to stress the rear derailleur. Is this the answer? Any other suggestions? Is this just a part of life with a 1x9?
_________________
Downhill is easy.
Use a light weight bashguard in combination with an N-Gear Jump Stop.
Armchair Sasquatcheror
Blackspire Badger
I have had great luck with the blackspire chain tensioner. I think it's called the badger. At any rate, it is a simple mount with a tension wheel that mounts between your bb shell and cup or to iscg mounts if you have them. It's lightweight, costs $25 and it's easy to install.
I use it with a dual riung set up so it should work perfect for a single ring.
"Put the Fun Between Your Legs."
what nice teeth you have
Use an old derailleur as a chaing guide. I picked up a Rohloff chain guide and use that, a bit pricey, but effective.
Also called a railleur. I agree on both ideas here. It is cheap and works like it should.
nadinno-
that thread was really helpful. thanks
_________________
Downhill is easy.
- You may not post replies
- You may not edit your posts
Forum Rules
