Results 1 to 3 of 3
    Zocchi 55 ata2's
    Opinions please, fancy a set of 55 ata-2's for a little project.
    They will be going on a jump bike frame and will be ridden wound down to 120mm.
    Use will be street, small dj and some skate park.
    They state 35mm stanchions, so if I ride them at 120mm they got to be stiff enough and up to the job right?
    I am 240lbs what you think, suitable.??
    Thanks, Scott.
    Captain Underpants
    Reputation: Random Drivel's Avatar
    Not sure that when the 55 is ridden down that you get full travel. Post this up on the suspension board for the best answer. Bet you could have the fork shortened by Marz tho. I know Fox 36's can be shortened.
    I'd prob go with the dirt jumper anyway.
    Aug 2005
    That is an expensive fork for what you are going to use it for. I would look at ordering a Marz 55 R from Nemesis Project lowered to a custom height. I know they do it for Z1 and 66 so I would assume it can be done for the 55.
