Results 1 to 6 of 6
    Reputation: starsky's Avatar
    Feb 2005
    XTR Disc Brakes - Enough to stop a Clyde?
    Hi,
    I have been offered a second hand set of XTR disc brakes. I usually run the XT's. The calipers look pretty small on these. ANyone used them? Do they have enough stopping power for XC use?
    Making fat cool since '71
    Reputation: ImaKlyde's Avatar
    Sep 2004
    A little late...
    Quote Originally Posted by starsky
    Hi,
    but the answer is yes they are fine for a clyde's xc needs. Depending on which model year they are (and which year your xt's are) there may not even be much of a weight "savings" for you and I'm not convinced there is *any* purly performance advantages over your xt's, but I wouldn't be surprised if someone argued there is a minimal increase...
    Ride well.
    Kraig...
    Are the wheels roundish? Ride it.
    Disciples Of Dirt, come ride with us.
    Feb 2005
    Thanks Kraig.
    I went out riding this morning with a guy using Avid Juicy's. Incredible stopping power!
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Assuming you are comparing them to the new 2 piston 765 XT's then the stopping power is the same. Functionally they are the same brake. The XTR has a shaved down caliper to sve weight.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    In case of doubt,
    Hi,
    upgrade front rotor to 180mm . I did that with my 765 XTs and love it.
    Cheers,
    Cris
    Feb 2005
    Thanks guys.
