Results 1 to 12 of 12
    Oct 2012
    Wheelset - Deore M590 / Velocity Blunt
    Replacing my broken 26 with a 29er build. Went over everything at the LBS but wanted some Clyde approval before they start the build
    Carrying over drivetrain, etc. basically adding a 24" Surly Ogre frame and a custom wheelset consisting of Deore M590 36 hole hubs, DT Swiss pro spokes and velocity blunt rims.
    At 6'8" / 275 lbs I destroy a lot of stuff, thus the move to a steel frame. But what about the wheelset, will it be sufficient to survive my next strava challenge?
    Nov 2008
    More road/gravel duty or mainly singletrack duty? I'd stay away from Shimano rear hubs, cheap and weak. Blunt I think will be a good choice. Make sure you use the DT Swiss Comp spokes (double butt) and not the champion straight gauge spokes.
    Thread already spun
    Reputation: Zowie's Avatar
    Aug 2013
    +1 that. If you do go Shimano, make sure you keep that freehub clean and engaging properly, seems like the engagement goes to crap once there is crap in it.
    If you have the budget, there are a some good triple butted 13/15/14 spokes out there too.
    Oct 2012
    Seemed the price gap between hubs was a little preventative at least where I live. I've ran the old shimano LX hubs for years with no issue. So far I haven't had any hub issues ever, so I went with the Deore front and back. Thanks for the tip on the spokes. The LBS was all ready to do straight gauge. Switched it over to the Comp double butted.
    Black everything including hubs spokes and rims. Looks pretty sick IMO. Coolest looking do-all I've ever owned. Living on the west coast having the ability to add proper fenders is desirable! The plastic clip on mountain fenders are just terrible.
    Attached Thumbnails Attached Thumbnails Wheelset - Deore M590 / Velocity Blunt-new-surly-ogre-0813.jpg
    I weigh about the same as you and destroyed a Blunt SL in 2500kms on my CX bike with only about 500 of that on dirt.
    I then went for a P35 and that lasted 1700kms.
    In contrast my 2009 XT wheels with 24 spokes are still going strong after 3000kms of abuse on my AM bike.
    Oct 2012
    Well here's hoping my experience differs! I got the blunt, the SL is the lighter, racier version. They looked plenty beefy to me. I ride 150km a week so I'll post back in 3 months if stuff starts falling apart.
    Chris Bling
    Reputation: dustyduke22's Avatar
    So how have they held up for you Graham77?
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
    turtles make me hot
    Reputation: NYrr496's Avatar
    I may be wrong, but isn't the Shimano M529 stronger than Deore and XT?
    I've built a bunch of 29er and fat wheels with the 529 and had zero issues.
    I like turtles
    Oct 2012
    The Velocity Blunt did not hold up. Back wheel got out of true turns out a spoke pull through basically cracked the rim right in the centre. Now have to rebuild the wheel. Going with a Sun Ringle Mx33. Reviews paint it as indestructible. Any insight is appreciated!
    Oct 2012
    The bike shop is suggesting the Mavic 719 would be stronger than the Sun.
    Chris Bling
    Quote Originally Posted by Graham77 View Post
    The Blunt and the MTX are completely different rims for completely different purposes.
    If you Blunt is pulling through the rim, its not normal. either the rim was bad or the spokes had way too much tension on them.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I'm probably way too late to the party on this one, but the MTX 33 is emphatically a stiffer, stronger, more clyde-worthy rim from pretty much every angle I can see. Less expensive to boot.
  1. Velocity P35 vs. Velocity Blunt rims?
    By danwerle in forum 29er Bikes
    Last Post: 09-03-2011, 01:49 PM
  2. Question about velocity blunt wheelset
    By mustangous in forum Wheels and Tires
    Last Post: 05-20-2011, 07:08 AM
  3. Shimano-Deore-ST-M590
    By motosig102 in forum Beginner's Corner
    Last Post: 04-27-2011, 10:14 AM
  4. Shimano Deore ST-M590
    By motosig102 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-24-2011, 12:16 AM
  5. LX FC-M582 or Deore FC-M590 crankset?
    By Hundun in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2011, 02:54 PM
