Results 1 to 17 of 17
    Mar 2013
    What tubeless pressures do you run?
    I am 245ish lbs with Bontrager Race Lite wheels and Conti X-King tires. I ran 40psi on my XR-1 tubed tires and hoping to run less with this tubeless setup. Don't want to burp flat. Any larger guys able to chime in on pressure recommendations?
    May 2005
    I'm "only 215", but might suggest 35psi rear and 30psi front. See how it works for you and then try dropping a psi or 2. Use an electronic gauge to get readings as accurately as possible and check tire pressure every time before you ride, because with tubeless it's not uncommon to lose air. I run 27-30psi rear and 23-25psi front, depending on terrain. Occasional burp, but no big deal.
    Jun 2013
    I'm 225 and I run 30 front and rear on mine. No issues so far.
    Apr 2013
    I'm 250 and I run 30 psi front and 35 rear running Bontrager 29-3 tires on Duster wheels.
    Reputation: ACLakey's Avatar
    Re: What tubeless pressures do you run?
    I am 230 geared up, running 30lb in a 2.3 Purgatory front and 34lb in a 2.2 Captain rear on Mavic Crossmax wheels. Very predictable and reliable.
    Sent from my Android in the great outdoors.
    Mar 2013
    I ran about 32 front/35 rear and they feel more firm than when I ran 40/40 with tubes. Must be the tire...
    29 2.0 captains, 30 rear, 25 front. 260 with gear.
    Oct 2011
    230 with gear here...I am running 28 front and 32 rear (depending on trail/conditions) on Stan's Arches with Conti X King with no issues...love them
    Reputation: AlexCuse's Avatar
    220 naked here. Riding the protection model x kings. With both at 2.2 24 f / 27 r was the sweet spot for me. Switched to 2.4 up front and still haven't touched the rim despite going down into the teens. Thinking I need to get to 16 or so.
    Yeah I only carry cans cause I'm a weight weenie.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by Alias530 View Post
    Start with the NoTubes "suggested" formula:
    Rider Weight in pounds divided by 7 = x
    x - 1 = Front tire pressure in PSI
    x + 2 = Rear tire pressure in PSI
    Example: 245lb rider
    245/7 = 35
    Front tire pressure: 35 - 1 = 34 PSI
    Rear tire pressure: 35 + 2 = 37 PSI
    Nov 2008
    About 340 with gear. 25 psi front Ardent 2.4, 27-28 psi front 2.35 Nobby Nic, 25 psi rear 2.5 WTB Dissent, 28-30 psi hans dampf 2.35. These are all 29er tires.
    I have been running tubed tires tubeless for the past season and run 38 psi in the rear. Higher than most posters but the tire feels like its flat running lower pressures. I'll try running tubeless tires (thicker casing) and see I can run lower psi then.
    Reputation: Locool's Avatar
    Feb 2006
    About the same size as the OP and put me in the 27-35 crowd on Mavic UST wheels and tubeless ready tires. Rolls well on hard-pack and deforms well while rock crawling the climbs.
    Mar 2013
    Quote Originally Posted by BruceBrown View Post
    245/7 = 35
    It was probably partially because the brand new tires got worn in a bit and lost whatever is on them when they're new that makes them slick, but this combo of pressures was amazing for today.
    Certifiably Crazy
    Reputation: Carloswithac's Avatar
    Feb 2012
    I'm 201 lbs and run 23 in front and 25 in the back. I'm running 2.25 Nobby Nics 29x2.25.
    2013 Felt Edict Nine
    Always Learning
    Glad to hear it. I've found that it usually is a very good starting point using that formula. Then you can adjust up or down a psi or two or three to dial it in for the soil conditions and tread pattern/tire volume.
    Reputation: Tystevens's Avatar
    About 250# on Spesh 2bliss, stock rims. I run about 32 in front, 35-38 in the rear. I tried lower psi for a couple rides (about 25 front/30 rear), but I didn't like the squishy feeling running much lower than that, and I ride in lots of rocks, so I want to make sure I don't ding a rim or burp on a drop.
    '11 Specialized Enduro Expert for the trails
    '13 Felt Z4 for the road
  1. Singletrack pressures on a 4.0
    By razardica in forum Fat bikes
    Last Post: 06-11-2013, 07:44 AM
  2. Tire Pressures
    By rockinsurfstar in forum 29er Components
    Last Post: 08-26-2012, 03:34 PM
  3. tire pressures
    By akexpress in forum Tandem Mountain Bikes
    Last Post: 03-03-2012, 01:50 PM
  4. SID 100mm air pressures
    By ironlegsracer in forum Shocks and Suspension
    Last Post: 06-11-2011, 03:43 PM
  5. Pressures for around town?
    By justin51 in forum Fat bikes
    Last Post: 01-08-2011, 06:30 PM
