Results 1 to 13 of 13
    May 2013
    What tire pressure do you run.
    So I'm curious on what some of you guys run for tire pressure and what size width tire.
    Im runnning 50 psi with a 2.0 tire. After My Seat purchase I am going to Go to 2.2 or 2.3 tires.
    Reputation: Nubster's Avatar
    My rear is a 2.2 and I run 45-50 psi. I run tubes so I ride high pressure to avoid pinch flats. Someday I may try tubeless...just haven't made the jump yet.
    Reputation: Locool's Avatar
    Feb 2006
    At 6' 5" and 245, I've been riding on 2.2s w/ 35 rear and 26 front tubeless set-up.
    Jan 2013
    Around 6'5", 250. 2.2s w/32 rear, 26 front. Tubeless.
    On singletrack.
    "How big a fella are ya", as Roy D Mercer would say.
    Are you on the trail with that much pressure? Or Roads?
    I wouldn't have much traction, with that much pressure. On dirt hills in my area.
    Me personally, yeah, I'm on trails. Dirt, mud, rocks, and roots. Traction not that bad. I could probably come down in pressure at this point. I've been running that pressure since I was 320 pounds. I'm down to 275 now so I can probably start lowering it some.
    Jan 2013
    Sorry, I was responding to the 208Ryder. Yours seems a little high also. I have been running around 35-38 psi with tubes in the rear previously. No rock gardens, but plenty rooty trail.
    Reputation: tysonnemb's Avatar
    I run 30 - 35 with a 2.4 with tubes. Also want to switch to tubeless, but slime tubes have held up until now, so I'll wait till money is available. The desert is brutal on tires!
    6'3" 200lbs, but was 235.
    “Think of bicycles as rideable art that can just about save the world.”
-Grant Petersen
    turtles make me hot
    Reputation: NYrr496's Avatar
    6'5", 255 pounds.
    Running a 2.3 up front and a 2.2 rear on 30mm rims, 30 psi front and rear.
    I like turtles
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    rim size and tire size all has to play into it... a 1.9x26 will need a higher PSI than a 1.9x29 will and a 2.5x29 will require even less...
    some tires will require less air and others more just based on how they are made.
    I found around 12psi on my 4.7x26 on the 80mm wide rim to be about right... 2psi more and it was to harsh... granted that is obviously a fat tire and I'm riding rigid.
    it's all about air volume, how much you weigh, and how you ride.
    you'll also find tire psi more important on rigid bikes...
    the best way is to pump up before EVERY ride and monitor the pressure... if you are bottoming out on the rim you need more pressure, if it feels like the tire is rolling out from under you then you need more pressure... so really it's a game of experimentation :-/
    - Surly Disc trucker
    - '82 trek 560 roadie
    Reputation: Stainless Steel's Avatar
    Mar 2013
    6'3 275
    2.10 both front and rear @ 35 psi. Tubes on both ends. I ride single track, fire roads and lots of technical trails (roots, soft sand, etc...). Only pinch flats I have ever recieved were from the tarmac at the end of my ride.
    2009 Diamondback Outlook
    The lowest I can go without pinching, then a couple more PSI for good luck.
    May 2013
    Quote Originally Posted by Bdabike View Post
    On singletrack.
    Sorry for the delay. It was the weekend and I was out riding and having fun.
    TO answer you question I am 6'3 345#
    I figure the higher pressure is better so I don't hit the rim or pinch the tubes. Even at 50psi they still flatten out a little, so the tread gets flat contact.
    I ride both street and single track. I did notice though yesterday that with it that HI on the trail it did feel a little loose. So I might let it down to say like 40-45PSI for trails.
    Reputation: ACLakey's Avatar
    6'0" 230lb with gear. Currently running tubeless 2.4 Purgatory front at 32lb, 2.2 Captain rear at 34lb. I may lower the front pressure just a tad after rides this past weekend.
  1. Tire Pressure 101
    By RideStrong in forum XC Racing and Training
    Last Post: 08-23-2013, 09:28 AM
  2. Tire Pressure Help
    By Diesel8810 in forum Wheels and Tires
    Last Post: 09-05-2012, 12:00 AM
  3. tire pressure
    By spartus625 in forum Beginner's Corner
    Last Post: 05-02-2012, 04:04 AM
  4. Tire Pressure
    By Bobcanride in forum Endurance XC Racing
    Last Post: 07-13-2011, 07:18 AM
  5. Tire Pressure
    By AllisonWunderland in forum Beginner's Corner
    Last Post: 06-20-2011, 05:49 AM
