Results 1 to 26 of 26
    What forks are the plus sized boys using?
    im 6 foot 280 pounds and my 08 hardrock comp disc has the crappy stock suntour forks that clank to the bottom every time i pedal hard. i think air is the way to go but what is everyone using?
    Nov 2008
    I'm 315lbs and I've got a Tora 318 Air fork. You can adjust the air pressure, rebound, and has a lockout. Good solid, stiff fork. Any of the Tora air's are good clyde forks. ($200-$300)
    Never ridden one, but forget about any of the Darts. Flexy.
    The past reba's are know to be pretty flexy also (2006??-2008). They have supposedly been stiffened up in 2009 for clyde use. ($400-$700)
    Reputation: Dremer03's Avatar
    I am 240 pounds and I ride on a Dart 2.
    Big Foot Blue KHS XC704r
    turtles make me hot
    Reputation: NYrr496's Avatar
    I'm 250 ona 2008 Reba 29. Been great so far.
    I like turtles
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    6'5" & 270lbs:
    Hardtail: Tora 318 Solo Air - surprisingly good "plushness" in an XC fork with air spring, 32mm stanchions, motion control compression cart and adjustable rebound.
    6" travel FS: Marzocchi All Mountain 1 w/RC2 upgrade - air/coil hybrid that easily handles my weight. With the RC2 upgrade, in addition to the coil spring, it actually has 2 air springs that each need about 15-20psi for me to run 20% to 25% sag. Quite satisfied with this one too.
    thread killer
    Reputation: WTF-IDK's Avatar
    Fox Float R 36
    BTW I'm 6 foot 300lbs
    next time
    [QUOTE=spazzy] Might as well sell your bikes, E-riding is much more productive.
    Reputation: cobi's Avatar
    Lyrik 2-step air
    6'3" 235
    Making fat cool since '71
    Reputation: ImaKlyde's Avatar
    Sep 2004
    36 Talas, Marz Z1 light, Marz MXR, Surly Karate Monkey, Hunter rigid. They all work, my fave for pure "performance" is the 36.
    Brock...
    Are the wheels roundish? Ride it.
    Disciples Of Dirt, come ride with us.
    local jackass
    Reputation: biggoofy1's Avatar
    double
    local jackass
    i really need to look into upgrading the fork on my bike seeing as im 6'8 280 this was helpful thanks for the info
    Reputation: bigtymerider's Avatar
    280
    white brothers magic 29er 110 with heavy duty crown
    Live Large
    220 and riding an '09 reba race.
    plenty stiff
    i've been told that the Sids are more flexy than the reba, is that true?
    err, 27.5+
    Reputation: AL29er's Avatar
    White Brothers is about the only Mfg I can think of that makes a coil fork with a stiff enough spring for clydes. I ran a Fluid 135mm last year and liked it a lot. For a Hardrock you would want to limit travel to 100-110mm though.
    I am a fan of the Rockshox air forks. Even in stock form they can be tuned fairly well for big guys. I have owned Recon, Revelation, and Pike forks in various models over the last 4 years without any issues.
    My current Hardtail, a Rockhopper, is donned with a Rockshox Revelation Dual Air. I dropped the travel to 110mm via all-travel spacers.
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    My new ride, Kona Hoss, came with a marchozzi dirt jumper 2 and I have bottomed it out yet. I ride on some trails with a lot of logs and tree roots. I am 6'-2", 240 lbs.
    err, 27.5+
    OhioMTB, that is a very hard fork to bottom out. The valving in it spikes to prevent bottoming and it has a progressive air chamber. I used to use one on my urban bike for doing 5-8ft drops to flat down staircases. It never bottomed. But at high speed on the trail it was kinda abusive since it didn't move fast enough. All in all a good clyde fork if you are worried more about bottoming out than about ride quality. On most trails it is fine but those rock gardens definitely are jarring
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    Lots of choices of course. If you are using quick-release, then any of the 32mm forks from Rockshox, Fox, or Marzocchi should be OK. I use a Reba (air), and have used older 32mm Fox Vanillas (coils), and they all worked well. Only bottomed out occasionally, which is what should happen. But if you are open to getting a different wheel, then 20mm (or 15mm I guess) is the way to go for us big guys. You usually can notice a difference in stiffness. I am 280 lbs using a Reba, Pike and Lyrik (and sometimes a Marz 66), and all of them work well for their purpose, but stiffness is different of course.
    That Revelation sounds interesting. I think you can get it as an air with qr? But I see those Toras on sale quite often too.
    I'm a bottom feeder...
    Reputation: CARP's Avatar
    Fox Van 36 RC2. Yellow coil. I find coil works better for me than air. The fork is smooth as butter. Great big hit small bump compliance.
    Reputation: edouble's Avatar
    I Have Two...
    White Bros Bw.8 Forks And They Are The Most Flex Free Forks I Have Ridden. Fwiw, 6ft 2in @ 260lbs
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    Masters' class Clydesdale
    Reputation: Nadamamasboy's Avatar
    I'm running a Marzocchi Z1 drop off and am bottoming it constantly. Not sure what spring I have but don't know if it's worth re-springing. I'm 225 lbs right now. Any suggestions? Thanks guys!
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    on my 29ers i've used... a rigid surly karate monkey fork (great for for a fatty like me ;-)... and a tora 318 soloair... both have done great for me...
    when you get to the higher end of a clyd weight spring forks aren't a great option as most of the companies don't have spring rates that are made for us... and thankfuly these days air forks are strong enough for us fatties... I know not long back air forks would blow under our girth... but today you can pump it to where you need to and roll on
    - Surly Disc trucker
    - '82 trek 560 roadie
    flying fatass
    Reputation: carrot_top's Avatar
    im 230 and use a 06' Marz Z1 sport....its a freeride fork and almost impossible to bottom out.....ive done some rough things with it and to this day have not bottomed it out once.......although the RS Tora's people are mentioning are a much better fork that what i run....i just bought mine because it was affordable...
    Quote Originally Posted by BeaverTail
    Should your balls sit in front of the saddle or on the saddle? Im a bit confused.
    Reputation: GTscoob's Avatar
    Is the extra firm Rockshox spring enough for a 250lb rider, probably 260lb with gear? I'm really leaning towards picking up a RS Pike but a friend is trying to convince me towards a Fox Vanilla 32
    Underskilled
    Reputation: CaveGiant's Avatar
    The cheapest good fork is a Tora 318, the ultimate probably the Fox 36.
    You will appreciate a 20mm axle if you can afford.
    I personally ride a White Brothers Fluid 150mm with 6 custom springs, two air chambers, custom seals and the offer of 6 more springs from WB if I want them!!
    Mai
    Mai is offline
    Reputation: Mai's Avatar
    Feb 2006
    Fox Float 36 20mm thru
    Two roads diverged in a yellow wood and I,
    I took the road less traveled by and
    It has made all the difference. R Frost
    Reputation: 11053's Avatar
    On the bikes: Float 36 on the FS rig and Manitou Minute 120 on the 29er.
    Off the bike: I do my share of time on the salad, dinner and dessert variety too.
    Reputation: jaewannabe's Avatar
    I know what not to use, Manitou Axel Super, I broke the arch last weekend. Looking at going with the Marzocchi 44 ATA, does anybody have any experiance with that fork?
