Results 1 to 8 of 8
    Kneel before Zod!!
    Reputation: 5 Star Bomb's Avatar
    May 2010
    Weight Limit on Fox RP2 rear shock
    Im 5'11 and 235 lbs. Is this too much weight for a Fox RP2 rear shock?
    Ride in midwest so its mostly XC riding with very little drops. Mostly going over roots, gravel, log etc.
    Thanks for the input
    Former Bike Wrench
    It depends on the full suspension frame. I believe the RP2 can hold at least 250 psi, but how much you need is based on leverage ratio and type of suspension.
    Reputation: bvibert's Avatar
    Mar 2006
    I think the max pressure on Fox air shocks is 300PSI. At your weight I think you'll be fine.
    Kneel before Zod!!
    May 2010
    Quote Originally Posted by mtnbiker72
    Gary Fisher 2010 Hifi plus.
    Former Bike Wrench
    Quote Originally Posted by 5 Star Bomb
    http://fisherbikes.com/pdf/fisherbik...up_card_10.pdf
    Hi five star,
    I'm a shade under 5'10" weigh 235 and ride a 2009 Hi Fi.
    I ride a lot of technical singletrack and "big air" (yeah right) is 18" off the ground. I'm running about 200 psi in my RP 2 and it works just fine.
    Kneel before Zod!!
    May 2010
    Hey thanks to everyone for the input.
    Jan 2011
    230lbs
    190 PSI but still loking for the right pressure.
