Results 1 to 11 of 11
    Sep 2013
    Too big for my tires
    I have noticed that my back tire gets depressed a considerable amount while I am riding. I am pretty big (6' 6", 280 lbs.).
    Is it possible to change out tires for a bigger tire and hence bigger tube to account for this without having to buy new rims?
    Any advice?
    Jul 2013
    What tire, what exact tire size and what pressure are you running front and rear?
    Sep 2013
    I have a Giant Escape bike with Giant flat-guard 700x32C with 65 psi right now which were what the bike came with.
    Nov 2008
    You need to set it at 90 psi
    Sent from my LG-P769 using Tapatalk
    Sep 2013
    Oh sorry, 65 psi is the max according to the tire but I guess I actually don't know what pressure I am using because my pump doesn't have a gauge
    Jul 2013
    Yeah you need to get a gauge and tires need to be checked and likely aired up before each day of riding. A tire pressure app on Android says at that tire size and your weight you should be at 104 psi rear and 84 psi front.
    I'm about 260 and ran 65r and 55f on 40mm tires.
    Sep 2013
    Should any tubes be able to go to that pressure? Are there tubes that can go higher
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Tubes can go much higher than that. The tire is the limiting factor. Generally, if the tire can hold it, the tube plays along just fine.
    If your frame has sufficient clearance, then you can run a wider tire. A wider tire will allow you to run less pressure, which should make for a smoother ride.
    Jun 2013
    You don't need to run that much pressure. I am 250# and run around 35# yes the tire is going to depress and widen out. This is actually what you want to happen for traction. The more the pressure increases the rougher the ride is going to be and the less your tire will conform to the imperfections in the trail causing traction loss.
    Jul 2013
    32mm tires will pinch flat with low pressure and bang up his rims too.
    Get a gauge and see what you are running. I very much doubt it is 65 if you see it deforming that much.
  1. Replies: 2
    Last Post: 10-31-2013, 08:33 AM
  2. Switching from off road tires to street tires...suggestions?
    By bpreachers in forum 29er Components
    Last Post: 04-13-2013, 10:35 PM
  3. Question about Schwalbe tires to replace stock tires
    By bosco0633 in forum 29er Components
    Last Post: 03-06-2012, 08:40 AM
  4. Replies: 4
    Last Post: 10-07-2011, 05:04 PM
  5. Wider tires, less rolling resistance, what about taller tires
    By HighLife420 in forum Wheels and Tires
    Last Post: 06-01-2011, 06:23 PM
