    May 2010
    tire pressure question
    I just bought a Jamis Trail XR. The guy at the LBS said it was fine for my size 6'2" 280.
    Anyway, went riding today and the tire look like they are flattening out under my weight. I checked the tire (27 x 1 3/8) for the max pressure (65 psi) inflated to that but they still look like they are flat.
    Any ideas, bigger tires, inflate to a higher psi?
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    You can inflate to a higher psi if you have tubes. Exceeding specified pressure with tubeless is a bad idea.
    Wider tires is a good solution.
    May 2010
    Thanks, I have Sunlite tubes. I'm going to stop at the LBS where I bought the bike and talk to them.
    Your tires aren't flat. They will bulge out a little at the bottom, but they are supposed to do that. You only weigh 30lbs more than me and I ride my mountain bike with just over half that pressure with no problems.
  1. Newbie question on tubeless tire pressure
    By ciocc in forum General Discussion
    Last Post: 04-29-2013, 02:52 PM
  2. Pressure /tire type question
    By drjay9051 in forum Wheels and Tires
    Last Post: 12-14-2012, 09:09 AM
  3. Quick Question About Tire Pressure
    By DieTheVillain in forum Clydesdales/Tall Riders
    Last Post: 01-06-2012, 11:58 PM
  4. Schwalbe tire pressure study question....
    By bing! in forum Wheels and Tires
    Last Post: 03-06-2011, 06:57 PM
  5. Tubeless tire pressure question
    By RBowles in forum Beginner's Corner
    Last Post: 01-19-2011, 02:10 PM
