Results 1 to 5 of 5
    threadless riser adaptor or 130 deg stem?
    I want to get my bars up a little higher as I am showing quite a bit of seatpost. I am wondering about advantages/ disadvantages of using either a riser adapter or replacing the 100 x 105 deg stem I am using with something like a 135mm x 130 deg?
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    I'm intrested in thoughts about the risers also... seems a riser stem would be stronger... and weigh less... but are the risers safe for real riding?
    - Surly Disc trucker
    - '82 trek 560 roadie
    Lionel Hutz, Esq.
    Reputation: Thirdrawn's Avatar
    I'd go with the new stem mainly because it's simpler and (I would imagine) stronger. You might want to consider a new handlebar with a fairly large rise, too. Take a second to look at where your hands will be with the new stem and if you'll end up 20mm or so higher, you could accomplish the same task with a new handlebar (assuming you're riding a flatbar now).
    As far as "real" riding, I can only assume this means aggressive trail riding. My opinion on the matter is that if you need the handlebars up that high, you're either 1) not doing aggressive riding but rather easy-going comfort rides, or 2) on the wrong size equipment for your intended purpose and you need to get properly outfitted before you begin a "real" ride.
    2007 Trek Fuel EX 8
    1999 Trek 7000 --- Dragonfly Green = Sexy
    2002 Trek 2100
    2008 Felt New Belgium Cruiser
    Thanks for the response. I asked becase I wonder about the strength of a threadless riser. they look kind of iffy to me. As far as "real" riding... I am riding 10 -20 miles on logging roads in a hilly area 3-4 times a week. I am OK with that. Being 6'6" tall, finding the exact dream ride has never been easy. I work at it and eventually I build something up that works for me
    some know me as mongo
    hate to say it but your not super tall. i'm 6'5" and for the most part have to problems finding bikes that fit me well and have a good bar height.
    some things to remember is that for xc your bars should be lower than your saddle. the same goes for AM and a FR bike when you are pedaling.
    BTW steerer tube extensions and high riser stems are NOT safe for offload riding. you are actually much better off using a riser bar. keep in mind though that not all bars are created equal, you will need to get a quality bar to be safe
    post a pic of your bike. for that point we might be better able to help you.
