Results 1 to 5 of 5
    Nov 2008
    Tall hardtail frame that will fit a 2.5" tire
    I just found a crack in my performance Access XCL 29er frame. I liked it because it would fit a 2.5 WTB Dissent in the rear. What are some other hardtail frames that come in a 22 or 23 inch size (around 25.5" top tube) and will fit big rear tires?
    May 2005
    I run Ardent 2.4 on front Spec SJ SS XXL amd plenty of clearance, I may put same on back since Ikon is giving me some issues
    Nov 2008
    Yeah I'm really only interested in what the frame can handle or rear wheel. If you ever mount up an ardent, let me know how it fits.
    The Misfit Dissent will handle a 2.5 in the rear. It's a little shorter than what you're after, and you'll be limited to a 1x9 setup with full-length housing, though.
    Jan 2005
    New Kona
    Have you looked into the new Kona hardtail 29er that is coming out in October?
    I think it will be called the Kona Honzo...
  1. Tall hardtail frame that will fit a 2.5" tire
    By Sasquatch1413 in forum 29er Bikes
    Last Post: 07-11-2011, 06:35 PM
  2. Trail Hardtail advice for a tall guy 6'4"!
    By bodben in forum All Mountain
    Last Post: 12-18-2010, 04:20 AM
  3. Replies: 5
    Last Post: 07-10-2008, 10:02 AM
  4. 5' 10" tall 165 lbs does a 17" frame sound to little?
    By JonBoy in forum General Discussion
    Last Post: 10-21-2004, 03:26 PM
  5. "tall" 24" rear tire?
    By fsrxc in forum Downhill - Freeride
    Last Post: 03-29-2004, 12:19 AM
