Results 1 to 9 of 9
    Super XL Clydesdale
    I am a 6'4'' 367lb Super stud But, I want to drop the weight to about 225lb. Being that I am new to the bike riding scene I need advice as to what kind of bike to purchase. Price is an issue, with only a $300 spending limit. I want to do road riding and switch to off road when I am more advanced and drop in weight. I welcome any advice with this issue.
    Former Bike Wrench
    $300 is extremely limiting...not sure there is much out there but I would recommend a fully rigid 29er.
    You might be able to find a used Redline Singlespeed 29er for that money.
    Mouth-Breather / Huffer
    Reputation: dog.gone's Avatar
    I'm with mtnbiker72 in terms of staying away from anything with suspension in that price range. $300 is going to be tough even for a rigid bike.
    If you're open to buying used, you might want to check your local Craigslist just to see what may be available.
    Going to third the recommendation for saving a bit more and getting the Redline Monocog. It will give you the best reliability in a bike, fit well, and ride well. The downside is as a single speed, it will force you to get strong. I would suggest starting out on Multi Use Trails and work your rides up from there. A great thing about a rigid single speed is it will improve your riding skills and strength.
    Riding slowly since 1977.
    Thanks for the advice guys. Guess I'll have to shell out more cash than what I expected.
    BIG and Bald
    Reputation: FireBallKY's Avatar
    Check into the Redline D440. Single crank in the front but you have 8 gears in the back. You can get this ride for between $600-$700. If you really want to get into the sport, road or dirt, you're going to have to drop a few more $$$ (especially for guys with our weight) but it's well worth it. Good luck!!!
    P.S.
    make sure you buy #1. A helmet and #2. A good pair of riding shorts ( www.aerotechdesigns.com )
    Eat to Live...not the other way around
    Plus size jersey model
    Reputation: bigworm520's Avatar
    Quote Originally Posted by FireBallKY
    P.S.
    I would agree here. Also if you find a cheap SS snag it you can always turn it into a 1x9 for pretty cheap if its not working out. I always like started my buddies out on my SS when I loan out a bike because it simplifies things for newbs, no worrying about gears and such just about riding.
    maybe someone else can chime in on the quality of these bikes, but nashbar has some beginner bikes around your price range
    being new to the sport, i would think a basic beginner bike would suit your needs.
    http://www.nashbar.com/bikes/CatalogSearchResultView?sortBy=offerprice//1&storeId=10053&catalogId=10052&categoryId=200516& searchType=categoryId&searchTerm=200516&beginIndex =0&ipState=c0%3Di%253A1%253B3%253Biphrase%2Bbundle %2Btaxonomy%2Bid%2Bfrom%2Broot%253B200516%253B%253 A200516%253B1%252C1%253B0%26q%3D30%26a1%3Diphrase% 2Bbundle%2Btaxonomy%252F%252Fv%253A0%26a0%3Diphras e%2Brelevance%252F%252Fv%253A0%26i%3Dsitemap%2Bid% 26k0.0%3D200516%26qt%3D1240692009%26qid%3Dq6Xk0G6Y 19oKr%26vid%3DvE6X90Go83FyF%26ioe%3DUTF-8%26s2%3Dsitemap%2Bid%252F%252F1%26qtid%3Dq6Xk0G6Y 19oKr%26s1%3Diphrase%2Brelevance%252F%252F0%26rid% 3Dr4mID3KZXkL1o%26s0%3Diphrase%2Brelevance%252F%25 2F0%26t%3D0%26m0%3Diphrase%2Bbundle%2Bid%26mcmode% 3Dtest&pageSize=30&cn1=f01//Bicycles:Bicycles:Mountain%20Bikes//h//2//100||
    After much research and considering my financial situation I decided to purchase a steel frame Beach Cruiser and mount Sun Black Eye rims. Hopefully this will do the trick. I will keep you informed.
