Poll: Which brakes do you use, mechanical or hydro?
Results 1 to 37 of 37
Thread: Stop!!!
    Stop!!!
    STOP!!!
    hydro or mech for XC 280+ clyde stopping power?
    Chris, 6'1" 275lb clyde, Giant Anthem x 29er w/FULL 2012 XT group, Giant Defy Composite Ultegra. Team Truly Spokin!
    Also is anyone running a 203 sized rotor for XC?
    Reputation: Bunyan's Avatar
    Hey, I'm running about the same weight as you at 6'6" and run the Juicy 7's.
    I wouldn't use anything less than 200's up front at our weight. I've got 180's in the back and the stopping power is great.
    Reputation: Nubster's Avatar
    I have Avid BB5 160's on my 29er but someday I want to at the least upgrade to 203 up front and 180 on the rear if not go all the way and do hydros. Most likely Juicy 7's when/if I do that.
    Juicy 3's and 185mm rotors here, but just because that's what came on the bike.
    Sometimes I wonder if we focus too much on thinking we need something special to handle the weight. Of course, my last bike had cantilever brakes, so anything would be an upgrade.
    Unless you have some really special need for extra powerful brakes, I'd just roll with something stock.
    My 2 cents....
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    You'll get good stopping power with either mechs or hydros. Hydraulics tend to be more consistent and require less adjustment when you first get them set up right.
    Can your frame and fork handle big rotors (durability and clearance)?
    I'm running a hydro's w/185/160 combo, its what came on the bike. I was just curious of the rest of the world.
    I know the new Reba will handle a 203 and I don't see why the rear wouldn't fit a 185.
    I'm good with what I have for now as long as I continue to improve on my cornering abilities. One of the guys in our local club has it right "I ride with one pedal partially on the edge of my abilities and the other on a banana pill.
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    185mm bb7 up front and sd7V out back... with sd7 levers controlling stuff...
    need to toss some carls prelubed cables on there still... debating between going with the 160mm rear or staying with the V out back...
    - Surly Disc trucker
    - '82 trek 560 roadie
    Quote Originally Posted by donalson
    Go disc, you can pick them up off www.pricepoint.com fairly cheap.
    actually have one but need the 160mm rear adapter... or a 185mm rotor... but because I have track ends on the bike theres more to it then that... had the hydros on your bike on the KM for a little while... things like having to loosen the caliper to get the wheel off suck lol...
    loosening the claiper to get the wheel off?
    rock crusher
    203/185 with Avid bb7 rotors on both my FS and SS 29ers. One has Avid SD7 levers, the other some cheapie Fr5 levers (I notice no difference). I weigh 235 in just shorts, and the setup works well. The 16 rotors I used to have stopped really well too... but they faded a bunch on longer downhills, and my hands would cramp up more than they do now. And, with the larger wheel, I like a larger disc size... modulation is more consistent when they heat up. I will never ever, ever run rim brakes again on a mtn. bike.
    Hydros seem to have some good performance notes, but I tend to like the simplicity of the mech. brakes.
    Former Bike Wrench
    Juicy 5's 180 (with rear 160 adapter) front, 160 rear on my 29er. Perfect braking balance IMO
    chris... i'll show you next time we manage to ride together... one of the quirks with track ends on the karate monkey doh lol
    I'll take you there.
    Avid 203 BB7 upfront (upgraded), Hayes MX2 160 rear (stock)
    Be excellent to each other.
    thread killer
    Reputation: WTF-IDK's Avatar
    I'm 6 foot 300lbs.
    I use BB7's
    8" frt
    7" rear
    on my Heckler
    next time
    [QUOTE=spazzy] Might as well sell your bikes, E-riding is much more productive.
    Reputation: njbiker66's Avatar
    Hope M4's 185 front and rear with floating rotor.
    Mouth-Breather / Huffer
    Reputation: dog.gone's Avatar
    6'2" (+/-), 280#, XC
    I upgraded my Peace 9r to 185mm Avid BB7s front and rear with Speed Dial levers. Very, very happy with the stopping power. I regularly hit 40-45mph coming home from the trails and am amazed at how quickly I can stop with these mechanicals (especially when compared to the stock Tektros. Blech.)
    panem et circenses
    Reputation: bvibert's Avatar
    Mar 2006
    6'4" ~270. I use Juicy 5s with 185F/160R rotors. Works perfectly fine for my riding. I had a 160 in the front, but it suffered from brake fade on some of our longer descents here.
    Nov 2008
    Avid Code 185/160 on my rigid 29er singlespeed. Tried BB7 185/160, but could not get enough power out of them. I thought that the Codes may be too much for a XC SS rig, but I am not regretting the decision at all.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Hydros
    Quote Originally Posted by Gaffed
    STOP!!!
    You will never regret getting hydros, more stopping power, hardly any maintenance other than replacing worn out pads which doesn't even require any tools on my Juicy 7s, small learning curve if you do your own service work. Dot brake fluid is preferable, IMO.
    Hydros are simpler in reality, and no hand cramps. Light pressure with a fingertip is all that's required.
    I ride with the best dogs.
    I am 17st (6'1") and have hayes nine with 6" (160) rotors. works fine, MIGHT put a 7" on front (might not). get hydros.
    rm -fr *
    Reputation: wahoofish's Avatar
    6'2" @ 230lbs have avid bb7s on the full susp, avid bb5s on the redline d460, and some tektro v-brakes on the redline d440. i like the simplicity of the mechanicals but you can quickly go from slight braking to locked wheels. hydros give you lots more middle ground between the two extremes.
    Underskilled
    Reputation: CaveGiant's Avatar
    When riding XC I used shimano XT with 203. With an almost unfortunate collision with a barbed wire fence I started saving.
    220 mm rotor Formula the one brake.
    I am now able to decelerate 240lb easily and safely.
    moral: You can never have too much braking power at this weight.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Juicy 7s with 203 up front and 180 rear. I started out at 288 pounds and now I'm 255. No shortage of stopping power ever.
    I like turtles
    Well, I've swapped to mechanicals. BB7's 203/185 combo with Clarks pre-lube cables. It works wonderful.
    hydraulics: hayes nine 8"/6" for mountain riding...
    Bikes + Wedding = Less Bikes
    2010 RockHopper Comp Disc
    peoperly set up BB5's or BB7's have awesome stopping power.
    Quote Originally Posted by BeaverTail
    agreed, i had BB5s with a 160mm rotor... easily would send me OTB if i wasn't paying attention. and i weigh 230lbs
    slow uphill
    Reputation: orangedog's Avatar
    I'm 6'8" 250lbs... use a 203 front and 185 back... almost wish I'd gone 203 front and back, but for XC the 185 back is working ok.
    6'5" 300lbs My current bike has Cantilever brakes that grab the rim. After decending out of the park my rims are quite warm to the touch.
    My new bike (1 week hopefully!) will have hydro and be 203 front, 185 rear. It'll be interesting to see how much fade I get...
    Jan 2009
    Good job!
    Quote Originally Posted by WTF-IDK
    I'm 6 foot 300lbs.on my Heckler
    now thats gotta be a monkey humping a football right there...
    Reputation: markymark's Avatar
    Have tried everything. Hands down Magura Louise FR is the best set of brakes I've ever had and I got them for a lot cheaper than avid mechs. But Avids mechs are ok too, got them on my 29er.
    Quote Originally Posted by markymark
    WHERE?!!!!!
    Avid mechanicals are cheap, i spent $150 including the clarks pre-lube cables& levers for my front and rear set-up
    Quote Originally Posted by AlexJK
    WHERE?!!!!!
    on sale at chainreaction
