Results 1 to 11 of 11
    Reputation: fishrising's Avatar
    Mar 2012
    Stan's Arch vs Flow - Who is Riding Which?
    What are you Clydes riding when it comes to Stan's wheelsets?
    I'm 240ish, the Arch gives a 230lbs limit, the Flow has a 250lbs limit.
    I'm right in between....
    Oct 2011
    have ridden both....I am 225 but closer to 235 with all my stuff on. Arch's have held up just fine for me and I pound them pretty hard. If you are over 230 though you could be considerably more with water/kit etc. The flows are awesome too....probably a better choice for someone of your stature. Of course this is all just opinion.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Currently in the neighborhood of 270 lbs and riding Flows. The same set for the past three years.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    You could keep shedding the pounds and be under the weight recommendation for the Arches but I think it also comes down to the type of riding do you do most and the bike are these going on. I weight about 235 geared up but chose the Flows more because of my ride style and the trails I ride most.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    turtles make me hot
    Reputation: NYrr496's Avatar
    How's your riding style and the terrain you regularly ride?
    Go with Flows and give yourself some safety margin.
    I like turtles
    Reputation: 4nbstd's Avatar
    I chose Flow for the reason others have given. I'm 220lb, but I'm on rigid with a lot of air time. I would rather have stronger wheels than lighter wheels.
    Ghisallo Wheels
    I'm really good looking.
    I will go with arches, I am 230, I prefer xc style riding and normal trail riding... long walks on the beach and candle light dinners.
    Read the 30 other threads on herd...flows!
    Mar 2012
    Thank you all for your responses.
    May 2013
    260lbs here using flow the strongest rim I've ever use
    Reputation: Alaskagriz's Avatar
    +1 for Flows
    Where's the gas pedal on this thing?
  1. Stan's Arch EX vs Flow EX for a Clyde
    By BlackOut in forum Clydesdales/Tall Riders
    Last Post: 11-27-2015, 07:15 AM
  2. Flow vs arch
    By napa in forum California - Norcal
    Last Post: 12-28-2012, 11:39 PM
  3. Easton EA90 XC vs Stan's ZTR Arch EX vs Stan's ZTR Crest
    By hexeis in forum Wheels and Tires
    Last Post: 12-26-2012, 02:54 AM
  4. Arch vs flow (have problems with arch)
    By Wanny in forum Wheels and Tires
    Last Post: 06-22-2012, 10:17 AM
  5. Arch vs Flow??
    By jekyll2003 in forum Wheels and Tires
    Last Post: 05-09-2011, 06:38 PM
