Results 1 to 5 of 5
    Reputation: 0351's Avatar
    Nov 2013
    Single speed torque on hubs
    Is there any concern for hubs failing while mashing on SS bikes? Will Hadley's hold up? Or would you pay $200 more for DT240s' ? I'm 210#
    Fat-tired Roadie
    Nov 2007
    Not a clyde and only sort-of a singlespeeder here, but no. The hub is the least of my worries.
    My hardtail goes down to a 22/34 gear ratio. In terms of torque, that means that a little more than 150% of the torque I put into the crank gets delivered to the freehub. Now and then, I still get out of the saddle and really shove to get up something steep, even with that low a gear ratio.
    On the other hand, the classic singlespeed ratios are all higher than 1:1. I've seen 2:1 cited some places, though I doubt I'd want to push that ratio off-road. With a 2:1 ratio, only 50% of the torque you put in at the crank would be delivered to the hub.
    So if I was doing a conversion, I'd probably just get a singlespeed cog and a chain tensioner and go.
    Nov 2013
    Thx, there's a lot to learn when you want to build a bike, but I can't wait!
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    AndrwSwitch is correct.
    2:1 is the classic SS MTB gear ratio for 26" bikes. Add two teeth to the cog to compensate for a 29er. These are gear ratios we actually ride off-road, some a bit higher and some a bit lower but it's definitely the right ball park.
    So if a typical SS guy has 32/18 and a geared bike easily goes to 22/34, you do the math which has more potential to put torque to the rear hub.
    Nov 2013
    Thx guys
  1. Cheap 135mm Single Speed Hubs?
    By jnroyal in forum Fat bikes
    Last Post: 10-28-2012, 05:19 PM
  2. Replies: 3
    Last Post: 05-02-2012, 06:55 PM
  3. Alloy free hubs for single speed?
    By mike carmody in forum Singlespeed
    Last Post: 03-31-2012, 11:47 AM
  4. single speed hubs. king vs hope?
    By yer-mum-was-ace in forum Singlespeed
    Last Post: 02-29-2012, 11:37 AM
  5. Single speed hubs...
    By Nubster in forum Clydesdales/Tall Riders
    Last Post: 05-25-2011, 08:19 AM
