Results 1 to 10 of 10
    Feb 2010
    Seat post blues.
    I catch myself push'n back on my seat with my thighs try'n to find more room between the seat and handle bars, hope'n one of the seat post that has a bend in it will move the seat backwards a little & fix the problem.
    Whars could a guy find such a monster ? and whers the go to place for parts?
    Thanx guys.
    Keep The Rubber Side Down
    Reputation: Mellow Yellow's Avatar
    Sep 2003
    Thomson
    Best seat post for a Clyde. If ever I need one again, it will be a Thomson. You need to get one with the recess.
    http://bikethomson.com/products/seatposts/elite/
    Good luck!
    Some of my happiest memories in life took place on my bicycles. - Me
    Former Bike Wrench
    Reputation: sturge's Avatar
    Ditto what Mellow Yellow said...last bike I went through a Ritchie, then a Race Face. Had to bring hardware with me every ride because I was exploding bolts. Finally went with the 'setback' Thompson design and never had a problem again.
    07 Kona Dawg Supreme
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Since the Thomson has a zero setback clamp, is the net setback really any further back than a straight post with a setback clamp?
    The Thomson setback post only nets you an extra 16mm. Conversely, the Crank Brothers Cobalt seatposts with their setback clamp will net you 20mm of offset.
    FSA makes a post with 35mm of offset:
    http://www.masherz.com/products/fsa/...seatpost09.htm
    They also make a version with 25mm offset.
    Thay also have an aluminum post with 20mm offset for $29.95:
    http://www.cambriabike.com/shopexd.a...y+Mtb+Seatpost
    Kore makes this 20mm offset clamp model for $19.95
    http://www.cambriabike.com/shopdispl...tain+Seatposts
    There are other setback clamp models that have 20mm +/- offset
    Quote Originally Posted by jeffj
    Not trying to hurt anyone's feelings or anything like that, but if I was bustin' bolts on posts, I would NOT go with a carbon laid-back post....
    Feb 2010
    Thanx for the input gents, definately gonna look into the examples given.
    Unless its unplanned most of my ride'n is pretty tame so maybe it'll last a while.
    Thanx again.
    Oct 2010
    Thomson all the way! I broke finally broke one on "mishap". Until the thomson I was breaking posts every other week it seemed like. I ride aggressively and weigh 365. Thomson replaced no questions!
    How’s your front to rear balance on the bike? And position over the cranks? If you are looking for a bit more cockpit room a longer stem might be part of the solution.
    Kool-Aid, Kool-Aid, Taste Great... Oh Yeaahh!
    Reputation: Midgetman's Avatar
    Since the Thomson has a zero setback clamp, is the net setback really any further back than a straight post with a setback clamp? ...
    Good post + the Thomson post doesn't allow for very much saddle fore and aft adjustment. It's a great post though.
