Results 1 to 15 of 15
    Reputation: jekramerjr51's Avatar
    Seat Height Blues
    I have been having problems retaining seat heigth. I ride a hardtail with a Race Face Evolve seatpost with a Hope quick release clamp.I'm thinking about changing posts or taking this post to a machine shop and having it "knurled". Are there any seat posts out there that are knurled or grooved? Thanks to all you fellow Clydes out there for any comments or suggestions.
    Start by getting rid of the qr clamp! That is not the place that you want qr(unless you like stealing other peoples seats and posts)!
    Reputation: Joules's Avatar
    Thomson posts have ribs which seem to help. Also, they are the best post on the market in every other way.
    How tight is your QR? The only times I've had a post slip, qr or bolt, it was slightly undersized - typical of real inexpensive posts.
    I have it so tight that it takes real effort to close it.And when i'm riding,it creaks and makes alot of noise. Very frustrating!
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    The grease that is used to keep the post from sticking in the seat tube is also slippery. Years ago, someone mentioned using chalk instead of grease; the dry kind, not greasy crayons.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    I have been reading about where riders have taken an aluminum soda can and made a "shim". Any thoughts,pros or cons?
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    Quote Originally Posted by jekramerjr51 View Post
    Have you lubed your QR clamp recently? If you haven't, put a bit of grease or chain oil in there. Chances are it is too loose, but the friction is making it feel super tight. Creaking is also a sign that it needs some lube.
    Reputation: thickfog's Avatar
    Oct 2010
    My evolve slipped like mad in my sir9. Truvative team post has been better, but not 100%.
    I know what you mean by qr so tight that it's hard to close/open.
    Sometimes I think it's a seat tube issue. Gonna try fiber grip next which is usually used for carbon fiber and aluminum contact.
    CRAMBA Chairman
    Friction paste is what you need.
    Here's a brand. However, your LBS has some for certain and they may just put some of therir's on your peat post if your a return customer...
    http://www.trisports.com/fsa-install...ion-paste.html
    Oct 2010
    Yes, that's more like it. Any other experience using this successfully?
    CRAMBA Chairman
    rock crusher
    I replaced a useless Hope QR on my 135# wife's bike recently because it slipped all of the time. It was replaced with a Salsa Lip Lock, same as this 230# clyde runs, because it won't slip
    Reputation: KTMDirtFace's Avatar
    My race face evlolve post creaks like mad, but its not the post its the clamps on the seat. I don't know whats up with it.
    I actually broke my stock giant QR ( bent it ). I have a salsa quick release on there no problem. Never slipped, not evn super tight.
    I'm 6'6" 225.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I weigh about 250 and have a Thomson post and a Syntace clamp. No problems.
    I like turtles
    Dont waste time or money....
    Hey Pop,
    Just wanted to let you know that the seat on my Haro came knurled stock and I still have slippage. (About an inch per 2-3 hours). Not bad but still annoying. I did some research and even if you replace your QR with a post bolt you will still have the same problems. (Face it, we are clydesdales, right.) I have also heard that checking your seat post pre-ride for any small pebbles that may be acting as a bearing will help. I read that rubbing dirt and baby powder on your seatpost may be effective short-term but you run the risk of your seat seizing in your seat tube. I am going to try using an aluminim can as a shim. That seems to be the most cost effective solution that I have come across. Give it a whirl! Ride Hard!
    I use carbon paste on my thompson with my salsa lip lock...i'm 6'6" 250lbs.. sometimes it creaks, but never slips.
  1. Seat height vs Handle Bar Height for AM
    By chcmuzza in forum All Mountain
    Last Post: 12-21-2017, 07:43 AM
  2. Seat post blues.
    By Fox Fire in forum Clydesdales/Tall Riders
    Last Post: 04-01-2011, 10:32 AM
  3. Bar height vs. seat height on Mojo
    By getbusyliving in forum Ibis
    Last Post: 02-04-2011, 01:13 PM
  4. Seat Height relative to Handelbar height
    By Rob Mac in forum Singlespeed
    Last Post: 01-22-2010, 10:56 PM
  5. Determining handlebar height to seat height
    By bwheelin in forum Bike and Frame discussion
    Last Post: 09-22-2009, 10:39 PM
