Results 1 to 9 of 9
Thread: seat clamp
    Oct 2010
    seat clamp
    I have a salsa lip lock seat clamp that keeps slipping. Can they actually go bad? Screw still fine. What are my other fellow clydes using?
    Mar 2011
    I hope not, I just ordered two of them. One for me and one for my wife.
    I have been using the stock QR that came with my bike and it has been slipping a little. Good thing I marked my height on the tube.
    How tight do you have the screw? Are you sure you have the right size clamp?
    I would imagine that this would be a good place for some locktite if you don't plan on changing the height.
    Former Bike Wrench
    It's more likely the post fit in the seat tube...make sure the fit is correct. If it is really loose you may need to go up one size. You can also add a little sand to the post (stick to the grease) to create a tighter fit.
    I once had a frame that was supposed to be a 27.0 seat post size but even a textured post like a Thompson slipped. I honed out the seat tube a little (your LBS should have the correct hones) and went with a 27.2 and never had a problem.
    Reputation: phbike's Avatar
    I cannot use quick release seat clamps. They've always slipped (240 lbs). I always have to use allen bolt type clamps
    Oct 2010
    Quote Originally Posted by mtnbiker72 View Post
    I'll have to check, I hope its not that. The frame is a custom steel, and he ordered all components and built up. It seemed to work fine til I got caught on the trails in a downpour and got pretty wet and sloppy. So that's why I was wondering if mine went bad. It seems pretty simple piece not much to actually go bad.
    friction paste!
    Clean the frame and seat post very well and use friction paste (a gel/lubricant with super fine grit) on the seat post.
    Quote Originally Posted by dadtorbn View Post
    friction paste!
    yes, did the same thing. went from my stock bontrager QR to a Salsa LipLock with carbon friction paste, 6'6" 250lbs and boom nice and solid
    Maaaaan
    Reputation: Ericmopar's Avatar
    Aug 2003
    That's actually a common problem on new bikes. It isn't helped by the fact that many of the seatpost sizes are only fractions of a millimeter apart.
    Communist Party Member Since 1917.
    Former Bike Wrench
    Quote Originally Posted by Ericmopar View Post
    Yep and this was a Bontrager frame (Trek made) so it wasn't some generic tubeset, it was True Temper OX II.
  1. Replies: 1
    Last Post: 08-23-2010, 02:33 AM
  2. Replies: 3
    Last Post: 08-19-2010, 07:19 PM
  3. Seat Post to Seat Clamp Table
    By Whafe in forum Nicolai
    Last Post: 07-24-2008, 08:10 AM
  4. Thomson Seat Clamp - Seatpost Clamp - Seat Post Clamp
    By tvrbob86 in forum General Discussion
    Last Post: 05-02-2008, 09:22 AM
  5. Replies: 4
    Last Post: 04-27-2008, 07:12 PM
