    Reputation: sprocket47's Avatar
    Oct 2010
    Scandium strength for big guys
    I'm looking at picking up a Niner and was initially interested in the AIR 9 which is made of scandium. In the reviews a couple people commented on the scandium strength for 200+lbs riders. Anyone have experience with this frame material?
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Like most materials used to make frames, it's probably fine if they use enough of it ;~)
    I'd call Niner directly and ask them how they feel about clydes using that frame.
    I don't think Scandium weighs much less per se, they just use less of it. I think mostly because they can butt the tubes further toward the end of the tubes/joints than they can with the other alloys they use.
    How much over 200lbs are you?
    Former Bike Wrench
    Jeffj hit it right on the nose...Scandium is just a very small amount added to standard Aluminum. What it does is align the grains which increases fatigue resistance.
    IF companies used the same amount of material as a standard frame it would be stronger...but instead they use less material for a lighter (and often) more compliant frame.
    Check with Niner but I'd guess their EMD would be the stronger frame.
    Oct 2010
    More this time of year but around 240.
    The EMD seems a little cheap to me...but that might just be me. The MCD is steel and that seems like a nice option if the scandium won't work.
    I have an email to Niner asking what they think would be best for my size and riding type as well.
