Results 1 to 2 of 2
    Reputation: eric_syd's Avatar
    Scalpel 1st generation FOX RP3: help needed
    I am just finishing the build of my Scalpel 1st generation (softail, carbon chainstays).
    The rear shock is a Fox Float RP3.
    I'm 110kg, what pressure should I put in it ?
    At 170 psi, the sag is still very impressive. How much higher can I go ?
    Eric
    PS: this is a cross thread in the Cannondale and Suspension forums
    Former Bike Wrench
    Quote Originally Posted by eric_syd View Post
    Eric
    Fox gives 300psi as the maximum pressure...start with your body weight (lbs=psi) and adjust from there.
  1. Is there a specific Q-factor needed for XX on Scalpel?
    By TonyONeill in forum Cannondale
    Last Post: 10-15-2012, 07:13 AM
  2. Scalpel 1st generation shock: help needed
    By eric_syd in forum Cannondale
    Last Post: 10-18-2011, 04:43 PM
  3. Replies: 2
    Last Post: 03-16-2009, 03:28 AM
  4. Replies: 5
    Last Post: 04-07-2007, 06:07 PM
