Results 1 to 5 of 5
    My shop always suggests bringing the forks in there for service. Might not be a bad idea as forks are expensive.
    good luck
    sbd
    sbd is offline
    Reba set up suggestions
    I am 230# and have the stock 80mm Reba that came on my 08 Stumpy Comp 29er. After a few years of pounding, the fork is feeling a little flat. I was looking for some guidance before i starting fiddling around with it.
    sbd
    sbd is offline
    If there was a decent LBS with and hours drive I might do that, but there isn't!
    Besides, I don't think there is anything wrong with them, but I am fairly sure they have slowly lost some air over the last three years, and I am going to try that first. There are settings on the leg but I have heard they aren't very accurarte.
    Former Bike Wrench
    Servicing is pretty easy, it should be done for sure after 3 years of use
    http://www.google.com/url?sa=t&rct=j...MOLupzdtdAtUMg
    http://www.sram.com/sites/default/fi...4160_rev_a.pdf
    sbd
    sbd is offline
    That was mighty helpful! Thanks a bunch!!!
  1. 2011 26" or 29" Reba RL OE $330
    By sslikesnake in forum Where are the Best Deals?
    Last Post: 01-19-2012, 04:31 AM
  2. which bike and tire set up would you choose ?
    By jincardona in forum All Mountain
    Last Post: 01-16-2012, 09:13 PM
  3. Need Crank Suggestions For Single Chainring Rig
    By CharleyGnarlyP290 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-16-2012, 11:38 AM
  4. XC wheel set for 5spot?
    By tald in forum Turner
    Last Post: 01-15-2012, 02:50 PM
  5. Replies: 0
    Last Post: 01-13-2012, 12:12 PM
