Results 1 to 9 of 9
    Reputation: jkidd_39's Avatar
    Sep 2012
    Offseason HT Clyde build
    I'm building my new HT over the winter. I am 6'4" 280lbs.. I have an Orbea Carbon fiber Frame. It's weighing in at 3.2lbs. Figured I would ask all you big guys if my build list needs any changing? I want if to hold up under me. The only weak spot I might have is my wheelset. Any opinions are greatly appreciated.
    Thanks guys
    Wheels Stan's ZTR Flow 29er $595 1935g
    Fork X-Fusion Slide RL2R 29er $479 1905g
    Front Derailleur SRAM X.O. 10spd $78 130g
    Rear Derailleur SRAM X.O. 10spd $263 193g
    Crankset SRAM X.O. 26-38 Crank $382 580g
    Bottom Bracket "XD-15R BB30/BBRIGHT $119
    Brakes - Front Shimano XTR $169
    Chain guide Bionicon C.Guide V.02 $49.99 19g
    Cassette SRAM PG-1050 $90 299g
    Chain SRAM PC-1091R $56 265g
    Handlebars Thomson $149 195g
    Stem Thomson $99 167g
    Headset KCNC/RWC INTERNAL x EXTERNAL HEADSET $85
    seatpost Thomson $149 193g
    Saddle Ebay CF Saddle $60 145g
    Brakes - Rear Shimano XTR $169 220g
    Rotors- Shimano Icetech rotors $120 230g
    Shifters - SRAM X9 Grip shifters $paid 287g
    Tires Schwalbe Rocket Ron $180 1040g
    Total Total
    $3,291 17.6lbs
    Ski N Bike Tech
    Reputation: SkiNBike's Avatar
    The flow rim is a good one. I've put many a larger customer on that rim.
    What spoke count did you go with?
    Sep 2012
    I haven't built it yet.. thinking 32 spoke
    Ski N Bike Tech
    Yes. Do 32.
    I'm a 300+ rider and I did 32 on my rear wheel and 28 on my front (I got the front hub used from a co-worker back in 08). 3x lacing with DT champion spokes and they are holding up great. I'm using 240s hubs and DT400xr rims. Not as stout of a rim as you are using and I do wish I had picked a wider rim. But that will be next time.
    Oct 2010
    Quote Originally Posted by SkiNBike View Post
    Yes. Do 32.
    Agreed,
    Those DT XR400's want hold up to that weight and any amount of abuse. My SB95 came with a set (w/DT 350's) and I tweeked the front rim in just 15 miles...I weigh less @275lbs. So I installed a set of Stan's Flow EX wheels. The Stan's wheels are much wider/beefier and adds a little weight but it's well worth it.
    Nov 2008
    Build looks great. There's only one thing that confuses me, when is there an offseason? Ride all year
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by Sasquatch1413 View Post
    ^^^This. Riding in the snow is a blast!
    Nov 2012
    are those your actual costs for that drivetrain? id be going for xx1 for what your paying for that stuff
    Sep 2012
    Quote Originally Posted by cpfitness View Post
    That was using pricing thru jenson and various other online retailers.
    Please point me to an XX1 drivetrain for less. I would love one!!!
